[ROM][Aug 17][G900FXXU1ANG7][4.4.2][ART][Knox 0x0] NeatROM v2.2
_Sale_
VIP član
Welcome to NeatROM for S5 G900F
Simple, clean and reliable
Please read the Terms of Use carefully:​
Please note that you will get Knox 0x1 (warranty void) when you flash: either a custom kernel or custom recovery.
To check your Knox counter status, boot into Download Mode (power off the device and then press Volume Down + Home + Power, then press volume up if the triangle screen appears) and the Knox flag is shown in the list at the top left hand side of the screen.
If, "KNOX WARRANTY VOID:", is showing as 0x0 then you have not tripped the Knox flag.
If it is showing as 0x1, your Knox flag is permanently blown and your phone is no longer suitable for Knox security purposes.
By installing this ROM, you take full responsibility of it's use. I am not responsible for anything that may happen or does happen to your phone, including KNOX, as a result of installing this Rom. You are choosing to install this yourself and thus accept any/all risks involved.
  • NeatROM for Samsung Galaxy S5 G900F
  • August 17, 2014
  • Firmware: G900FXXU1ANG7 NeatROM v2.2 Aroma (4.4.2)
  • Build date: Tue Jul 22 13:34:39 KST 2014
  • Modem: XXU1ANG7
  • CSC: AXX1ANG5-Multi
  • Change List: 2289584
  • Available languages in ROM: Azerbaycanca, Bahasa, Catala, Cestina, Dansk, Deutsch, Eesti, English, Espanol, Euskara, Filipino, Francais, Gaeilge, Galego, Hrvatski, Islenska, Italiano, Latviesu, Lietuviu, Makedonski, Magyar, Nederlands, Norsk bokmal, Ozbekcha, Polski, Portugues, Romana, Shqip, Slovencina, Slovenscina, Srpski, Suomi, Svenska, Tieng Viet, Turkce, Udru, Uzbek, Greek, Bulgarian, Russian, Ukrainian, Korean, Chinese...
  • Default Language - English
  • Aroma installer
  • Option to Full Wipe from Aroma
  • Odexed
  • Rooted
  • BusyBox
  • SuperSU v2.02
  • Private Mode
  • ART Compatible
  • NO WIPE
  • Enabled All Languages for Samsung Keyboard
  • Enabled Secondary Symbols on Stock Keyboard
  • No Auto Converting messages to MMS
  • Modded Mms (Sent Time instead of Received Time)
  • Enabled Sending/Receiving MMS without Data
  • Enabled Signature in Messaging
  • Enabled Scheduled Messaging
  • Enabled Split Mode in Messaging
  • Enabled Save VMessage
  • Enabled VCalendar
  • Enabled VTask
  • Enabled Save/Restore Messages
  • Enabled Call back Button in Messaging
  • Enabled Folder View in Messaging
  • Enabled Delete Button On ActionBar in Messaging
  • Enabled Option Delay Send SMS
  • Enabled Screen On-Off Option in Messaging
  • Enabled Vibration Option in Messaging
  • Enabled Group Message Option in Messaging
  • Increased SMS Hour Limit to 1000
  • Unlimited Recipient SMS/MMS Limit
  • Unlimited Contacts to SMS,MMS
  • No SMS or MMS in Call Log
  • Enabled Call Button in Logs
  • Enabled More Contacts (999)
  • Call Recording
  • Enabled Call & MSG Blocking
  • Enabled Camera Sound Menu
  • Enabled Camera During Call
  • Enabled Screen Capture Sound in Camera
  • Modded Camera (Removed Camera Battery Warnings)
  • Added Exit Browser Option
  • 4 Way Reboot Menu
  • Disabled scrolling cache
  • Enabled Hidden Torch Settings
  • NeatROM WallPapers
  • Allowed Installation Of Apps From Unknown Sources By Default
  • Disabled Verify Apps By Default
  • Disabled Safe Volume Warning
  • Disabled Battery Cover & Charging Cover Toasts
  • Enabled Menu Alarm Alert During Silent Mode
  • Default Screen Animation speed set to 0.5
  • Cooked using JustArchi's awesome kitchen Thanks to [MENTION=5161352]JustArchi[/MENTION]
  • www.NeatROM.com set as default home page for Browser
  • Removed Knox
  • Read/Write to External SD Card enabled
  • Rebuilt all permissions
  • Init.d Support
  • Init.d Tweaks
  • Build.prop Tweaks
  • Multiple other Tweaks
  • Other minor changes and fixes
  • Option to Install:
    - Stock Bootanimation
