Trebalo bi da ima jedan Gigabyte-ov model i kod nas www.monitor.rs/maticne-ploce/gigabyte-ga-f2a88xn-wifi-rev30
Što nisi napisao rešenje? Ili misliš da ako si ti našao nikome neće trebati?Nasao resenje i mega glupa fora al ajd.
Final manual overclock was stable at 4.5GHz and 1.4885 Vcore, 1280Mhz GPU and memory pushed to 2400MHz but timing loosened to CL12. This was completely stable under prime95, AIDA and OCCT but for some reason a single launch of BF4 would crash instantly or even running Firefox would freeze screen (as mentioned in the notes above). Instead of lowering the GPU OC, I decided to move back down to the AMP settings of the memory at 2133 MHz and was able to run all games and benchmarks without issues.
Da li moze 7850k da se klokuje na a55-bm e ploci do 4ghz?
