I tako... dosao je i taj dan, kada je i Kopernikus poceo da stavlja korisnike iza NAT-a.Net uzasno lose radi ovako.
Pogledajte prilog 192467
Izvini da li možeš nešto konkretnije da objasniš, ne razumem baš najboljehvala
Jedino što vredi pogledati su vesti od 19 i 22h, ostatak programa je klasično smaranje, uz izuzetak emisija kao što su pressing koju vodi Ćosić i poneki dokumentarac političkog tipa.
ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=28 ttl=54 time=15.4 ms
64 bytes from 8.8.8.8: icmp_seq=29 ttl=54 time=16.9 ms
64 bytes from 8.8.8.8: icmp_seq=30 ttl=54 time=15.0 ms
64 bytes from 8.8.8.8: icmp_seq=35 ttl=54 time=20.4 ms
64 bytes from 8.8.8.8: icmp_seq=36 ttl=54 time=20.9 ms
64 bytes from 8.8.8.8: icmp_seq=37 ttl=54 time=17.6 ms
64 bytes from 8.8.8.8: icmp_seq=38 ttl=54 time=16.1 ms
64 bytes from 8.8.8.8: icmp_seq=39 ttl=54 time=24.7 ms
64 bytes from 8.8.8.8: icmp_seq=40 ttl=54 time=16.3 ms
64 bytes from 8.8.8.8: icmp_seq=41 ttl=54 time=17.0 ms
64 bytes from 8.8.8.8: icmp_seq=42 ttl=54 time=19.3 ms
64 bytes from 8.8.8.8: icmp_seq=43 ttl=54 time=17.1 ms
64 bytes from 8.8.8.8: icmp_seq=44 ttl=54 time=17.9 ms
64 bytes from 8.8.8.8: icmp_seq=45 ttl=54 time=15.7 ms
64 bytes from 8.8.8.8: icmp_seq=46 ttl=54 time=15.8 ms
64 bytes from 8.8.8.8: icmp_seq=47 ttl=54 time=16.8 ms
64 bytes from 8.8.8.8: icmp_seq=48 ttl=54 time=15.0 ms
64 bytes from 8.8.8.8: icmp_seq=49 ttl=54 time=17.1 ms
64 bytes from 8.8.8.8: icmp_seq=50 ttl=54 time=17.1 ms
64 bytes from 8.8.8.8: icmp_seq=51 ttl=54 time=16.2 ms
64 bytes from 8.8.8.8: icmp_seq=52 ttl=54 time=16.8 ms
64 bytes from 8.8.8.8: icmp_seq=53 ttl=54 time=17.7 ms
64 bytes from 8.8.8.8: icmp_seq=66 ttl=54 time=16.3 ms
64 bytes from 8.8.8.8: icmp_seq=67 ttl=54 time=17.7 ms
64 bytes from 8.8.8.8: icmp_seq=68 ttl=54 time=16.5 ms
64 bytes from 8.8.8.8: icmp_seq=69 ttl=54 time=18.6 ms
64 bytes from 8.8.8.8: icmp_seq=70 ttl=54 time=20.8 ms
^C
--- 8.8.8.8 ping statistics ---
70 packets transmitted, 27 received, 61% packet loss, time 69026ms
rtt min/avg/max/mdev = 15.039/17.552/24.701/2.106 ms
Ovo je prevrsilo svaku meru. I juce i danas internet ne moze da se koristi, packet loss ogroman. Izgovor "tehnicke podrske", je da ne mogu da uticu na to i da sam jedini koji se zali na te probleme iz tog IP pool-a (ima nas 91). Naravno kad ostale boli dupe, jer samo gledaju fb i yt, pa i nema veze ako net radi lose, nista ne gube. Evo dokaza za packet loss:
Zivim u Cupriji. Imam internet i kablovsku preko kopernikusa. Uzeo sam set top box preko kopernikusa. I do pre par dana sve je radilo normalno i bilo je nezavisno jedno od drugog,internet od digitalne televizije. Sada se desava sledece. Kad internet radi punom brzinom prosto je nemoguce pogledati bilo sta na kanalima preko digitalizacije. Kad internet radi na minimalnom rezimu rada,dakle npr.samo da se citaju neke vesti ili osvezava neka stranica,nebitno,ponovo kanali seckaju,preklapaju se boje i tako dalje i tako duze i nemoguce je gledati nijedan tv kanal. Napominjem da je do pre par dana sve radilo normalno,cak sam i skidao neke stvari sa neta maximalnom brzinom i signal na digitalnom set top boxu i na svim kanalima je bio savrsen izmedju 100 i 90 procenata kvaliteta. Sada kada se nesto skida na netu signal pada do 20 procenata i prosto je nemoguce pogledati bilo koji kanal koliko koci. Pre par dana je nesto radjeno i od tada se sve poremetilo. I sada je ovako lose vec nedelju dana iritirajuce je stvarno,pustis nesto da se skida sa neta ne mozes da gledas televizor,kraj price. Pre par dana su nesto cackali , palili – gasili ko zna sta je radjeno,cas imao signal pa nije pa opet jeste pa nije i od tada haos zivi. Tako je i kod komsije koji ima isto kao i ja,sve isto,net i digitalizaciju. Sta je to u pitanju i sta da uradim da se to vrati na staro ? Internet koristim preko onog Cisco rutera a digitalizaciju preko akcije sam uzeo set top box dvb-c ono kad su davali pre par meseci itd. Ocigledno nije do mene,jer je sve radilo kako treba i savrseno je bilo do pre par dana. Hvala drugari na mogucim odgovorima.
Ja se bas razmisljao da predjem na kopernikus kablovski sa telekom box adsl-a... ali kad vidim koliko se ljudi zale...
Isao sam u poslovnicu i pitao ljude kako radi kod mene u gradu, ubedjuju me da radi ok i da ima neke manje normalne prekide, ali kao bolji je nego adsl.... ne znam da li da im verujem...
U Smederevu od rano jutros nema Interneta, telefoni su im svi pogaseni, u bgu automat se javlja samo da bi ti nabijao racun i skidao minute. Zlo..
Ja imam isto veliki packet loss, verovatno je svima tako. Sve je OK ostalo ali njihova podrska je nikakva. Ali bolji su od ADSL-a, bolje da izaberete nekog drugog provajdera, po meni SBB je najbolji ali ja nazalost nemam uslove za SBB.
