Nokia 6
SuperStarr
Moderator
CPU & Cooler
Xeon 5670 (6c/12t) @ 4.3Ghz
Matična ploča
ASUS P6T Deluxe v2
RAM
48Gb HyperX DDR3 @ 1666Mhz
GPU
Gigabyte 1060 6Gb
Storage
Kodak 512Gb + 16Tb RAID
Zvuk
Creative Audigy2 ZS
PSU
Zalman ZM600-HP (Heat-Pipe :) )
Kućište
Alexander Weiss (glass front + glass side)
Monitor
AOC 32" IPS
Miš & tastatura
G602 & Drevo 87 key (Red Switch)
Ostale periferije
MX Master 2 & K380
Mobilni telefon
Moto G9 Plus
Pristup internetu
  1. Kablovski internet
http://www.gsmarena.com/compare.php3?idPhone1=8571&idPhone2=6885
Osnovno:
  • Android 7.1.1 (Nougat)
  • Qualcomm MSM8937 Snapdragon 430
  • Octa-core 1.4 GHz Cortex-A53
  • Adreno 505
Razlike između Nokia 6 modela:
(TA-1000 vs TA-1003):
The difference between TA-1000 and TA-1003 is that the TA-1003 variant comes with Google services, while the TA-1000 doesn’t have Google Apps and uses a customized Android Nougat that follows the guidance of the Chinese government.
Izvor:
http://nokiamob.net/2017/06/15/hmd-explains-why-you-shouldnt-buy-nokia-6-ta-1000-outside-china/
[table="width: 900, align: left"]
[tr]
[td]Model Number[/td]
[td]Region[/td]
[td]Sim Sockets[/td]
[td]WCDMA Bands[/td]
[td]LTE Bands[/td]
[td]HAC[/td]
[/tr]
[tr]
[td]TA-1000[/td]
[td]China (No Google Services)[/td]
[td]Dual SIM[/td]
[td]?[/td]
[td]?[/td]
[td]?[/td]
[/tr]
[tr]
[td]TA-1003 (4Gb/64Gb)[/td]
[td]Hong Kong and Taiwan[/td]
[td]Dual SIM[/td]
[td]?[/td]
[td]?[/td]
[td]?[/td]
[/tr]
[tr]
[td]TA-1021[/td]
[td]Global Variant[/td]
[td]Dual SIM[/td]
[td]1/2/5/8[/td]
[td]1/3/5/7/8/20/28/38/40[/td]
[td]Not Support[/td]
[/tr]
[tr]
[td]TA-1025[/td]
[td]Dual SIM[/td]
[td]1/2/4/5/8[/td]
[td]2/3/4/7/12/17/28/38[/td]
[td]Support[/td]
[/tr]
[tr]
[td]TA-1033[/td]
[td]Single SIM[/td]
[td]1/2/5/8[/td]
[/tr]
[tr]
[td]TA-1039[/td]
[td]Single SIM[/td]
[td]1/2/4/5/8[/td]
[td]Support[/td]
[/tr]
[/table]
Izvori:
http://www.teamandroid.com/2017/08/04/nokia-6-model-numbers-variants/
https://www.nokiacamp.com/hmd-minor-hardware-software-changes-nokia-6/
Nokia 6 Drivers:
http://gsmusbdriver.com/nokia-6
http://www.teamandroid.com/2017/08/21/download-nokia-6-drivers/
ROM
Po tvrdnjama sa neta, čak i da instalirate TA-1003 ROM na TA-1000 uređaj, isti će biti prepoznat kao "Custom ROM" i bićete onemogućeni za "OTA update".
Autor ovog posta to ne vidi kao naročit nedostatak u slučaju da imamo mogućnost instalacije "Custom Recovery"-a, svaki update se može instalirati naknadno, flešovanjem kroz Recovery.
Sa druge strane, neki tvrde da su uspeli da savladaju ovu prepreku.
Izvor:
https://forum.xda-developers.com/nokia-6/development/problem-firmware-nokia-6-ta-1000-t3640667
Download link:
https://drive.google.com/drive/folders/0BwYm0ERh9P1WOENiOFh2TTNtRzA
Ovde imamo i potvrdu uspešnog flešovanja: https://forum.xda-developers.com/showpost.php?p=73371031&postcount=18
Sve ovo nas, na ovome području ne bi trebalo da zanima jer bi mi trebalo da kupujemo TA-1003 uređaje.
