4k video
  • Začetnik teme Začetnik teme a c a
a c a
Uticajan
Laptop
HP 8570p
Mobilni telefon
Realme 8
Pristup internetu
  1. Kablovski internet
Skinuo sam neke semplove 4k materijala i pokušavam da pustim na mojoj mšini ali mi ne polazi za rukom. Da li je mašina slaba ili nisu dobra podešavanja? Probao sam mpc, mpc-hc, mpc-be, vlc, pot player, jriver. Evo informacia o fajlu:
General
Unique ID : 232254923168972859310530153164683978656 (0xAEBAABCEEE07596C9B2F54359381A7A0)
Complete name : D:\Temp\Big.Buck.Bunny.4K.UHD.HFR.60fps.FLAC.WEBDL.2160p.X264_ZMachine.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 851 MiB
Duration : 10mn 34s
Overall bit rate mode : Variable
Overall bit rate : 11.3 Mbps
Movie name : Big Buck Bunny - ZMachine
Encoded date : UTC 2015-01-21 21:20:46
Writing application : mkvmerge v7.4.0 ('Circles') 64bit built on Dec 12 2014 12:19:56
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Attachements : Big_buck_bunny_poster_big.jpg
_STATISTICS_WRITING_APP : mkvmerge v7.4.0 ('Circles') 64bit built on Dec 12 2014 12:19:56
_STATISTICS_WRITING_DATE_UTC : 2015-01-21 21:20:46
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
DURATION : 00:10:34.125000000
NUMBER_OF_FRAMES : 7432
NUMBER_OF_BYTES : 257265141
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 10mn 34s
Nominal bit rate : 8 000 Kbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.016
Title : Video H264 [email protected] (4K UltraHD - HFR 60 fps)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=8000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Default : Yes
Forced : No
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 10mn 34s
Bit rate mode : Variable
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Title : Audio FLAC 5.1
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Default : Yes
Forced : No
Ovo mu dodje 4K 60fps? Veliki je to zalogaj za taj procesor...
Ne bi mogla, dekoder koji ima taj GPU ne podržava 4K rezoluciju. Ne možeš da pustiš glatko ni 4K@30FPS.
Ako je samo zbog 4k@60 videa onda ok. Mada nema puno ripova u toj rezoluciju.
A treba ti i ogdovarajući TV ili monitor. A pošto je 60fps nisam siguran da bi hdmi kabl to izdržao.
4k jeste next big thing ali je još uvek rano za upgrade.
Ipak može na sličnoj konf, ali 30fps. Prvo instaliraj ffdshow (i 32-bit i 64bit) a onda u mpc-hc isključi interni dekoder (options/internal filters/transform filters/ uncheck-iraj H264/AVC). Interni dekoder je mono thread, ne može da izgura. Sa ffd-om dobijam 30fps sa oko 50% CPU zauzeća, tako da pretpostavljam da bi mogao krajnjom snagom da izgura 60, samo trenutno ne mogu da nađem nijedan 60fps clip. AKo ti nije teško baci neki link da probam.
Možda po tehnikalijama i nije, ali ne može da angažuje više od jednog jezgra pri dekodiranju AVC, pri čemu ne uspeva da izgura pun fps. To se zove single thread, bez obzira kako su ga oni deklarisali.
U MPC-u kao decoder izaberi EVR i verovatno će raditi i na tom Athlonu svih 60fps glatko.
Na procesoru iz potpisa radi 4k@60fps bez problema (ne dropuje frejmove ni malo). Doduše, taj Bunny ima samo 8000Kbps bitrate, s toga i nije baš neki pravi pokazatelj 4k videa.
edit: sad ću da probam jedan 4k@30fps na oko 40Mbps
Izgleda. Ne obratih pažnju dovoljno. 🙂
Doduše, prvih par minuta je zauzeće GPU-a malo (do 5%) i tek kasnije se povećava do 45%.
Kad ide sve preko CPU-a?
@60FPS taj sa 8000 kbps ili @30FPS od 40Mbps?
MPC-ov fps pokazivač zna da vara. Kad prebacim na EVR (sa dotadašnjeg EVR custom pr.) zaista pokazuje pun frame rate, ali clip opet secka tamo gde je i pre seckao, i dalje koristi istu CPU snagu- 1 jezgro. Kad prebacim na ffdshow decoder, vidno je "glatkije" a cpu raste na 50%.
@peja
CPU je na 100% kontantno. GPU ide od 5 do 45% paralelno za ovaj 4k@60fps. Sad probah i ovaj 4k@30fps 40Mbps i slično je. CPU 100%, GPU oko 20%, nema seckanja.
Biću afk jedno sat vremena, pa kad se vratim ću da čačkam još malo (i ovo što dragg reče).
Ma nije problem toliki bit rate, nego 4K rezolucija, jer te stare (i slabe) graficke nemaju upotrebljivost, i sve ide na procesor.
Jedino da proba da menja te video rendere u plejeru...
@peja
Proveri u MadVR-u da li imaš dropped frames (Ctrl-J dok gledaš 4K). Tvoja grafa može kompletno hardverski da odradi 4K tako da možeš da oboriš zauzeće CPU-a na minimum.
Pejo, nije bilo dropova. 🙂
Ovo dole izgleda da je kombinacija koja najmanje opterećuje sistem.
MadVR i LavFilters. Tokom upaljenog 4k klipa, desni klik unutar MPCHC x64 prozora, LAV Video Decoder, Hardware Decoder (DXVA2, copyback) i štiklirati 4k ispod.
4k@50fps na 87.5 Mbps radi bez seckanja.
4k@50fps na 280 Mbps radi bez seckanja.
Sve h264 klipovi i naravno ovo je sve skalirano sa 4k na 1080p. CPU ide do 50% isto i GPU.
edit: postaviću na Google drive ova 2 4k klipa (po 10s oba traju, oko 500MB zajedno).
Imaš 1337x, uglavnom su pornjave ali provuče se poneki drugi 2160p.
Sad sam probao jedan clip na 8Mbps. Ide glatko preko ffdshow decodera ali ne uspeva da izvuče 60fps sve vreme. Ima ok 5% ispuštenih frejmova tj. postiže oko 57 fps u proseku. Ipak je dovoljno glatko i gubitak se ne primeti.
Aco, jesi li probao dzonijeve klipove? Ovaj moj i3 sa HD2000 (EVR-CP) nije dorastao zadatku.🙂
Promeni renderer (na EVR) ili odradi ono gore što rekoh za MadVR. Pejo, probaj i ti MadVR sa onim podešavanjem. Meni je cpu usage prilično spao kad sam namestio LAV Decoder.
Ne bi mogla nikako HD2000 da se izbori sa 4K resize-om. Ne podržava ni 4K kardversko dekodiranje (ipak je to Sandy) pa sve ide preko CPU-a. A stoji mi LAV naravno.
Samo, čini mi se da bi sa tvojom kartom CPU usage trebalo da ide još niže. CUVID je CPU zahtevniji?
Pejo, izvini što ne odgovorih ranije. 🙂
CUVID je sličan što se tiče zahtevnosti, kvalitet slike takođe. Za par časova (dok se skinu) ću da probam jedan 4k@50fps na 275 Mbps i jedan od 372 Mbps.
Isto. Dok je štikliran 4k ekran je zelen, kada nije onda je po starom, seckanje.
