NVIDIA Volta
Nisi u toku postoje 8k monitori i televizori uveliko par linkova...
https://www.theverge.com/2017/9/12/16293326/dell-8k-monitor-review-ultrasharp-up3218k
http://www.dell.com/en-us/shop/dell...itor-up3218k/apd/210-alez/monitor-accessories
https://www.pcgamesn.com/8k-monitors-volta-navi
https://www.pcgamer.com/au-optronics-aims-to-ship-8k-displays-in-the-first-half-of-2018/
https://appleinsider.com/articles/1...-thunderbolt-3-4k-display-due-later-this-year
https://www.kitguru.net/peripherals...philips-to-launch-32-inch-8k-monitor-in-2018/
Dell je vec izbacio 8k monitor cena je sitnica nekoliko hiljada dolara,takodje mnogi 8k monitori-televizori dolaze u prvoj polovini ove godine...
Da 8k nije mejnstrim to se slazem i bice potrebno par godina da postane mejnstrim u Americi a kod nas mozda tek posle 2020 godine...
Vidi Crysis je isasao 2007 god. i dan danas moze da se igra u 4k tako i danas sutra igre koje izadju ce moci da se igraju u 8k.
Najvaznije za ovu narednu generaciju grafickih je VR trziste i glatko igranje u 4k i pristojno igranje u 8k...
Samsung je najavio isto da ce izbaciti televizore ove godine u 8k ne mogu da nadjem sad tu vest ispravka evo je https://www.cnet.com/news/samsung-spits-out-an-85-inch-tv-with-8k-resolution-ces-2018/
nece jos dugo dugo biti grafike koja ce gurati 8k 30fps
Nisam rekao da ce za 8k biti dovoljna gtx 1180 nego 1180ti a i ako ne bude dovoljna jedna gurace onda dve i omogucice tih 30 fps a i vise.
Inace evo vam jedan komentar kupca koji kupio dell-ov monitor od 8k...
It’s like being in the future, I can’t even share screenshots with people because the average display isn’t at this level yet so owning this does come with some inclusion. It’s being powered by 2 1080Ti Hybrid with the SC2 Trim. Gaming isn’t always 60FPS but surprisingly many titles will hover between 50-60, such as ESO, Overwatch, and World of Tanks, but I’m expecting the next generation of Nvidia Ti cards to get me there.
Znaci 2 komada 1080ti vecina igara na 50-60 frejma na dell-ovom od 8k...
2 komada 1180ti recimo omogucice glatko igranje na 8k a jedna omogucice pristojno igranje 30 fps-a ili vise.
Tek sad vidim da komentarisete od tomasbg post sorry onda za off 🙂.
sve te igre sto su navedene mogu da rade na intergisanim grafikama,nek potera witchera 3 ili crysis 3.
Da ne govorimo o ceni takvih monitora/televizora + 2x1180Ti + resto mašine da gura sve to...ne zanosimo se.
Evo za neverne tome i to par igara
Evo vam i Crysis 3
Kao sto vidite ti klipovi su jos iz 2017 god. sada smo uveliko vec u 2018 god. i planiraju se jos mnogi 8k televizori i monitori.
Mogu jos klipove naci ljudi se uveliko igraju u 8k sa Sli sa Titanom XP ta gtx 1180ti ce sigurno biti jaca od TitanXp...Sto znaci da sa 2 komada gtx 1180ti moci ce da se igra sve u 40 fps najmanje.
Da cene monitora su par hiljada eura naravno da nisu za nas dzep ali u americi,japanu itd. to za njih i nije puno i jako brzo ce to da zazivi kod njih...4K se tamo vec uveliko koristi kod nas je to retkost da se neko igra u 4k.
Meni iskreno 8K u gamingu nema smisla na monitoru, to je tech za VR gde je veca rezolucija potrebna, barem 2x 4K, jedino sto adaptacija tg trzista kao i podrska jakoooo sporo napreduje
Pa da mi sa sadasnjom generacijom karti mozemo imati 60 fps-a u 8k rezoluciji to sam hteo da dokazem...Jer je tomasbg napisao da su sve to slabe igra za Dell-ov monitor od 8k i da je kod njih lako dobiti pristojan fps zato sam stavio eto i Crysis 3 i Witcher 3.
Sto znaci da sa sledecom generacijom mozemo dobiti istu stvar sa jos manje grafickih karti jer ce gtx 1180ti sigurno biti jaca od titan xp.