Zanimljivo je zato što su ovo prvi koraci koji će, nadamo se, dovesti do toga da imamo da jednog dana imamo veliki izbor Custom ROM-ova i laganu metodu instaliranja Custom Recovery-a i Root-ovanja ovih telefona.
Zašto ne bi trebalo koristiti TA-1003 ROM na TA-1000 uređaju?
But that modyfied rom too much power consuming! Guys, if you got stock ta1000, dont even think of that damn ta1003rom.. it got native 6 cores active all the time while stock got 2 cores active in stanby.
Izvor:
https://forum.xda-developers.com/showpost.php?p=73332216&postcount=14
  • Navodno je moguće koristiti MiFlash by Xiaomi umesto QFIL softvera.
  • Navodno, postoji TWRP Recovery za Nokia 6, ali na kineskom.
  • Navodno, EDL Kabel za Qualcomm uređaje koji se može kupiti preko eBay-a radi i sa Nokia 5 / 6 telefonima.
Izvor:
https://forum.xda-developers.com/showpost.php?p=73453123&postcount=52
Protivrečnost:
https://forum.xda-developers.com/showpost.php?p=73450161&postcount=22
Nokia 6 Global variant FW ( TA-1053 DS ) or TA-1003:
Još uvek čekamo link!
prateći hardver
Nokia 5 / Nokia 6 connect / EDL cable - Thug Life version:
  • Prespojite 2 leva pin-a na USB kablu. Za ideju kako to uraditi sa alu-folijom, pogledajte sliku iznad.
  • Ubacite kabal u USB port. Učinite to pažljivo. 🙂
  • Ugasite telefon. Ubodite kabal u telefon. Sačekajte 10 sekundi, ako se telefon ne "pali" - sve je u redu, spremno je za dalje korišćenje.
  • Ako se telefon "budi", nešto nije u redu sa "modom".
  • Ovo je takođe primenjivo i sa "USB C" and "Micro" kablovima.
izvor: http://forum.gsmhosting.com/vbb/f296/nokia-5-nokia-6-connect-edl-cable-little-ones-2246357/
Pojašnjenje kako ovo radi:
http://forum.xda-developers.com/showpost.php?p=73573730&postcount=73
moze li mi neko porediti Xiaomi RMN3 i Nokiu 6? kamera, baterija, zvuk pri zvonu, brzina punjenja? hvala
@SuperStarr jesi li ti to kupio Nokiu 6 ? :d
Jesam i već sam mi nedostaju LED notifikacije. 🙁
😀 neka te lepo sluzi, pazi to im je teska ******stina a mozda se oslanjaju na Ambient display koji dolazi uz Oreo 8.0 ... 8mica ima Glance a ove zakinuli, nisu mi jasni...
Nokia 6 i LED notifikacije:
Thank you for contacting Nokia Mobile Care
Regarding your question about the Nokia 6, please be informed that your device doesn't have LED notifications.
If you have any further questions, please do not hesitate to contact us again.
Best Regards,
Nokia Mobile Care team
Ma generalno bedak, "kinezi" imaju više razumevanja za korisnike.
Za ove u Nokiji se vidi da su dugo sarađivali sa Majkrosoftom - uvek su oni u pravu. :S:
Samo da "provali" neko kako da rutujemo telefone pa prelazimo na custom ROM-ove i pečeve. Ali treba izdržati do tada. 🙂
I kako si generalno zadovoljan telefonom s obzirom na ulozen novac? Je l' ima neku izrazenu manu ili nedostatak izuzev LED notifikacija? I baci komentar na bateriju i kvalitet kucista aka osecaj u ruci i tako to 😀
Veca je mana sto je chipset lesina i cena koju su stavili za telefon sa takvim chipsetom nego Led notifikacija.
Nokia 7 sa SD 625 ce biti super ako bude kostala 270-280e.
Ја ћу да узмем шестицу али код мтс-а јер нуде дуал сим. Вип нуди са једном картицом.
Ne znam sto stalno to ponavljas ali nema smisla ... mozda konverujes filmove ili igras neke mocne 3d igrice pa ti je bitan svaki fps 😀
We ran the usual set of benchmarks and looking at the results, we debated whether we should bother publishing them at all - they're mostly identical to the ones from the Chinese version. A slightly more pronounced difference in the all-important (not really!) Antutu benchmark tipped the scales.
