Dropcoin [DROP] (DropLP)
Technical Specifications / Information
Proof-of-Work Mining Algorithm: DropLP
Blocks 0 - 160: Reward increases linearly from 0.0 - 10.0 coins.
Block Time: 61 Seconds
Transaction Maturity: 12 Blocks
Coinbase Maturity: 161 Blocks
Block halving occurs every 172,328 blocks (approximately four months).
Estimated time until block reward reaches zero: 7 1/4 years (roughly 87 months)
Total coins mineable: ~3.62 million +/-5%
Proof-Of-Knowledge (PoK) Mining*
tl;dr When a block is mined with PoK enabled, the block reward is increased by a certain percentage. For Dropcoin the bonus is set at ten percent.
Wallets
Official Windows 64-bit: Standalone v0.10.2 | Installer v0.10.2
Official Windows 32-bit: Standalone v0.10.2 | Installer v0.10.2
Official Linux 64-bit: v0.10.2
Official Linux 32-bit: v0.10.2
Official Mac OS X: v0.10.2
Official Android: pending
Official iOS: pending
Official Source: Git Repository
Mining
With the Qt wallet: Open wallet and click on the Mining tab
or
With daemon: dropcoin-cli setgenerate true
ccMiner Source: Git Repository
ccMiner Windows: ccminer.zip
cpuminer source: Git Repository (curtesy of kernels10)
Note: cpuminer currently does not work with PoK and is not significantly faster than the in-wallet miner. In other words, unless you see a hashing speed increase of over 10% you are better off mining using the wallet with PoK enabled.
To mine using cpuminer or ccminer, your dropcoin.conf file needs to contain:
rpcuser=someusername
rpcpassword=somepassword
rpcport=29019
rpcallowip=127.0.0.1
server=1
usepok=0
daemon=1
Replace "someusername" and "somepassword" with whatever you like.
The 'rpcport' parameter is optional and will default to port 29019 if not set otherwise,
and 'rpcallowip' should be replaced with the IP address of the computer running cpuminer.
To run cpuminer on *nix based systems:
./minerd -o 127.0.0.1:29019 -u someusername -p somepassword
To run cpuminer on windows:
minerd.exe -o 127.0.0.1:29019 -u someusername -p somepassword
To run ccminer on *nix based systems:
./ccminer -a drop -o 127.0.0.1:29019 -u someusername -p somepassword
To run ccminer on windows:
ccminer.exe -a drop -o 127.0.0.1:29019 -u someusername -p somepassword
Pools
Suprnova's DropCoin Pool // Algo: Drop // Pre-Reg now, waiting for CPU Miner !
Block Explorers / Richlists
Block Explorer hosted by CryptoBE.com
Development / Roadmap
(in no particular order)
Website
Block Explorer
iOS Wallet
Android Wallet
Secret Item #1
A real roadmap
Some type of master node implementation
Mining Pool(s)
Catch up with the latest Bitcoin Core code
[ more to come ]
Services & Exchanges
alcurEX
sad nesto nece da mi se konektuje ovaj novi miner.Nisu nista trebali da diraju,em manje daje em nesto zeza konekcija
urekao si ga sa temom 😛
samo da ne prodje lkao qubit ahahahaha :d
Vredi kupiti par hiljada komada, cisto da se nadje. 🙂
ja sam iskopao vec par hiljada komada da se nadje.....
Ne znam ali znam da deva nema vec 4 dana. Vidim da su juce neki kukali.
Lepo je DEV ranije rekao ne moze svaki dan da kucka jer ima i druge obaveze, cim su jednom kukali da ga nema 2 dana.
Lepo sve funkcionise i ide svojim tokom. Aplicirao je i na par drugih menjacnica.
Kopaju samo nvidie i za sada samo preko wallet-a ide, tj. ne znam da su napravili pool.
ne moze nista da se iskopa sa nvidiama angazovao sam 5x jacu snagu od cpu-a i opet je manje coina iskopano u odnosu na cpu, tek sad ide kilavo kad je mreza porasla...
vidim i kod mene kao da radi u prazno a mreza porasla, imam 200 komada sad cekam cenu :d
nesto mreza ne raste? raste pa se vrati i tako u krug
Ja nisam nista mogao da iskopam, pa sam nesto kupio. Da li neko ima ideju koliko je ovoga vec iskopano (mozda oko 350 000?) I koliko kopate dnevno i sa cim. Ja sa nekoliko procesora nisam za citav dan uhvatio niti jedan blok.
sa kojim kopas, nesto ti ne valja, ja sa fx8350 na 80%, iz waleta kopam i danas i juce po 3 bloka ubodoh
i7 4770k od juce 100 Drp
wallet stoji upaljen a kopa se iz programa minerd.exe
Hvala, sporo ovo nesto ide, sad je pametnije da se kupi izgleda.
@nnikola, koliko imas ukupno kh?
jel kopa jos neko sa fx8350 koliko mu daje
vidis sa slike 4 threda po 8.8kh /s . ovako iz waleta kad se kopa mislim da je ukupno 22kh a ovde iz minera.exe imas 4 x 8.8=35khs
onda je bolje iz mineraja imam oko 20 pa zato pitah
gde skidate minerd, ima samo opvaj cc
meni izbaci "json_rpc_call failled" i "HTTP rewuaest failled" nesto ne radim kako treba
ok hvala nesam video :d
wtf ???
E ovde sam imao prezadnji. Ali opet mi pripisalo 400. Ne racunam onih 462
Možebiti fork. Ako imaš negde stari blockchain, "isprobaj" ga. Ili kopaš sa jedno 50-tak CPU-ova. 😀
Stavi zadnji.
Probaj da prodas a ako uspe javi da i mi uradimo isto 😛
Aj kad ste vec ovde, json rpc failed gresku imam i ja kao kolega iznad, zna neko.sta je problem?