Pa mex87 isto su pricali i za 4k da je to preterano i za 2k svaki put kada odskocimo u tehnologiji uvek ista prica kasnije se ljudi naviknu na to i o tome se vise i ne prica nego se u istoj tehnologiji uziva.
Za VR ce mnogo da znaci i to je po meni i bitnija stvar nego 8k gaming jer realno 8k jos nije za siroku masu ljudi,ali ko ima novca lepo uzme 2 komada gtx 1180ti i igra se i ne brine za fps 🙂.
Presmešna priča o 8k rezoluciji na kojoj treba da gledam u teksture naprevljene za konzolne portove / igre zasnovane na konzolnoj tehnologiji koje ne prelaze 512x512 za okolinu i 1024x1024 za likove.
Nađite Skyrim modove sa teksturama od 4096x4096 pa pokrenite to u 8k... trebala bi vam farma GPU za kopanje kripta da ide na 60fps, a da ne pominjem 144hz i 144fps konstantnih.
Snovi...
Medonjo, neki softveri su pisani da iskoriste mogucnosti gejmerskih kartica, jedan od njih je Oktan, moju Quadro karticu K5200 pegla neka 1050 Ti.
Inace tu P5000 pegla svaka 1070-ka! Cak i GTX 980ti je unistava.
Quadro je djubre!!!
https://render.otoy.com/octanebench/results.php?v=&sort_by=&filter=&singleGPU=1
Jesi li probao da isključiš ECC u Nvidia Control Panelu i onda da vidiš da li je išta brže?
EDIT: Inače, GeForce karte nemaju više mogućnosti od svojih Quadro parnjaka.
Ma kakav ECC, krsevi, ajde nadji jedan softver gde ce neka quadro karta da nadmasi 1080ti! Pogledaj Vray, Oktan, Red Shift, quadro kupujemo samo mi naivni retardi!!!
Jesi li isključio ECC ili nisi?
Evo i tebi jedan info od "nevernih toma". U pitanju su 4 Titan Xp graficke na klipovima koje si postavio 😀
E to, to, četiri komada a ne dva i još u W3 isključen AA i nVidia dlakaworks. Na sve to četiri XP ne mogu da izguraju 144 fps nego jadnih 60. Pfffft. Mis'im @Fallout 3 ono 8k monitor a ovamo sirotinjskih fps.
Snovi...
Upravo tako.
Cak i na 1080p60fps postoji jos jako mnogo prostora za dodavanje detalja i likova i terena.
Po nekim online izvorima 1170 i 1180 (ako se tako budu zvale) ce u startu biti bar 20% skuplje od 1070 tj 1080.
A kakve ce biti cene po kojima cete stvarno moci da kupite nove karte videcemo sta ce biti sa kriptovalutama.
Proslo je tacno dve godina od izlaska 1080 i jos uvek je skuplja od launch MSRP.
perafilozof-Nisam video da postoji monitor 8k sa 144hz,za sada moze da vrti 8k samo 60 fps-a....
Pa smesna prica je bila i 4k do pre par godina,ali izaci ce i igre sa boljim teksturama u buducnosti 🙂.
Ja vjerujem da će u avgustu biti samo paper launch Volte ili Pascal druge generacije sa GDDR6 koja će biti 25% brža od prethodne generacije. Sumnjam da će biti znatnih poboljšanja sem ako AMD ne izbaci nešto konkurentno.
@offtopic
Kako imati devojku kad mi zena da dve iljade za izlazak????
A ovome žena dala 1000 i kusur evra samo za večeras da potroši. :d
https://youtu.be/4bVmG6mi5OU?t=34s
Computex:
Q: When is the next GeForce? A: I'll invite you. There will be lunch. But it's a long time.
Q: When is Volta coming to gaming? A: So many gamers were deprived of GeForces due to mining, but now pricing is coming down. 1080/Ti are the best cards right now, we suggest they buy GeForce ASAP
U prevodu: "Nema potrebe ulagati u razvoj nove generacije kad nemaju konkurenciju i imaju odlicnu prodaju, kupujte dok jos mozete po ovim cenama jer ce uskoro rast cena zahvaljujuci minerima"
Ako bude tako, to će samo rudari kupovati...
Sent from my SM-G965F using Tapatalk
Napokon. N A P O K O N. Ma dosta je bilo sa trocifrenim cenama. Vreme je da se u svim segmentima uplovi u četiri cifre i da se ovaj trocifreni teror završi. 😀
