Vegeta
Cenjen
Vega Architecture Key Features
– 4x Power Efficiency
– 2x Peak Throughput/Performance Per Clock
– High Bandwidth Cache
– 2x Bandwidth per pin
– 8x Capacity Per stack (2nd Generation High Bandwidth Memory)
– 512TB Virtual Address Space
– Next Generation Compute Engine
– Next Generation Pixel Engine
– Next Generation Compute Unit optimized for higher clock speeds
– Rapid Packed Math
– Draw Stream Binning Rasterizer
– Primitive Shaders
AMD’s Raja Koduri Confirms Vega 10 Die Size At 484mm² – RX Vega To Be Faster In Gaming Than Frontier Edition
http://wccftech.com/amds-raja-kodur...e-rx-vega-gaming-cards-july-launch-confirmed/
na stranu performanse koje ce l0ogicno biti vece meni je interesantna povrsina od 484nm2 koja ostavlja mogucnost za jos jaci chip u okviru 14nm procesa.
That Monero hash rate is very impressive. Basically your Vega FE is twice as profitable mining Monero as a GTX 1080Ti mining Ethereum.
If RX Vega behaves the same, jesus miners will take them all.
FE nije od tog lika vec privatno od minera koji testira za komapanije.... kaze da bez undervolta karta nenormalno trotluje a jos nije nasa nacin kako to da odradi jer je bios dosta redizajniran i power play sekcija istog je duplo veca
