LG G2
Где скидате тај xcam? Јел може неки линк.
Rutovao sam telefon uspesno ali kada sam hteo da instaliram recovery pise da je uspesno instalirano.i kad hocu da butujem pojavi se lg logo i gore u levom cosku pise nesto boot error..el ima neko resenje?
Ja imam isti problem i telefon je promenuo tri servisa, nijedan nemoze da resi kvar. Naime ja sam rutovao tel i telefon je preko noci apdejtovao nesto. Kad sam ga restartovao izbacivao mi gresku
boot certification verify
Secure booting error!
Cause: boot certification verify
Nisam mogao ni u Downloda mod niti u recovery. Windows ni linux ne prepoznaju telefon, tj. kad se zakaci na usb samo izbacuje neke greske. Sistemi prepoznaju neke particije od 16mb, 120mb ali nista sa njima ne mozes da uradis. Ukoliko imas isti problem probaj na ovom linku da uradis nesto ako mozes http://forum.xda-developers.com/showthread.php?t=2582142
CHANGELOG for 2.8.0.0:
-Add MTP support to recovery thanks mostly to bigbiff with a little help from Dees_Troy
-Add command line capabilities - you can now execute various TWRP features via adb instead of the touchscreen
-Add support for color in the console and give error, warning, and highlight lines different colors
-Track backup and restore progress based on file sizes to provide a much more accurate indication of progress
-Improve handling of /misc thanks to mdmower
-Improve setting of time on Qualcomm devices thanks to [NUT]
-Allow using images on slidervalue GUI objects thanks to Tassadar
-Allow using variables and addition and subtraction in variables for easier theming
-Add support for 1440x2560, 280x280, and 320x320 resolutions and update 240x240
-Allow ui.xml file to include additional xml files to help break up the theme and make TWRP easier to maintain
-Other minor fixes and improvements
Over the course of the last year or so, bigbiff has worked to migrate various Java functions from Android's MTP implementation to bring you a fully C++ based MTP implementation that allows you to transfer files to both emulated storage and Micro SD cards. It's confirmed to work on various Nexus devices but we may have to make some changes on other devices to keep Windows happy. Windows is very picky about USB IDs and its drivers. We have tested it on Windows 7 and 8 as well as Ubuntu 14.04 Trusty. MTP is enabled by default, but we do toggle it off and on automatically during certain operations such as if you choose to wipe a storage partition. You can enable or disable MTP under the mount menu in TWRP. For more about what MTP is here.
Note: Due to a weird bug with our MTP setup, you cannot copy a zip file to the root of storage with Windows. You can change the .zip to something else like .txt and then copy it to the root and rename the file back to .zip once it's copied to the device. You can also copy the zip into any subfolder.
Command line support is also now available. You can perform various OpenRecoveryScript commands via the adb shell. Depending on what you are doing you may wish to do a "twrp set tw_mtp_enabled 0" and then reboot to prevent the MTP auto toggle from killing your adb interface. You can use this option to create and restore backups, wipe, install zips, and more. Via adb shell, type twrp followed by a space then enter the OpenRecoveryScript command and hit enter. Find more OpenRecoveryScript commands here.
TWRP 2.8.0.0 odličan !!!
Download - http://techerrata.com/browse/twrp2/g2d802
Nova Motorola Moto X, odlicna zamena za G2, po meni ispravlja najveci nedostatak ovog telefona, a to je ekran. Moto X ima AMOLED, a metal je samo slag na torti, tako da vlasnici G dvojke, batalite trojku i da predjemo svi u Moto bandu. :D
Inace, me zanima da li Cloudy rom ispravlja nedostatak koji je dosao sa Kit Ketom, a to je neverovatan lag ekrana, prilikom primanja poziva, ranije toga nije bilo, nazalost.
nikakva motorola trenutno nemoze da zameni moj g2
Moze se srediti. Unbrickao sam garant 20tak g2 uredjaja..najmanje 20
Taj link ce brickati totalno i one koji su brikani :)
Da da, skineš samo zip i flešneš, ponudiće ti da obrišeš dalvik i cache (odradi to) i posle samo reboot to recovery...
