Gaming PC za oko 400e?
clapton
Cenjen
Bitno mi je da pogura 2, 3 generacije PES-a, FIFA-e... da mogu bez problema da radim u Lightroom-u ili PS-u (ponekad) i volio bih da ubacim i SSD od 120gb.
+ da kasnije mogu da lako odradim manji upgrade RAM-a i sl ako bude potrebe.
ovaj PC mi je ponudjen za 390e:
MBO: Asus H81M-K, Socket 1150, DVI/VGA, USB 3.0, Chipset Intel H81, gar 2 god = 40,00 eur opis:http://www.asus.com/in/Motherboards/H81MK/overview/
CPU: Intel Core i3-4150, 3.50GHz, 3MB, LGA1150, Haswell, GPU HD4400 = 101,00 eur
RAM: Crucial 4GB 1600MHz, CT51264BA160BJ, DDR3 Non-ECC CL11 240-pin DIMM = 41,50 eur
VGA: MSI AMD Radeon R7 250 1GD5 OC, 1GB DDR5, 128bit, D-Sub, DVI, HDMI, FAN cooling, gar 2 god =80,00 eur
SSHD: Seagate 3.5" 1TB 7200RPM, ST1000DX001, SSD MLC/8GB + HDD SATA 6Gb/s 64MB 7200RPM 3.5", gar 2 god = 87,00 eur
ODD: LG DVD RW GH24NSB0 24x speed, SATA Internal Black Super Multi DVD Rewriter = 17.00 eur
CASE: Rhino RH-C375I, MidiTower, ATX , napajanje RX-550PA 550W 6pin PCIE konektor, Boja: Crna = 26,00eur slika: http://www.plus.ba/assets/products/kuciste_raidmax_rhino_rh-c375i_550w1.jpg
ovaj je 427e (sa SSD):
MBO: Asus H81M-K, Socket 1150, DVI/VGA, USB 3.0, Chipset Intel H81, gar 2 god = 40,00 eur opis: http://www.asus.com/in/Motherboards/H81MK/overview/
VGA: MSI AMD Radeon R7 250 1GD5 OC, 1GB DDR5, 128bit, D-Sub, DVI, HDMI, FAN cooling, gar 2 god = 80,00 eur
SSD: SiliconPower SSD SATA3 120GB Slim /475MB/s, SP120GBSS3S55S25 = 75,00 eur
HDD: Toshiba DT01ACA050, 500 GB, SATA3, 64 MB, 3,5", 7.200 rpm, gar 2 god = 45.50 eur
CASE: Rhino RH-C375I, MidiTower, ATX , napajanje RX-550PA 550W 6pin PCIE konektor, Boja: Crna = 26,00 eur slika: http://www.plus.ba/assets/products/kuciste_raidmax_rhino_rh-c375i_550w1.jpg
a ovaj je najskuplji, 475e:
MBO: Asus B85M-E, Socket 1150, Chipset Intel B85, gar 2 god = 65,00 eur opis: http://www.asus.com/Motherboards/B85ME/
RAM: TakeMS 8GB DDR3 1600MHz CL11 (512x8) bulk = 70,50 eur
VGA: MSI NVidia GeForce GT 740, N740-2GD5, 2GB DDR5, 128 bit, D-SUB, DVI, HDMI, FAN cooling, gar 2 god = 95,50 eur
CASE: Blueberry BC-M46-520 Miditower Multimedia Case M46, PSU-520W, 1xUSB3.0, 3xUSB2.0+Audio, ATX, 3x5.25" = 39,00 eur
najvece razlike su u maticnoj ploci, RAMu i grafici. ostalo je skoro isto. da li preporucujete SSHD i moze li da se sastavi nesto bolje za ove pare?
