GTA V
da li moze neka grupa/klan da se napravi na steamu? dodajte me kexi95
Ovaj njihov editor je zanimljiva alatka.
[YOUTUBE]8ITAnNzj-zg[/YOUTUBE]
Usudio se neko staviti ove nove amd-ove beta drajvere?
Koga bude zezao download ili nece da ceka ima ova varijanta:
If your download from R* is shit, use this method and just get everything from MEGA:
Source:
http://www.reddit.com/r/GTAV/comments/328e2u/gta_v_rockstar_preload_is_broken/
This is confirmed working: If you haven't made much progress downloading the stuff, use fast download using MEGA link: https://mega.co.nz/#F!N91DxBLJ!mO4qwYEfgcq4hPXUqlEdsA You have to download all RAR files in order to unpack it.
Unrar password: "www.intercambiosvirtuales.org" (without quotes)
Otherwise, search for a torrent that offers the same files if you only need some of the setup files.
INSTALLATION
If you used the MEGA files, unrar them first using the password.
After that, place all files in c:\Program Files\Rockstar Games\Grand Theft Auto V
Run GTAVLauncher.exe. It should see that the download is finished and it will proceed with the setup.
You can test to remove a file from the directory (for instance /x64/metadata.dat). The download manager will download that file. After that you see this: https://dl.dropboxusercontent.com/u/21558454/GTA wachttijd.png which means the download is finished. That is what I did.
Problem je u tome sto sam ja cuo kao da kada bude 1:00 da ce da se skida jos neki dodatn sadrzaj oko kao 5GB e onda ce da bude ****no jer mi je konekcija 500-700 Kb/s (bila je kada sam skidao) onda cu nekoga da koknem...
ima ja mislim da se skine jos oko 300mb...
Odbrojavamo....
koja je fora kada je disk verzija u pitanju? Steam, Origin, nesto trece?
53 MB downloada... koji jek renuo lepo a sada skida 10 kb/s...
Da evo muci se bas kod mene 50 MB :/ i stalno rstart server lost 32 kb uzas
Uzas kako ce ovo raditi sve restartuje pa opet pa :S
hahahaa *** 53 MB pa skine skoro do kraja ostane 0.4 MB pa server lost pa tako u krug vec 3 put ...
10 min treba za unpakovanje igre, mogu misiti vama na HDD-u, trebat ce minimum 40 min xD
Sporo, sporo... meni se još nešto zakucao launcher na pola, morao sam da ga gasim u task manager-u.
I ušli smo :)
Ovo ce moci izgleda normalno tek sutra...zakucani serveri...na twitchu 200.000 ljudi..nikome ko strimuje jos nije krenulo..
...Bas me interesuje nakon par dana kada objave preliminarne rezultate zarade kolika ce biti :)
Cenim da ste vi "Stimaši" bolje prošli
na twitchu najranije za 11 min neki lik....ostalo mrka kapa...
edit: ovaj je sa stima sto ceka 11min
