SR_Jugoslavija
Poštovan
Entry Vega je oko $500. RX 580 verovatno vise nece biti ispod $400 opet. Kupovina 1080 mi se cini boljom akcijom uopsteno.
Asus Radeon RX Vega 64 Strix Gaming
http://hexus.net/tech/reviews/graphics/109078-asus-radeon-rx-vega-64-strix-gaming/
A quick word on overclocking. We managed to run the Asus Radeon RX Vega 64 at 1,980MHz core and 1,000MHz memory, just beating out the clocks achieved by reference, and by doing so we added
an additional 6.4 per cent performance in a trio of games. The downside of this voltage-induced performance is that power consumption rose to 532W at the wall
Asus adding extra TDP to the BIOS obviously increases total power consumption. That is reflected in under-load figures that are 44W higher than reference.
However, that massive Strix cooler does an admirable job of keeping RX Vega 64 cool and composed.
What's more, though we didn't test in our own environment, the card's fans kept very quiet under load. We'd describe the card as barely audible in a typical gaming rig, as is the GTX 1080 version, to be fair, and therefore a huge improvement over the noisy Radeon reference model.
Drivers were the same 17.8.1 beta as used on the reference card.
Conclusion: Positive first impression
Even if a test of the final Asus Radeon RX Vega 64 Strix like the market introduction still a few weeks in must wait, shows the pre-production copy of Asus already where it goes with this partner card: In the right direction. This is largely due to the 2.5-slot thick cooling system, which was already convincing on the Asus GeForce GTX 1080 Ti Strix (test) .
Because while the reference card goes under load loudly, the version of Asus manages to remain very quiet even in games. From a closed case the strix under load is hardly heard and the quiet competition with GeForce GTX 1080 equals.
The performance-per-watt ratio is slightly better
Asus did not like the graphics card: The Radeon RX Vega 64 Strix is even a bit faster than the reference design of the Radeon RX Vega 64 (Test) and is in the case somewhat smaller selection of games with an overclocked GeForce GTX 1080 equals. This also creates the reference design with a maximized Power Target, but an abnormally high volume is generated.
Another reason for the quiet cooling with high performance next to the radiator is the third good news: The power consumption has hardly increased compared to the reference model at 100 percent Power Target. It remains high, but the performance per watt ratio is slightly better compared to the reference card.
Final Partner Cards at the end of September
Even though it will be a final evaluation of the graphics card only on the basis of a final version, to ensure that it also corresponds to the model in the trade, the first impression of the Radeon RX Vega 64 Strix is very positive. What will it cost? Asus did not say anything.
Whether the model of Asus will be superior to the other partner cards, including those of the usually strong AMD exclusive partners PowerColor and Sapphire, must also show up. Probably towards the end of September, a test of several partner cards will also answer this question.
Vega je jednostavno brza karta od GTX 1070
Ne znam zašto svi toliko potenciraju to, kao da beži od 1070 ne znam koliko. Bukvalno zavisi od igre. Evo testa u 25 igara (više no bilo koji drugi review):
https://www.youtube.com/watch?v=lQCal8t-qvQ
U pola njih je brža Vega, u pola 1070. Kad se sve sravni, Vega generalno beži manje od 10%...u realnim ciframa, to je u većini slučajeva bukvalno nekoliko frejmova. Šačica frejmova manje od Vege mi ništa ne znači kad u gro igara izvlačiš 80-100 fps. Da se mašina muči da izvuče 40fps, tih 5-6 bi značilo nešto...Da li je neko voljan da žrtvuje vrelinu i potrošnju struje zarad nekih 8% više FPS u odnosu na 1070? Ja ne bih. Opet, zavisi od toga koje igre najviše igraš.
Za nekog poput mene, ko ne igra AAA igre i mahom igra starije stvari, NVidia je bolja kupovina jer manje pravi probleme u starijim igrama, manje mi opterećuje napajanje i hlađenje u kućištu i tiša je.
BTW, ne zanosite se da će Vege mogu da se nađu po prvobitnim cenama, od toga nema ništa. Kad se AMD smiluje da ubrza proizvodnju i popuni zalihe, koštaće po 100$ više (i to u SAD, kod nas možemo samo da nagađamo). A što se samih zaliha tiče, i to je čupavo jer za sada HMB2 memoriju pravi samo Samsung (šuška će da će početi i Hynix) i to ide sporo, pa im se može da nadrukaju cenu (a i sama proizvodnja nije jeftina). Zbog slabe proizvodnje a velike potražnje, prodavci će takođe da nadrukaju cene (kao što smo videli). Plus, tu su mineri koji će verovatno da obrste Vegu 56 (za Vegu 64 nisam siguran jer guta previše struje), tako da...
Slazem se ti 10% nije velika prednost, ali vecina ljudi muci svoje karte klokuje da bi dobili toliko ubrzanje, ti 10% koliko je VEGA56 brza znacajnije je nego neka potrosnja koja je kod Vege veca.
Sto se tice cijena tu smo vise puta diskutovali sve ce ovisiti o miningu ako bude manja zainteresovanost rudara onda se moze ocekivati i stabilizacija cijena u protivnom dok je ovakva ludnica nema nista od realni cijena, nazalost!
@jurodivi
Matematika i zvrcka je jasna: niko normalan nece uzeti referentne krsine koje su skuplje a iste ili malo slabije u igrama od nereferentnih out-of-the-box blago oc modela GTX1070/1080. 🙂
