LG G5
Šumadinac
Banned
Banovan
Red je da se otvori ova tema pošto G5 dolazi početkom sledeće godine, a već postoji dosta informacija o novom modelu G serije...
Jedno je sigurno - konačno prvi LG flagship telefon koji će biti kompletno izrađen od metala !
Očekivane specifikacije:
Metal unibody construction
5.6" True HD IPS 4K display
20 MP Sony lens that has a width of 1/2 an inch / 10MP front camera with iris scanning technology
Snapdragon 820 processor, which is set to be a beast of a SoC with a 8-core & 14nm process
3GB/ 4GB of RAM
32, 64, and 128GB versions with Micro-SD slot for storage expansion
An Eye or fingerprint scanners
4G, NFC, 802.11ac Wi-Fi, and Bluetooth 4.0.
4000 mAH battery & Qualcomm Quick Charge 3.0 Technology. This tech allows the battery to be charged to 85% full capacity in just 35 minutes.
No price specs have leaked yet, but as the LG G5 is LG’s flagship, it’s going to cost a lot.
Ne volim metalne telefone i ne svidja mi se sto bat nece biti lako zamenjiva,ovo ostalo ok 🙂
Tako su procenili, a i konkurencija je nametnula 🙂
Baterija manje više, ali microSD slot ako ostane biće dobro...
LG G5 will feature a 5.6" screen with a 1440 x 2560 resolution. The Snapdragon 820 SoC will be under the hood, containing a quad-core CPU, and the Adreno 530 GPU. There will be a 21MP camera on back, along with an 8MP front-facing camera. LG G5 has been rumored to feature a Finger Print Scanner as well as Iris Retina Scanner.
The LG G5 is expected to be unveiled in February 2016.
http://www.phonearena.com/news/Rumo...clude-SD-820-SoC-and-21MP-rear-camera_id76518
Za sada idealno, još samo da bude metal i pun pogodak ! 🙂
Meni su za sada Sony i Huawei Nexus prvi favoriti za sledeći telefon posle G3 ali ako se pokaže da vredi i ne bude imao problema možda i ostanem u LG taboru mada meni hardver i nije toliko bitan.
Više mi znači zvanična softverska podrška koja kod androida i dan danas nije na nivou iOSa
Pa ok je LG sa softverskom podrškom - G4 među prvima ima v6.0...
Osim toga radi multitasking kako je predviđeno za razliku od samsunga.
I oni ubrzali.. Ranije su cekali par meseci posle galaxy S serije a sada idu prsa u prsa 🙂 bice zanimljivo..
Nadam se samo da ce se vratiti bezelima sa g2,g3.
Samo metal i minimalne ivice 🙂
Za kameru ne sumnjam da će biti ok...
Meni ni note 4 nije veliki 🙂
Pomisli tek kako je azijatima koji su sitnije građe...
Pa imaće uskoro i on v6.0...
Sigurno pre konkurencije 😉
Jedino je Motorola možda bolja što se tiče toga, ako ne računamo Nexus uređaje...
Moja braća imaju 5.5" telefone, kum iP6+ i kažu da im ni najmanje ne smeta veličina, verovatno su navikli poput tebe i mnogih drugih, ispada da je sada prosek ta dijagonala. Ja mislim da ne bih mogao, imam 8" tablet ako mi zatreba veći ekran za multimediju, za telefon mi je sve preko veličine G2 preveliko. Čak mi je i Xperia Z3 koju ima kolega nezgodna za korišćenje jednom rukom, pošto ima velike ivice oko ekrana. Ispada da si osuđen na Samsung ili jabuku ako hoćeš manji flagšip
a g3 koju verziju ima?
Za nedelju dana ide 6.0 na njega
Slazem se sa striderom. Ako ne mogu da ga koristim 1 rukom bolje da ga ni nemam. Ali ocito je malo nas takvih u ovom svetu,***
5.6" je meni idealno, nikada ne bih kupio telefon manji od 5" npr.
Vidite i sami šta su Apple sektaši pričali godinama o idealnoj veličini telefona pa su se na kraju predomislili 😀
Sad je na redu da u narednom periodu uvedu vodootpornost (mogu da se kladim) ...
Sony ima prevelike ivice i ne sviđa mi se kao ni HTC, ostalo sve dolazi u obzir 🙂
Note 4 ima 5.7", a prema ovim najavama G5 će biti 5.5-5.6 inča.
Ovo treba da ubace u telefone... Nadam se što pre... 🙂
Po meni glavni problem i mozda i jedini a kada je rec o Lg telefonima je IZGLED njihovog skina, znaci samo IZGLED. Po meni ubedljivo najruzniji android skin na planeti. Sve ostalo je odlicno, na svaku velicinu telefona mogu da se naviknem sa note4 nisam imao problema, preko toga mislim da ne bih mogao. Nadam se da ce g5 imati velikog uspeha.
To je već stvar ukusa, a i Google now / nova launcher su tu 😉
LG UI je doneo i mnogo korisnih opcija koje se tek sada uvode na nekim telefonima...
Ma to njihovo "uskoro" godinama slusam...prvo od HTCa posle od Samsunga sad od LGja...svi osim lg g3 su imali 5.0.2 ili 5.1 gde su ispravljeni bagovi samo LG nista...i 6.0 sad kad dodje ima garantovano nesto da ukake i onda ce kao ispravljati 6 meseci i na kraju nece ni ispraviti...ostavice g3 na bagovitoj 6ici jer ce navodno da bude "zastareo"
Tvoja opsednutost ajfonom ne fascinantna, ne moze covek da procita neku temu a da ti ne pises o istom.Koliko puta treba da te banuju da bi se dozvao pameti.I jos jedna stvar, koga interesuje sta je za tebe idealnna velicina i sta bi ti kupio.