Treba da ti piše 2.8.0.0 ;)
Ima na xda resenje. Radi se preko linuxa. Ubace se i zamene pogresni fajlovi.
Novi dorimanx kernel 7.5. U kombinaciji sa Viperom zvuk na slušalicama je nešto najbolje što sam ikada čuo. Od ovoga ne može puno bolje.
Kakav je zvuk u slušalici tokom razgovora? Da li je to sredio?
Nisam još probao preko slušalice telefona, uglavnom razgovaram preko slušalica.
U changelogu piše da je ubacio nešto iz faux sounda, što bi trebalo da je za zvuk tokom razgovora.
Probaj da povećaš gain u stweaks-sound-handset.
Edit: Sad videh da je to podešavanje samo za mikrofon.
Može se pojačati pomoću aplikacije faux sound.
SGS II star 4 godine, preziveo pakao i tezak maltret 24/7/365..Ispadao, leteo, udaran.
Zasto ovo pisem? Pa zato sto je ekran navedenog telefona danas u PEFREKTNOM stanju, bez i jedne jedine ogrebotinice.
LG2..star ni mesec dana...malopre pronasao ogrebotinu na ekranu. :wall:
zastooo? zastooooo? :-( :-( :-(
To što je na sgs II, je možda isto ko na iPhone 2g, tj. nema oleophobic coating. Ono što vidiš je ogrebotina po tom sloju, ne po staklu. Moj prastari iPhone nema ni jednu ogrebotinu na ekranu :D
Sorry za off topic.
Koji imas os? Daj buold.prop da pogledam malo
cloudyG3... evo bpro mada ja koliko videh lge d802 sto bi trebalo da je ok...:-( :-(
# begin build properties # autogenerated by buildinfo.sh ro.build.id=KVT49L.A1406613943 ro.build.display.id=KVT49L ro.build.version.incremental=1406613943 ro.build.version.sdk=19 ro.build.version.codename=REL ro.build.version.release=4.4.2 ro.build.date=Tue Jul 29 15:18:23 KST 2014 ro.build.date.utc=1406614703 ro.build.type=user ro.build.user=cloudyfa ro.build.host=phantom ro.build.tags=release-keys ro.product.model=LG-D802 ro.product.brand=lge ro.product.name=g3_global_com ro.product.device=g3 ro.product.board=MSM8974 ro.product.cpu.abi=armeabi-v7a ro.product.cpu.abi2=armeabi ro.product.manufacturer=LGE ro.product.locale.language=en ro.product.locale.region=US ro.wifi.channels=11 ro.board.platform=msm8974 # ro.build.product is obsolete; use ro.product.device ro.build.product=g3 # Do not try to parse ro.build.description or .fingerprint ro.build.description=g3_global_com-user 4.4.2 KVT49L.A1406613943 1406613943 release-keys ro.build.fingerprint=lge/g3_global_com/g3:4.4.2/KVT49L.A1406613943/1406613943:user/release-keys ro.build.characteristics=default # end build properties # # system.prop for msm8974 # rild.libpath=/vendor/lib/libril-qc-qmi-1.so rild.libargs=-d /dev/smd0 persist.rild.nitz_plmn= persist.rild.nitz_long_ons_0= persist.rild.nitz_long_ons_1= persist.rild.nitz_long_ons_2= persist.rild.nitz_long_ons_3= persist.rild.nitz_short_ons_0= persist.rild.nitz_short_ons_1= persist.rild.nitz_short_ons_2= persist.rild.nitz_short_ons_3= ril.subscription.types=NV,RUIM DEVICE_PROVISIONED=1 # Start in GWL mode #ro.telephony.default_network=9 debug.sf.hw=1 debug.egl.hw=1 