1Coin [ONE] | First 3S PoW Hashing Combo
xdbitcoin
Cenjen
Nesto sasvim novo videcemo sta ce biti na berzi kad izadje daje lepu brzinu a temperatura i potrosnja smanjeni testiram na R9 270X kartici i daje 4.400 Mh/s
sgminer 4.1.0 - Started: [2014-10-27 12:37:29]
(5s):4.467M (avg):4.455Mh/s | A:10 R:0 HW:0 WU:0.062/m
ST: 1 SS: 0 NB: 78 LW: 19704 GF: 0 RF: 0
Connected to Pool 0 (stratum) diff 0.031 as user xdbitcoin.r9
Block: 3df75fcc... Diff:223 Started: [15:28:46] Best share: 4.564
[P]ool management [G]PU management ettings [D]isplay options [Q]uit
GPU 0: 52.0C 3411RPM | 4.462M/4.456Mh/s | R: 0.2% HW:0 WU:0.062/m I:19
[15:28:03] Accepted 0906262b Diff 0.111/0.016 GPU 0
[15:28:08] Accepted 15d28fd4 Diff 0.046/0.016 GPU 0
[15:28:19] Accepted 2728d1e7 Diff 0.026/0.016 GPU 0
[15:28:23] Pool 0 difficulty changed to 0.031
[15:28:23] Accepted 215bc8b0 Diff 0.030/0.016 GPU 0
[15:28:23] Waiting for work to be available from pools.
[15:28:23] Work available from pools, resuming.
[15:28:23] Accepted 384a25f0 Diff 0.018/0.016 GPU 0
[15:28:46] Stratum from Pool 0 detected new block
[15:28:46] Accepted 05b28c6e Diff 0.176/0.031 GPU 0
[Website]
http://1coin.eu/
Official Support Thread @ Bitcointalk.org
https://bitcointalk.org/index.php?topic=820302.0
[Specifications]
Stable Litecoin fork with minor enhancements.
15.15 Coins per block (.15==0.99%: dev fund)
100% Proof of Work
3 confirmations for each transaction
Total Coins: 21 Million ONE (~20M in 2029, ~20.6M in 2050)
Total Blocks: inifinity
PoW Algorithm Combo: 3S (shavite, simd & skein) with a ~40% speed increase and ~15% power decrease compared to X11(AMD HD 7950)
2 minute block time
DigiShield difficulty retarget
Dificulty retarget every 2 blocks with a max difference of 5%
140 confirmations for blocks to mature
Block halving every 680.000 blocks (~2.5 year)
Certified software engineer working in system engineering
No IPO
No Premine (Actually 2 blocks to make sure everything is OK)
No Instamine
~0.99%/block to dev fund for 1Coin.eu costs (e.g. bounties, hosting, marketing, development)
3S CPU & OpenCL GPU miner For both ATI & Nvidia Graphic cards
Binaries4Everyone: Static wallet, cpuminer3s & sgminer3s binaries for Microsoft Windows, Mac OSX and Linux.
Network port: 1998
RPC port:1997
[3S Benchmarking]
AMD HD 7950 [i=19]
X11 ~2.7 MHash/sec ~175W
3S ~4.5 MHash/sec ~150W
imam 25 komada zakasnio sam za sam start...prestao sam da ga kopam jer vidim da sami ljudi koji su kreirali coin ne daju nikakve novosti...ne pricaju ljudima koji su planovi ...sta dalje...zato je i mreza znatno pala...nece ovaj coin daleko ...mozda cak i ne vidi menjacnicu....vidim da se i diff prepolovio od juce
daj da i ja nesto novo probam ;)
ima fazon za miner -skini prvu verziju brza je... ona sto je precrtana na pocetnoj strani i moras da obrises sgminer.conf da bi miner radio
za 280x 7.4mhs
color 0b
setx export GPU_MAX_ALLOC_PERCENT=100
setx export GPU_USE_SYNC_OBJECTS=1
sgminer3s.exe -o stratum+tcp://one.maxminers.net:9012 -u x -p x -I 19 -w 256 --thread-concurrency 8193 -g 2 -o stratum+tcp://one.suprnova.cc:2323 -u x -p x
malo sam drugacije napravio
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
COLOR 0A
del *.bin
sgminer3s -k 3s -o stratum+tcp://one.suprnova.cc:2323 -u zile74.1 -p 1 -I 18 -g 2 -w 128 --thread-concurrency 8193 --gpu-powertune 20
ne znam sta je razlika u "setx" i "setx export"
Ne moraš ni jedno ni drugo, posle prvog puta ti parametri se upisuju u registry i ostaju tamo dok ne promeniš Windows
