HTC One M9
Da, jesam ***** [emoji24] pretpostavljam prednja strana i zadnja u istoj boji ...
Bilo bi super kad bi prednjai zadnja strana bila iste boje, npr golden/golden tj da mu se displej prisijava u golden boji, kao oni dvogledi :)
http://www.phonearena.com/news/Snap...wards-the-Samsung-Galaxy-S6-and-LG-G4_id64567
A trio of J.P. Morgan analysts from South Korea claims that the Snapdragon 615 and 810 processors are overheating, with the problem being especially present in the latter, whose Cortex-A57 cores reportedly heat up excessively when their frequencies go past the "barely there" 1.4 GHz stage and enter "performance beast" mode. According to Geekbench results, this causes a "serious throttling problem" that severely limits graphics performance. In addition, the 810's clock rate was reported as lower than the current generation Snapdragon 805, and memory controller problems were present as well.
Thus, the analysts believe that Qualcomm and manufacturing partner TSMC will have to delay production by a quarter, spending an additional month prototyping and re-designing metal layers on the chip, and an additional two completing the final product's metal layer mask. This means the chip won't be in circulation until May 2015 at the earliest. This is quite concerning, as the report claims that both the upcoming Samsung Galaxy S6 and the LG G4 will be using the Snapdragon 810. This is hardly surprising, but it shows how the industry will be impacted by Qualcomm's inability to deliver the processor on time.
Kalva su to djubrad ja nemam reci.. Sta bih dao da ih mediatek pregazi
HTC's next One flagship smartphone set to launch on March 1st
Slažem se :)
Verovatno hoće jer je qhd ekran ostavljen za onu hima ultru koja će šatro imati i senzor za otisak prsta
Jos kada ni izbacili i malo manju verziju sa 4.6-4,7'' 720p ekranom a da sve ostalo bude isto i bar 2600 mAh.. to bi bio pun pogodak (bar za nas koji necemo phablet).
To nema šanse, a da ne smanje i spec. za soc, ram, itd.
Kad bi još neki proizvođač izbacio konkurenta z3c-i...
Šteta što su se vratili na nabudžene megapixele... Trebalo je da unapređuju ultrapixel tehnologiju, ali su to morali da urade još na M8
Da su uspeli nekako da izvuku 10UP to bi već bilo nešto. Ovako kud svi tu i mi..
Pa da su nabili toliko "ultrapixela" to bi bio senzor kao u 808 u najmanju ruku :D
Ok je i 4-5 mpx, veruj da su oni na htc kameri najmanji problem :)
Ali onda ne može da snima 4k video. Nije to to :)
Snapdragon 810, kamera od 20mp i sve ostalo identicno kao na m8 je vec skoro pa savrsen telefon. Ali ako budu smanjili okvire a zadrzali iste dimenzije i kvalitet zvucnika to bi bila definicija savrsenstva. Za vecinu. :)
Ta kamera treba da bude i krštena a ne samo da ima 300 megapixela, ako budu bio "veliki" senzor i ručne kontrole valjda se uključe konačno u trku sa Samsungom
Ručne kontrole su pod moranje. Novi ui plus android 5. Očekujem ga u top 5 Android kamera.
Ako već moram da pravim listu ;)
1.s6
2.m9
3.g4
4.z4
5.note 4
To se valjda podrazumeva :d
Ne mora kamera da bude najbolja na trzistu, neka bude i medju top3 android kamera a ostatak telefona ce izvaditi konacnu ocenu.
da naravno. samo nek dođe u taj krug uređaja gde odlučuju nijanse i super je. ovo do sad je bilo baš drastično ispod konkurencije.
Da ,ovo je prototip.neki lik sa xda ga je imao u posedu i bukvalno ga opisao kao na ovoj slici.ogromna kamera i isti oklop kao m8
Ovo je napisao pre 15dana.
"looks very close to M8 but cleaner lines, camera has a little hump, sensor is about quarter size
I hope this is just a decoy cuz if the phone comes out like this
this gotta be the most disappointed iteration of One line up
I was kind of expecting a huge design changes
I ovo:
<i>"The screen will be the same size as the M8. Single camera on back, huge sensor on back, the module looked like a size of a quarter. Front camera looks like a 8mp camera, the screen has same bezel on bottom, but less bezel on left and right side.power button is placed on the right side under the volume button. It basically looks just like a m8."
neće valjda opet ova brushed konzerva...
Meni prednja strana tog proto. M9 deluje malo blize M7 nego M8 sto je dobro. Mada je ta zaobljenost slicna kao na M8. A za bezele me zabole, ko se lozi na bezele od 1mm ima LG i slicne, htc sve to opravdava sa (za telefon) sjajnim zvucnicima, bitniji su hw/sw od minimal bezela.
Ako bude stvarno ovakav jedino sto mu zameram je crna htc traka dole.
Jes malo ruzno ovo oko kamere pozadi. Mada bitno da je ulaz za sluske sa donje strane :)
Po meni je ovo 95% mob kog ce predstaviti 1og marta
