Evo ovde linka za daljinski, ali bi mogli i ostali da se nađu.Ovo bolje ?
https://forum.xda-developers.com/showthread.php?p=64950939#post64950939
Neko poređenje - https://forum.xda-developers.com/showpost.php?p=69205239&postcount=622
Daljinac (AOSP QuickRemote) - https://forum.xda-developers.com/lg-g2/themes-apps/port-lg-quickremote-aosp-mm-g2-g3-t3302437
Koji dajler koristiš? Google ili neki drugi?Ako neko moze neka mi posalje linkove na pm, ne mogu to da nadjem.
Inace na AOSP ne radi knock code, tj nema te opcije nazalost.
Probaj nadji drajvete za g2..te prethodne izbrisi
LG Mobile support tool pa od nule sve ...
.................i to sam probao,ali kad krene izbaci da telefon nije prikljucen na usb.....
Probaj preko otg da ubaciš flash sa snimljenim fajlovima za flešovanje. Treba ti otg kabl za to. Kad povežeš ideš u mount pa otg.usao sam u recovery ali ne mogu da ubacim ni jedan rom za flesovanje zato sto nece da ga mountuje.Zna li neko kako da ubacim fajlove?
Može da se namesti sa Nova prime.Ako neko moze neka mi posalje linkove na pm, ne mogu to da nadjem.
When installing certain custom ROMs on rooted Android smartphones or tablets, you will encounter “Status 7″ error issues once in awhile with TWRP.
Status 7 error is caused while the ROM’s updater script file checks to see if the phone model of your phone is compatible with the ROM you are installing, called “asserts”.
“Asserts” is a safety mechanism so you don’t accidentally install another phone model ROM on your phone. E.g. You tried to install Galaxy S2 ROM on a Galaxy S3 and ending up hard-bricking your phone but you got Status 7 error which saved you.
Now, this safety mechanism is great but there are times where even if you have the correct ROM for your phone, you will get Status 7 error.
This is due to an error by the developer of the ROM in the updater script, causing havoc.
Čovek ne misli na double knock, već na knock code.Može da se namesti sa Nova prime.
Poslato negde iz svemira
U pravu si, moja greška[emoji16] To ne može da se namesti.Čovek ne misli na double knock, već na knock code.
Šta li si ti to zeznuo ...
Ako imaš usb koji se kači na telefon - to ti je najlakše rešenje
Prebaci rom na usb, onda mount USB-OTG u TWRP rikaveriju i dalje znaš...
Nema to veze sa samim nugatom nego sa skriptom ...
Ukratko :
Ništa strašno, otvori se zip-rom fajl, (može i sa winrar programom) obriše se par redova, sačuva i to je to![]()
Installation Instructions
-Flash Bootstacks According to your variants from https://forum.xda-developers.com/lg-g2/development/boot-g2-hybrid-bootstacks-t3183219
- Download the latest build 23. 12. 2016- RR 7.1.1 Nougat D802 Official- http://www.resurrectionremix.com/d802/Nougat/RR-N-v5.8.0-20161223-d802-official.zip
- Download Gapps - http://opengapps.org Odaberite ARM pa 7.1 i nano paket.
- Take a nandroid backup
- Recommended - Full wipe and factory reset
- Flash ROM using latest TWRP recovery
- Flash Gapps
- Wipe dalvik cache
- Wipe Cache
- Reboot.
- First boot will take a while...be patient, it will boot
- Enjoy!
Ima gore sve napisano ...
Ne vidim nigde gde pise sta treba da se brise,na ovom videu je prikazano za drugi rom.....na xda pise da se instalira
CAF bootstack,a ovde pricaju da se brise nesto?Sta sad,koji je laksi nacin?
Rut - https://forum.xda-developers.com/lg-g3/general/guide-root-lg-firmwares-kitkat-lollipop-t3056951
TWRP rikaveri za Lollipop (stara verzija) - https://apkpure.com/d802-lg-g2-autorec-lollipop/b007.autorec2
TWRP rikaveri (zadnja verzija) - https://forum.xda-developers.com/lg-g2/development/twrp-twrp-2-8-0-0-kernel-f2fs-tools-t2898705
Skine se zip i samo flešuje iz postojećeg rikaverija.
RR 7.1.1 Nougat D802 Official - http://www.resurrectionremix.com/d802/Nougat/RR-N-v5.8.0-20161223-d802-official.zip
Google Apps - http://opengapps.org
Odaberite ARM pa 7.1 I nano paket.
Kome izbaci ERROR 7 prilikom flešovanja roma u TWRP rikaveriju ima uputstvo i objašnjenje u prethodnim komentarima.
Meni je izbacio error i vec sat vreena cekam da mi neko kaze sta treba da se obrise,posto video koji je postavljen nije za RR,tako da ne znam sta treba da se obrise?Hvala
assert(getprop("ro.product.device") == "d802" || getprop("ro.build.product") == "d802" || getprop("ro.product.device") == "g2" || getprop("ro.build.product") == "g2" || getprop("ro.product.device") == "galbi" || getprop("ro.build.product") == "galbi" || getprop("ro.product.device") == "d800" || getprop("ro.build.product") == "d800" || abort("E3004: This package is for device: d802,g2,galbi,d800; this device is " + getprop("ro.product.device") + "."););
Ideš na advanced wipe I ostaviš otkačeno internal storageuradim full wipe,ali ako uradim i factori reset onda mi brise sve iz elefona,ukljucujuci i backup i instalaciju ,ako krene po zlu.Jel mora taj factori reset da se radi?
Sta na kraju ne radi? Double tap ili sta? Bez toga ne koristim telefon, naviko sam se.U pravu si, moja greška[emoji16] To ne može da se namesti.