So we decided to compare the global Nokia 6 performance to a bunch of competitors which weren't out yet at the time of publishing of the old review back in April.
Let's kick off with Antutu then. The Nokia 6 for the rest of the world manages to outperform the Chinese version and the Moto G5 (itself equipped with a Snapdragon 430) and is on par with the Galaxy J7 (2017) and the Meizu M5 Note.
From then on in ascending order we have the Moto M (Helio P10), the Galaxy J7 Max (Helio P20), the Redmi Note 4 (Snapdragon 625), and the Moto G5 Plus (again, S625).
An even higher tier of chipsets is to be found on top of this chart with the Redmis packing a Snapdragon 650 and two Helio X20s - you could find these Xiaomi smartphones for the Nokia 6's money, so it's worth pointing them out.
http://www.gsmarena.com/nokia_6_global-review-1640p4.php
Zato sto je to cinjenica, to je low-end chipset u mid-range telefonu.
Zao mi je sto trziste ima jos jednu firmu koja nabija cene telefonima zbog brenda. Da ne pise Nokia na njemu, niko ziv ga ne bi kupio, nostalgija je cudo.
To sto se prodaje kao ludo nema veze sa kvalitetom uredjaja ili tome da li u tom cenovnom rangu ima neceg boljeg, a ima i globalno, da ne racunamo kineze(Huawei je globalno prisutan, pa njih racunam, kao i Lenovo). Ima veze iskljucivo sa brendom.
Edit:
Sto je taj telefon bolji od Lenovo K6 Note koji, ako ne gresim, od update-a na 7.0 ima stock Android, isti chipset kao Nokia i dosta bolju bateriju, kao i globalnu prisutnost, a kosta manje?
Ili od Moto G5 Plus koji kosta isto, ima SD 625 i stock Android?
Velicate telefon kao da je ne znam sta. Nije, samo pise Nokia na njemu.
@ivanbass svako ima pravo na svoju zabludu , kako mi tako i ti [emoji56]
neka se prodaje meni nije krivo, ima razloga... da nema nebi se prodavao pored vec mocnih modela koje si naveo [emoji4]
Ja sam naveo samo realne argumente [emoji14]
Telefon nije racunar - tu nisu bitne samo performanse vec i ukupan kvalitet izrade, poverenje u brend i sl. I tu kinezi nemaju sta da traze. Moram da priznam da ovaj Moto G5 jeste takodje dobra ponuda, iako je Lenovo. I to sto je SD430 sporiji od SD625 ne znaci da je spor vec samo da je sporiji. Obicni korisnici to nece ni da primete.
Primetili oni ili ne, razlika je velika.
Oni testovi gde se telefoni savijaju da se vidi u kom trenutku ce puci-takvu glupost je suvisno komentarisati.
Nokia kao brend je 0 medju Android telefonima, s obzirom da postoje od ove godine, tako da oni po tom pitanju nemaju nikakvog kredita, vec moraju da dokazu u narednim godinama da je brend dobar.
Vredjanje drugih brendova da bi odbranili neki brend je besmisleno, jer to nije argument, bas suprotno. Xiaomi telefoni razbijaju, kao i Meizu, LeEco, Huawei i Lenovo(ima ih jos).
Steta je sto vecina fura neke lesine od skinova i nije prisutna van Kine, inace bi druga prica bila na trzistu.
Edit:
Za kom ispod, da ne spamujem.
Taj ko sedne na smartfon ili kome ispada sa metar ipo na beton(meni dosta puta, sad svaki ide u case+staklo se lepi) apsolutno zasluzuje da ostane bez istog.
Edit2:
Volim Nokia brend, eno Lumia 735 koju sam nosio 2 godine i dan danas radi odlicno, samo sto su kao i uvek aplikacije krs.
Bas me zanima kakvu ce cenu imati sedmica.
3, 5, 6 i 8 su za mene apsolutno razocarenje sa chipsetovima(8 ovde ne racunam) i cenama.
Zasto glupost? Pa pre ce da sedne na njega i polomi ga nego da vidi razliku izmedju procesora dok lista fejs i instagram.
Da li ste sigurni da su Vip singl sim?
Sent from my LG-H815 using Tapatalk