debug.composition.type=c2d persist.hwc.mdpcomp.enable=true debug.mdpcomp.logs=0 dalvik.vm.heapsize=36m dev.pm.dyn_samplingrate=1 persist.demo.hdmirotationlock=false ro.hdmi.enable=true persist.speaker.prot.enable=false # # system props for the cne module # persist.cne.feature=1 #system props for the MM modules media.stagefright.enable-player=true media.stagefright.enable-http=true media.stagefright.enable-aac=true media.stagefright.enable-qcp=true media.stagefright.enable-fma2dp=true media.stagefright.enable-scan=true mmp.enable.3g2=true media.aac_51_output_enabled=true # # system props for the data modules # ro.use_data_netmgrd=true persist.data.netmgrd.qos.enable=false #system props for time-services persist.timed.enable=true # # system prop for opengles version # # 196608 is decimal for 0x30000 to report version 3 ro.opengles.version=196608 # System property for cabl ro.qualcomm.cabl=0 # # System props for telephony # System prop to turn on CdmaLTEPhone always telephony.lteOnCdmaDevice=1 #Simulate sdcard on /data/media # persist.fuse_sdcard=true #system prop for Bluetooth hci transport ro.qualcomm.bt.hci_transport=smd # #snapdragon value add features # ro.qc.sdk.audio.ssr=false ##fluencetype can be "fluence" or "fluencepro" or "none" ro.qc.sdk.audio.fluencetype=fluence ro.qc.sdk.camera.facialproc=false #property to enable user to access Google WFD settings. persist.debug.wfd.enable=1 #property to choose between virtual/external wfd display persist.sys.wfd.virtual=0 # qualcomm sensors debugging property # debug.qualcomm.sns.hal=0 debug.qualcomm.sns.daemon=0 debug.qualcomm.sns.libsensor1=e # System props for audio persist.audio.fluence.mode=endfire persist.audio.handset.mic=digital # LGE CHANGE_S, 2013-02-14, [email protected] persist.audio.voicecall.mic=0 # LGE CHANGE_E, 2013-02-14, [email protected] persist.audio.voice.clarity=none # LGE CHANGE_E, 2013-05-09, [email protected] persist.aanc.enable=false persist.audio.headset_fluence=false # LGE CHANGE, 2013-06-19, [email protected] persist.audio.handset_rx_type=DEFAULT # LGE CHANGE, 2014-02-04, [email protected] use.voice.path.for.pcm.voip=true #// LGE_CHANGE_S, [Net_Patch_0300][CALL_FRW][COMMON], 2012-05-25, Airplane Mode Pop-Up display property value { ro.airplane.phoneapp=1 #// LGE_CHANGE_E, [Net_Patch_0300][CALL_FRW][COMMON], 2012-05-25, Airplane Mode Pop-Up display property value } #System props for vibrator ro.config.vibrate_type=1 # [[email protected]] For Blue Error Handler V1.4 ro.blue_handler.level=0 # LGE_CHANGE_S [g2][framework][common] the screen auto-brightness adjustment setting persist.power.useautobrightadj=true # LGE_CHANGE_E [g2][framework][common] the screen auto-brightness adjustment setting # LGE_CHANGE_S [g2][framework][protocol] persist.radio.add_power_save=1 # LGE_CHANGE_E [g2][framework][protocol] # LGE_CHANGE_S [g2][framework][common] Define HW key led