Čim smislis javiNemam g4 ali imam ideju kako flashati, echoone mi je blizu(ne znam jel kući sad) pa da navrati da probamo. Tako da je nedokazano još.
Kakvih još novina ima ajde pričaj još malo - vabi nas da kdz-ujemo [emoji1]Prvi utisak je da je skoro sve istovecina promjena je ispod haube, tako da sad primijetih ovo trazenje da se odobri npr. pristup plfotografijama kod nekih apps, drugaciji je copy/paste meni, za potrosnju apps sad pise i procjena koliko je mAh potrosio. Flappy Bird klon je i dalje tu, samo malo izmijenjen (uspio sam konacno da ga proguram kroz jednu :-D )... Neocekivana prednost toga sto sam dobio tel za poljsko trziste :-D Instalirao sve legalno, preko LG Bridge-a
To back up his point, he lists dozens of new features that are coming to Marshmallow that should have Android users excited. Here they are:
• Now on Tap
• Permissions Management
• SD Cards can be “merged” with internal storage
• Android Pay
• Native fingerprint authentication
• Automatic app data backups
• App Links (you’re going to see less of those “what do you want to open this in?” prompts)
• Doze and App Standby
• Multi Window(currently hidden, uncertain future)
• Theming support(currently hidden, uncertain future)
• Dark theme(removed, uncertain future)
• Customisable Quick Toggles along with other UI tweaking
• Visual Voicemail Support
• Redesign of the Clock Widget and Music Identification Widget
• New “Memory” Section in Settings(it was there before, but hidden)
• Support for deleting screenshots directly through the notification centre after they’ve been taken
• Landscape mode available for the Google Now Launcher(feature will likely be backported to older versions of Android)
• New app and widget drawer with scroll bar support and vertical scrolling
• Built-In File Manager receives a bump in functionality
• Native tap to wake support
• Ability to disable “heads up” or “peeking” notifications
• Native 4K output support
• Stricter APK validation
• MIDI support
• USB Type C support
• New boot animation
• Introduction of a “voice interaction” API to allow better interaction with voice actions in apps
• Toggling battery saver by voice
• Ability to undo and redo text changes with bluetooth keyboard shortcuts
• Multi-selection to merge, delete or share has been added in the contacts application
• Faster text selection along with a floating toolbar for text actions
• Default apps UI
• Direct share can allow you directly share stuff with contacts through the share menu
• Much more granular app info
• Native bluetooth stylus support
• Split-screen keyboard
• Mobile radio active bug will be fixed
• Better do not disturb along with repeat caller exceptions
• Bluetooth scanning to improve location accuracy
• Native flashlight API
• Easier access to Multi volume controls(ringer, media, alarm)
• Smoother volume scrubbing