Simpatično 🙂
Od svih ovih komentara samo 2 su bila u "zabranjenom" delu foruma...
Ti od 6 jedan već omaši 😀
Temu o veličini telefona zna se ko je godinama potencirao ...
Veruj mi da je samsung mnogo gori, ako ti je to za utehu ...
Ako nisi zadovoljan LG telefonima onda ti jedino preostaje Nexus 6P ili neka Motorola (mada ih retko ima kod nas, skupi su telefoni i teško ih je prodati kasnije)
SnapDragon 820 - LG G5 dolazi sa njim - http://www.anandtech.com/show/9837/snapdragon-820-preview
Samsung nikada nisam uzimao u razmatranje prilikom kupovine telefona.
Imao sam službeni S3 i sada majci što sam uzeo J5 i to je sve što se tiče samsunga.
LG je sa G2 poboljšao tu podršku i zato sam mislio da će nastaviti i sa G3 međutim nije i zato sam skeptičan po pitanju G5....
A kao što rekoh za sada Sony i 6p su prvi pikovi kada dođe vreme za zamenu 😉
Sa sonijem i firmwerima ces tek da se usrecis!!
Što? Pa jedni su od retkih koji imaju 5.1, čak su i na xperiji z odradili taj update ako se ne varam. Gde su S4 i one M7 iz tog perioda... Zaglavljeni na 5.0.
A što se G2 tiče, telefon je izašao avgusta 2013, ima 5.0 iz tamo negde novembra 2014, ako ne puste bar 5.1 to je truba podrška a ne za pohvalu, period malo jači od godinu dana je smešan.
Ume Proday ''malo'' da drami sa tim znacima !!! i da pretera ali je u slucaju Z5 serije ipak u pravu, ti telefoni su izbaceni sa nedovrsenim sw i nisu radili brzo/dobro kao sto se ocekivalo mada je ovaj poslednji apdejt u speed testovima Z5 stavio tu negde u rang sa Nexusom 6P ali ipak nije to ta fluidnost kao na 6P (+ svi pomenuti sa S810 ispastaju pri vecem opterecnju zbog tog cipseta).
Dok je za ostale Z podrska malo sporija ali generalno odlicna, cela Z serija iz 2013 (3 telefona i tablet) su dobili 5.1.1 sto je mozda i jedini takav primer van Nexus linije, noviji Z telefoni rade odlicno a i 6.0 koncept obecava jer je izgleda jos blizi stock-u.
Od G5 stvarno ocekujem mnogo jer ce ocigledno ispraviti skoro sve (uglavnom manje) mane G2 i G4 (G3 ne racunam uopste), evo npr G4 mi je odlican telefon ali cak ni za 350e me bukvalno nista ne vuce da ga kupim iako radi brzo i ima odlicnu kameru. Da ima autonomiju kao G2 ili bolju mozda bih i razmislio.
Od G5 ocekujem da LG dodatno ispegla UI (mada su male sanse da ce biti primetno ociscen od bloat-a), da autonomija konacno bude u rangu sa G2 (moze i bolja, zasto da ne) i da izrada/dizajn konacno budu par koraka napred u odnosu na G2 tj ''premium'' (bez krckanja i pucanja plastike kucista). Naravno i da zadrze sve prednosti G4 (brz, fluidan UI, kvalitetan IPS panel i kameru).
E u tom slucaju stvarno mogu da razmislim o prelasku na LG jer ce sigurno (ponovo) biti najjeftiniji po oglasima, to je odavno tradicija na nasem trzistu i u tom slucaju G5 bi vrlo lako mogao da ponovi pa i da nadmasi uspeh G2 na Balkanu.
Vojkane ne samo po meni, vec i po gomili drugih na sony forumu, novim firmwerom poprave jedno, a pokvare 3 druge stvari. Ja recimo nikada nisam hteo da predjem sa 4.4.4 na Lp dok sam nosio z3c upravo zbog toga. Takodje vrlo cesto izbacuju nedovrsene firmwere (iako su svesni greske da postoji oni furaju glavom kroz zid), pogotovo sada sa celom z5 serijom (koja do duse ima i hardverskih problema boga oca)...tako da mi to nista ne znaci sto su izbacili najnoviji softver kad ga posle krpe 6 meseci, a ja za to vreme izgubim i volju za zivotom, a kamoli telefonom. Generalno ni ostali nisu bolji (samsung na primer upropastio lowlight fotke na n4 i s5 prelaskom na 5.x itd). Vidim hvale sad ios 9.2 da je konacno dobar tj verzija kakva je 8mica trebala da bude, nesto se razmisljam da se vrnem u ios vode, sumnjam da je baterija na ip 6+ veci ocaj od ove na n4!
^ 5.1.1 radi stvarno odlicno, kako ce biti sa 6.0/6.x videcemo.
Meni LG G5 i Nexus 6P prve opcije...
S7 neću iz principa posle iskustva sa Samsung softverom, podrškom, a i ne sviđa mi se staklo nazad, cena, exynos...
Tako je svojevremeno izbor bio između LG G2 i LG Nexus 5 i odlučio sam se za prvi - ni malo nisam zažalio...
Uvek se potencira ta baterija na G4, a meni koji sam sa Z3 presao na G4 baterija ne predstvalja nikakav problem, telefon isto koristim kao i Z3.
