Ja sam ga imao 11-og kod mene, nego nisam hteo da leak-ujem [emoji14]Ha ha ha, Djilkosh Tarot, promašio samo za dva dana 🙂
I HTC je ok 🙂Pa lepo piše da je jedino Samsung ispravio memory leak
"I'm almost certain that other Android 5.0 Lollipop ROMs may have the same problem (except for Samsung's Touchwiz - Touchwiz uses qmg format and I was unable to reproduce this bug on Touchwiz)," states the developer.
Samsung's TouchWiz is the only ROM which has fixed this issue.
A kad mozemo ocekivat, update preko telefona?Sto znaci da polako mozemo da ocekujemo od Lolipopa da radi normalno. 😀