Fx-6300. -12.000
Msi 970A-G43. -6.600
HDD 500GB Toshiba. -4.600
Ram 4 GB. - 4.600
Kuciste LcPower Pro 925B 600w. -5.800
R7 265 Saphire. -15.000
UKUPNO 48.600 u firmi em*i ili 420€
pozdravljam .
ako ti se više svidja intel (savet), u istoj firmi uzmi
Intel® Core™ i3-4150 -- 11.780
MSI H81M-P33 ------------4.300
Ostatak identičan.
grešiš mladi vuče, nažalost.
* fx6300 ima 3 fpu workera ( i to slabija ) dok i3-4xxx ima 4. (najveći broj kalkulacija su upravo Floating Point)
obrati pažnju na atačment - fx-6300 na 4.2 GHz ima slabije FPU performanse nego 2 jezgarni Intel Nehalem sa 4 threada na 3.2 GHz .
Moderni i3-4xxx su oko 30% brži.
* memorijski kontroler na haswelu je ~duplo brži nego na K15 amd
* IPC je ~50% slabiji kod AMD nego kod Haswella
* haswell ima AVX2 , dok AMD nema .
* Potrošnja - svima poznato. Da bi fx6300 dostigao FPU performanse i3 haswella , treba mu 130w (potrošnja se povećava logaritamski)
i samim tim 4000 dinara skuplja ploča .
Bio bi veoma srećan da je fx6300 bolji za igre od i3 hasvela, ali on to nije .
FX ne stavljati u novu mašinu . Eventualno kao apgrejd .
    199.9 KB · Pregleda: 206
Fx ima 6 jezgara a i3 ima 2 jezgra
Fx ima 2 jezgra u jednom a i3 ima jos 2 virtuelna jezgra
Fx je zver za taj i3
To sto si napisao nema veze s' vezom 🙂
Intel i amd su dve razlicite tehnologije i nikako ne mozes da ih poredis tako kao sto si napisao.
Znam da ne moze ali nikako nisam mogao drugacije da objasnim.. :]
A da li neko moze da mi objasni zasto vecina maticni za intel ima samo do 16GB rama i samo 2 slota?? I sta mislite o ovoj maticnoj AsRock B85M-GL?
Mihailo, koliko godina imaš? Deluješ mi kao neki školarac, sa tankim poznavanjem materije, a deliš ovde savete šakom i kapom. Čitaj malo pažljivije šta ti Kokan piše, možda i naučiš nešto korisno.
Vidis po nicku da je '98 godiste. 😀 Skoro kao forum mator. 😀
Kokan nastoji da bude objektivan, sto treba ceniti.
Ja bi razmislio i o Pentiumu G3258 u kombinaciji sa nekom h97 plocom asusa ukoliko je tacno da su biosom novim omogucili klok.
To sam i mislio, zato sam i pitao. 🙂 Nije problem, ima vremena da se uči, samo malo više da čita, a malo manje da deli savete. Hehe, ja sam 98-e prvi put overklokovao komp, nije bilo internet foruma gde je sve sažvakano, nego ti drugar proda foru, a ti rasklopiš komp podesiš džampere, i nadaš se da neće ništa da se pokvari kad uključiš ponovo. 🙂
Ploca ti je osnov, ali sve zavisi sta planiras i zelis.
Za cela 33Mhz. 😀 I oseti se u radu. 😀 Pa jos dzamperi na hardovima sa sve ide kablovima, kuku. 😀
Asus H97-PLUS~10.000
Asus VANGUARD B85~10.000(5 god. garancije)
Ako planiras u budućnosti upgrade dobro bi bilo da uzmes neku od ove dve ploce.
Ispravite me ako grešim🙂
ukoliko ne uzima K modele namenjeno overkloku, svaka 1150 ploča je sasvim dovoljna.
intel troši veoma malo, i Z ploče se razlikuju od H i B , samo po podršci za ram brži od 1600mhz.
Kokan se ne javlja a hitno mi je.
Dakle, R7265 OC je prosla a R7260X je dostupna odma. Na ovoj konf se ne bi osjetila razlika u performansama.
Da uzmem ovu drugu ili da cekam 10-15 dana za prvu?