feature lge.hw.frontkeyled=false # LGE_CHANGE_E [g2][framework][common] Define HW key led feature # LGE_CHANGE_S, [WiFi][[email protected]], 2013-01-22, Wifi Bring Up # reserved wifi related property dhcp.ap.macaddress= dhcp.wlan0.dns1= dhcp.wlan0.dns2= dhcp.wlan0.dns3= dhcp.wlan0.dns4= dhcp.wlan0.gateway= dhcp.wlan0.ipaddress= dhcp.wlan0.leasetime= dhcp.wlan0.mask= dhcp.wlan0.pid= dhcp.wlan0.reason= dhcp.wlan0.result= dhcp.wlan0.server= dhcp.wlan0.vendorInfo= dhcp.p2p.dns1= dhcp.p2p.dns2= dhcp.p2p.dns3= dhcp.p2p.dns4= dhcp.p2p.gateway= dhcp.p2p.ipaddress= dhcp.p2p.leasetime= dhcp.p2p.mask= dhcp.p2p.pid= dhcp.p2p.reason= dhcp.p2p.result= dhcp.p2p.server= dhcp.p2p.vendorInfo= init.svc.dhcpcd_wlan0= init.svc.dhcpcd_p2p= init.svc.p2p_supplicant= init.svc.iprenew_wlan0= net.dns1= net.dns2= net.dnschange= net.p2p-p2p0-0.dns1= net.p2p-p2p0-0.dns2= net.wlan0.dns1= net.wlan0.dns2= wlan.driver.status= persist.sys.security= persist.sys.hotssid.ksc5601= wifi.lge.autochannel= # LGE_CHANGE_S, [WiFi][[email protected]], 2013-01-22, Wifi Bring Up # LGE_CHANGE_S Audio_Framework: HiFi Sound # reduce Default minimum length allowed for offload in 30 sec. audio.offload.min.duration.secs=30 # LGE_CHANGE_E # LGE_CHANGE_S [CFW][Memory][[email protected]] Add oomAdj value ro.sys.fw.bg_apps_limit=24 ro.sys.fw.mOomAdj1=0 ro.sys.fw.mOomAdj2=1 ro.sys.fw.mOomAdj3=2 ro.sys.fw.mOomAdj4=4 ro.sys.fw.mOomAdj5=9 ro.sys.fw.mOomAdj6=15 ro.sys.fw.mOomMinFree1=49152 ro.sys.fw.mOomMinFree2=61440 ro.sys.fw.mOomMinFree3=73728 ro.sys.fw.mOomMinFree4=114688 ro.sys.fw.mOomMinFree5=196608 ro.sys.fw.mOomMinFree6=245760 # LGE_CHANGE_E ro.fm.module=BCM # # ADDITIONAL_BUILD_PROPERTIES # ro.build.target_operator=GLOBAL ro.build.target_country=COM ro.build.ui_base_ca=NO ro.lge.global_officialbuild=yes ro.lge.swversion=CloudyG3 1.3 ro.lge.swversion_short=V10z ro.lge.swversion_rev=0 telephony.lteOnCdmaDevice=0 persist.audio.nsenabled=ON persist.audio.spkcall_2mic=OFF persist.audio.spk_sm_fluence=OFF persist.audio.voip_nsenabled=ON persist.audio.nxp=ON persist.audio.fluence.voicecall=true ro.lge.bt_gain_control_factor=0.9 lge.fm_gain_control_factor=0.4 ime_extend_row_keyboard=true ime_onehand_keyboard=true ime_split_keyboard=true ime_theme=true ime_keyboard_layout=ko=QWERTY ime_vibration_pattern=0:20 ro.config.vc_call_vol_steps=6 ro.config.vc_call_vol_default=3 ro.com.android.mobiledata=true ro.lge.lcd_default_brightness=153 ro.lge.one_binary_support=true ro.lge.custLanguageSet=true ro.lge.dataprotect=1 ro.lge.heat_finish=51.0 ro.lge.nfc=true lge.nfc.vendor=brcm ro.com.google.gmsversion=4.4_r3 ro.setupwizard.mode=DISABLED ro.livewallpaper.map=DISABLED ro.com.google.apphider=on tangible_device_config=B1BCNAOTNA gsm.version.baseband=MSM8974A-AAAANAZM ro.lge.vib_magnitude_index=0,20,40,60,80,100,120,127 ro.sdcrypto.syscall=378 lge.normalizer.param=version2.0/true/14.5/true/8230/1.0/2050/0.55 