sgminer 5.0 je u pitanju ( 4.2.2 )
Ne jos prvo da se ja malo obogatim![]()
haha ok ajde idemo redom
xintensity 3
tc 8192(al nije toliko bitno)
g 2
worksize 256
kernel https://ottrbutt.com/tmp/neoscrypt.cl
14.6 rc2
sgminer: https://ottrbutt.com/sgminer/neoscrypt/sgminer5-neoscrypt-11-02-2014.zip
Evo uploadovoao sam bin da ne morati instalirati catalyst ponovo: https://www.dropbox.com/s/v33ei6mki141tx9/neoscryptTahitigw256l4tc8192.bin?dl=0
nemoj ko da mi se sa ovim kaci na ufo coin ujedam
I naravno ukoliko se ko obogati
FTC: 6gtMTcP8QLScgqyQivU4dj3becYVAKVuDc
Sgminer.exe -k neoscrypt -o stratum+tcp://stratum.wemineftc.com:4444 -I 12 --worksize 256 -g 2 -u mikica.1 -p 1 --thread-concurrency 8192
Sve si okacio samo nisi .bat, mogao bi.haha ok ajde idemo redom
xintensity 3
g 2
worksize 256
14.6 rc2
Evo uploadovoao sam bin da ne morate instalirati catalyst ponovo: https://www.dropbox.com/s/v33ei6mki141tx9/neoscryptTahitigw256l4tc8192.bin?dl=0
@majsta napisao si intezitet 3. Kad stavim to dobijam 40 khs. Kad stavim 12 dobijam nesto preko 260 khs
Evo ga moj bat. Probao na asus 280x 1100/1500 13.12 drajveri
Tnx, tvoja podesavanja sljakajuEvo moja podešavanje za 280x,radim preko moba ovo pa je malo nezgodno hahaha
"xintensity" : "3",
"worksize" : "256",
"algorithm" : "neoscrypt",
"lookup-gap" : "2",
"thread-concurrency" : "8192",
"shaders" : "0",
"gpu-threads" : "2",
"gpu-engine" : "1050",
"gpu-fan" : "60",
"gpu-memclock" : "1500",
"gpu-memdiff" : "0",
"gpu-powertune" : "0",
"gpu-vddc" : "0.000",
"temp-cutoff" : "95",
"temp-overheat" : "85",
"temp-target" : "75",
"api-mcast-port" : "4028",
"api-port" : "4028",
"expiry" : "120",
"failover-switch-delay" : "60",
"gpu-dyninterval" : "7",
"gpu-platform" : "0",
"log" : "5",
"no-pool-disable" : true,
"no-client-reconnect" : true,
"queue" : "1",
"scan-time" : "60",
"tcp-keepalive" : "30",
"temp-hysteresis" : "3",
"shares" : "0",
"kernel-path" : "/usr/local/bin"
https://www.dropbox.com/s/yk0mhb2rdp812ye/sgminer5-neoscrypt-11-02-2014.rar?dl=0
Spakovan miner, promenite workera u .config i to je to. Takodje ako ste imali tesno podesene napone, s ovim minerom ce vam trebati mrvicu vise.
ma nije ni ovo ok, treba sajber da ide po gajbama da instalira miner
ni slučajno neko da se pomuči da nešto čačne podesi otkrije sam itd...
meni ovaj miner nikako ne radi, ni pre kad je okačen a ni sad. samo zatvori prozor pre nego što uopšte krene. jel radi nekom ko ima 13.12 drajvere ili ste svi na nekim novijim?
Jesam, na kraju sam uzeo i komplet sajberov miner i opet ćorak.Jesi stavio ovaj bin sto je kacio majsta, meni radi na 13.12
i stavi pauzu na kraju pa vidi u cemu je problem..
