Windows 10 Insider Program
  • Začetnik teme Deleted member 46590
  • Datum pokretanja
D
Guest
Announcing Windows 10 Insider Preview Build 16241 for PC & Build 15230 for Mobile
https://blogs.windows.com/windowsex...41-pc-build-15230-mobile/#mOLcloFfh3gFF9xT.97
What’s New in Build 16241 For PC
Windows Shell Improvements:
Recover your pin and password from the lock screen: Self Service solutions empower end users, unburden helpdesk/IT admins, and save organizations money. Cloud Self Service Password Reset (Cloud SSPR) has been a really popular Azure AD Premium (AADP) feature and now we want to take this great capability one step further – Windows Integration. If you’re using an AADP or MSA account and you find yourself stuck at the login screen, you can now reset your password and PIN straight from here. Just click the “Reset password” (for password) / ”I forgot my PIN” (for PIN) link and you’ll be prompted to go through the AAD or MSA flow to reset it. Once reset, you’ll be returned to the login screen where you can login with your newly minted credentials.
Itd. itd.
Ovde mozete na miru diskutovati o Insider programu i Preview verzijama.
Crossposting,flejm,prozivke,etiketiranja: momentalni perma ban.
Unapred zahvalan
Ja sam imao do skoro pre 2~3 builda Insajder ali kada sam video da sa svakim novim buildom sve gore i gore ne radi mi ni Chrom ni Mozila a na zadnji onda nisi mogao ni da preimenujem ni fajl jer pucketa winexplorer ne znam kako to objasniti ja ga batalio potpuno mi je bio neupotrebljiv. Sada ne znam kakvo je stanje niti me mlogo interesuje. Mnogo oni to komplikuju a dobre funkcije su izbacili one sa fontovima sad se to mora pomoću reg fajlova rešavati.....jednom rečju crap.
Ma daj bre, na toj mašini sve mora da radi ko' sat. Jedine probleme koje sam imao sa insider build-ovima je da se po neki teže instalirao.
Meni se od update na novi build pojavljuje da će da mi licenca uskoro istekne. Gledao sam Msoft support ali nisam našao kako da sredim ovo.
Licenca bi trebalo da je digital i da je vezana za moj Msoft nalog? Imam samo opciju da unesem product key. Da li negde u Msoft nalogu mogu da dobijem key za trenutni insider build koji imam?
Sta ti pise pod Activation ? Jel ovako = bez obzira dal si nainsajderu ili na stable, insajderima je win legalica, ja menjao jedno 3x plocu sve je cool i dalje.
Isto tako i meni piše, ali me zbunjuje ovo što iskače da će uskoro isteći. Nekad baš iritira, Inače je 1703 a 16241.1001 build
Kako da ubijem ovo što mi iskače?
Izlazi novi build mozda i za sat vremena...
Sent from my Nokia 5
Evo instaliram sada, samo da napravim ISO prvo jer posle je kasno.
Vidi, vidi sve radi kako treba mada je uzelo sat vremena.
Imao sam danas neke random restarte i to dok je komp bio u idle ... sad vidim nema One Drive-a u tool baru, reci mi koja ti verzija One drive-a?
Odradicu mu ddu i sveze gpu drajvere pa cu pratiti dal ce i dalje pucati.
Evo opet ..
A juce sve bilo cool.
One Drive je 17.3.6955.0712, ako nije, ažuriraj preko Store-a.
Pa to mu piše u About na njemu, nego si me ti podsetio da ga updete-ujem a pre toga je bio samo 17.23 broj.
I nek vam je Bog u pomoć...
:eyebrows: za par godina odlazi mis u zaborav ...
HDD matori mi rusi win10 insajder , sta da radim, sad sam ga skinuo sa molexa i sata i sve ok sa sistemom... pre toga skidao je neka dva filma i pri chekiranju fajlova rusio sistem,, takodje bas dosta je lampica bila crvena , tj onak status za ucitavanje tj aktivnost hdd-a na kucistu.
HDD jeste mator ali radi, nema bad sektora itd ...
prihvatio si eula...
bas je random, nekad radi nekad ne... mora da ga je zbunio nesto win aero tweaker, nisam trebao da tweakujem w10 , iovako je doteran za korisnika.
Bez poznatih bugova? Je li ovo RTM?
iskljucio sam telemetriju, da li mogu da updateujem insider tako ili da ukljucim telemetriju pa opalim update?
