Aj' što su rekli da Polaris karte stižu na leto, nego se i na slajdu vidi da je tačno na sredini 2016![]()
http://wccftech.com/amd-polaris-sweet-performance-per-dollar/Polaris, the company’s impressively power efficient next generation 14nm FinFET graphics architecture was naturally front and center. With a demo showing Polaris 10, an enthusiast class GPU, running Hitman Absolution at 60 FPS, 2560×1440 in DX12. This is the second of two Polaris GPUs that AMD will be bringing to the market this summer. The first being Polaris 11, a very small, very power efficient GPU that was demoed at CES 2016.
With Polaris confirmed to use GDDR5, Vega is notable for being the first AMD architecture to use HBM2, and the first parts in general to use HBM tech since Fiji. I’m presuming these are higher-end GPUs to complement the Polaris GPUs (the smaller of which we know to be a low-power laptop design), which is where HBM would be more cost-effective, at least at current prices.
Ovo mi izgleda isto kao Tonga -> Fiji plan, tj. Vega nije ništa novo, samo duplo više svega od Polarisa i HBM2![]()
I da je dele uz Ariel umesto CD-a Zdravka Čolića
E za 200e ni ja ni ti to necemo dobitibar ne jos tamo nekad 2018 mozda a ove i naredne godine sigurno ne.
Dobro,
kolko sam vido', bice i jedna kartica iznad, znaci ovo nije fullchip, onda bi znaci trebala biti nesto brza od Furise.
Ali, meni tu nista nije jasno, :lupko:,
ako pogledamo one nezvanicne podatke o specifikacijama Pascal kartica, gde ce nalsednik 980Ti karte, sigurno biti brzi za nekih, minimalno 30-40%, a full Pascal chip ce biti jos i vise od Titanceta ( jer su po specifikacijama 980Ti i TitanX vrlo blizu) i kad dodamo koliko je samo 980Ti trenutno jaca od FuryX karte, onda to, ovako na prvu loptu i ne deluje nesto obecavajuce, sto se tice te neke konkurencije izmedju NV i AMD..
Ajd, to su tek prve nezvanicne informacije, mozda ce da bidne i da se prvi macici baca...u vodu, ce' vidimo, ali, s obzirom da NV planira najjace chipove da izbaci tek mozda sledece godine, ne bi me cudilo i da bude ovaj scenario...