ro.config.ringtone=00_Lifes_Good.ogg ro.config.notification_sound=Crystal.ogg ro.config.alarm_alert=Lifes_Good_Alarm.ogg ro.config.timer_alert=Timer.ogg drm.service.enabled=true persist.hwc.mdpcomp.enable=true ro.opengles.version=196608 ro.hwui.texture_cache_size=72 ro.hwui.layer_cache_size=48 ro.hwui.r_buffer_cache_size=8 ro.hwui.path_cache_size=32 ro.hwui.gradient_cache_size=1 ro.hwui.drop_shadow_cache_size=6 ro.hwui.texture_cache_flushrate=0.4 ro.hwui.text_small_cache_width=1024 ro.hwui.text_small_cache_height=1024 ro.hwui.text_large_cache_width=2048 ro.hwui.text_large_cache_height=1024 qcom.thermal=thermal-engine ro.sf.lcd_density=480 persist.fuse_sdcard=true persist.sys.emmc_size=0 persist.service.crash.enable=0 persist.sys.ssr.restart_level=3 persist.sys.purgeable_assets=1 persist.sys.strictmode.disable=true ro.lge.zwait=false audio.offload.disable=0 av.offload.enable=0 mm.enable.qcom_parser=37491 vidc.debug.level=1 mm.enable.smoothstreaming=true net.tethering.noprovisioning=true persist.lg.data.fd=-1 persist.radio.apm_sim_not_pwdn=1 persist.qcril.disable_retry=true ro.mot.eri.losalert.delay=1000 ro.vendor.extension_library=/vendor/lib/libqc-opt.so keyguard.no_require_sim=true ro.com.android.dataroaming=true ro.com.android.dateformat=MM-dd-yyyy ro.carrier=unknown dalvik.vm.heapstartsize=8m dalvik.vm.heapgrowthlimit=128m dalvik.vm.heapsize=256m dalvik.vm.heaptargetutilization=0.25 dalvik.vm.heapminfree=2m dalvik.vm.heapmaxfree=8m lge.signed_image=true ro.lge.capp_splitwindow=true persist.splitwindow.support_all=true ro.lge.capp_ZDi_O=true lge.zdi.actionsend=false lge.zdi.onactivityresult=true lge.zdi.dragdropintent=false ro.lge.lcd_auto_brightness_mode=false ro.lge.audio_soundexception=true ro.lge.capp_emotional_led=true ro.lge.capp_wfd=true ro.lge.capp_almond=true ro.lge.capp_smartcard_lgril=false ro.lge.capp_smartcard_uicc=true ro.lge.capp_smartcard_smartmx=false ro.lge.qslide.max_window=8 wlan.chip.vendor=brcm wlan.chip.version=bcm4335 wifi.lge.patch=true dhcp.dlna.using=false wifi.lge.sleeppolicy=0 wifi.lge.offdelay=false wlan.lge.concurrency=MCC wlan.lge.supportsimaka=YES wlan.lge.powermode=false wlan.lge.passpoint_setting=false wifi.lge.hanglessid=false wifi.lge.ftm_test=3 wlan.lge.wifidisplay=both wifi.lge.common_hotspot=true wifi.supplicant_scan_interval=180 pm.sleep_mode=1 ro.telephony.default_network=9 persist.sys.cust.lte_config=true persist.sys.dalvik.vm.lib=libdvm.so net.bt.name=Android dalvik.vm.stack-trace-file=/data/anr/traces.txt ro.qc.sdk.izat.premium_enabled=0 ro.qc.sdk.izat.service_mask=0x0 persist.gps.qc_nlp_in_use=1 persist.loc.nlp_name=com.qualcomm.services.location ro.gps.agps_provider=1
Ma mijenjao je xdabbeb bas prekjucer jer sam mu rekao iz svog build.propa..ne poklapa se. Posaljem mu da prepravi. Hvala
Kad izadje novi cloudyg3 onda ce valjati. Mijenjao je identifiere, mislim da nije namjerno.
