Ne snima ih na SD karticu zbog lolipopa i dozvola u lolipopu.gde snima slike slikane sa Lg xcam za G3 nigde ih nema a namestio sam na SD karticu
So hopefully that LG G4 will be receiving Marshmallow sometime before the year ends. As for other devices from LG that are due to receive their Marshmallow update, this includes the LG V10, LG G Flex 2, LG G3, and the LG G2. With the LG G4, the company's current flagship phone, getting it faster, it then becomes a slow trickledown after that.
It is probably a safe prediction for later versions of LG devices not receiving Marshmallow updates until Q1 2016. This is following a model based on last year's slow rollout of Android 5.0 to the LG G3, which was then the LG flagship of 2015 before the LG G4 was announced last April.
It is good that the G2 will be receiving Marshmallow after all,
A koji rom koristis? Ja ceo dan na 3G, ne mogu da izvucem 2.5h SoT... Osvetljenje mi je na auto 50%, gps off...evo slika ekrana, ovo je pola na 3g/4g ostatak je na WiFi
Pogledajte prilog 181872Pogledajte prilog 181873
Napraviš backup u TWRP, prebaciš na kompjuter ili cloud, obrišeš ako ti smeta (biće sigurno oko 5G), kad se zaželiš vratiš unazad i ne gubiš root i TWRP. A može i kdz.Trenutna verzija softvera mi je stock V20u-TWN-XX.
Ako mrčkam nešto, odnosno menjam rom, recovery, itd. jel mogu da vratim na stock tako sto cu da flešnem D85520U.00.kdz, koji sam direktno skinuo sa LG servera odavde:
http://csmg.lgmobile.com:9002/csmg/b2c/client/auth_model_check2.jsp?esn=XXXXXXXXXXXXXXXXX (ovo xxx se menja sa IMEI i tako se skine poslednja verzija kdz-a)
Resurecttion RemixA koji rom koristis? Ja ceo dan na 3G, ne mogu da izvucem 2.5h SoT... Osvetljenje mi je na auto 50%, gps off...evo slika ekrana, ovo je pola na 3g/4g ostatak je na WiFi
@Cvexkeks: ili ja tebe ne razumem, ili ti mene nisi lepo razumeo :-DNapraviš backup u TWRP, prebaciš na kompjuter ili cloud, obrišeš ako ti smeta (biće sigurno oko 5G), kad se zaželiš vratiš unazad i ne gubiš root i TWRP. A može i kdz.
Instaliraj sa marketa NextAppSD fix aplikaciju i resite ce ti taj problem.
Neka te ne buni sto pise KK...radi i na LP
meni i jeste kitket 4.4.2
https://mega.nz/#!bA8RkZBY!yxhElf7cIlzmtjBuzzNHettdLlu0nX6_GJ-tcD8GIS4Jel moze neka preporuka za neki rom/kernel da moze da izvuce 5h+ sot?trenutno sam na cloudy 2.5 i mogu negde oko 4h sot,ali bi ja to jos malo da poguram..
Takodje ako moze pomoc,NIGDE ne mogu da nadjem AndroidNow HD rom bukvalno sam ceo net pretrazio.To mi je bio omiljeni rom.Jel ima neko mozda zadnju verziju..
da li je neko isprobao ovaj rom, komentari?
To sam i ja mislio, a pukotine? Uzimaju li to pod garanciju?