    - NeatROM Bootanimation Thanks to [MENTION=2915835]momo.martinovic[/MENTION]
    - Google Bootanimation
    - Android L Bootanimation
  • Boot Sound:
    - Enable
    - Disable
  • Apps:
    - FlashPlayer
    - DropBox
  • Choose the Apps you want to Install:
    - Google Books
    - Google Chrome
    - Google Play Movies
    - Google Drive
    - Google Magazines
    - Google Maps
    - Google Music
    - Google Play Games
    - Google+
    - YouTube
    - ChatON
    - Email/Exchange
    - Flipboard
    - Help Hub
    - Live Wallpapers
    - Memo
    - Mobile Print
    - Polaris Viewer
    - Samsung Update
    - Samsung Fonts
    - Calculator
    - Music Player
    - Video Player
    - Widget Active Application
    - TalkBack
    and many more...
    I probably forgot something
August 17, 2014
MD5 Sum: fdaf99ee85378fcb2718b299b25439e0
Please don't post any mirrors. I count the downloads
Ask me first for permission if you want to use my work in your ROM
Complete NeatROM File Mirror is available here Thanks to [MENTION=4478812]ApriliaM3[/MENTION]
Installation Instructions via CWM recovery (KNOX 0x1)
1. PLEASE make a Nandroid backup of your current ROM!!!!
2. Backup your Internal SD to your PC
3. Download NeatROM onto your phone (either internal or external SD card) and reboot your phone into recovery mode (turn your phone off and then press & hold Volume Up & Home & Power buttons)
4. Reboot your phone into recovery mode (turn your phone off and then press & hold Volume Up & Home & Power buttons)
" IF YOU'RE COMING FROM ANOTHER CUSTOM ROM OR HAVING ISSUES WITH APPS FORCE CLOSING AFTER THE FIRST BOOT, IT IS HIGHLY RECOMMENDED TO WIPE DATA AND THEN INSTALL NeatROM"
5. Select "Install Zip" and then navigate to where the NeatROM zip is located on your SD card
6. Once the Aroma Installer starts, select the options that you would like to install
7. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
8. Remove the battery for a few moments and then put it back in, boot into Download Mode (press Volume Down + Home + Power, then press volume up)
9. Download and open PC Odin
10. Download, extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
11. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe Data"
12. Enjoy your NeatROM
Installation Instructions: If you're coming from NEATROM (KNOX 0x0)
1. Backup your Internal SD to your PC
2. Backup your Apps
4. Check the md5sum of the NeatROM.zip
5. Run Mobile Odin Pro---pic1---pic2
6. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
7. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
8. UN-TICK "Wipe data and cache"---pic1
9. UN-TICK "Wipe Dalvik cache"---pic1
10. Select "After flash..." then select "Download mode"---pic1,---pic2
11. Select "Flash firmware"---pic1
12. Once the Aroma Installer starts, select the options that you would like to install
13. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
14. When the phone goes into Download Mode, download and open PC Odin
15. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
16. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
17. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
18. Go to Settings/Security/ and UN-TICK "Send security reports"
19. Enjoy your NeatROM with KNOX 0x0
Installation Instructions: If you're coming from a Samsung stock NON-Rooted ROM before NG2/NG7/NG9 (KNOX 0x0)
2. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
3. Go to Settings/Security/ and UN-TICK "Send security reports"
4. Go to Settings/About device/Software update/ and UN-TICK "Auto update"
5. Root your phone with Towelroot---pic1---pic2
6. Reboot and install SuperSu from the PlayStore
7. Run SuperSU and select "Continue", "Normal" and "Cancel". Reboot device.---pic1,---pic2,---pic3
8. Run SuperSU again and select "Try to disable KNOX"---pic1,---pic2
9. Reboot and download NeatROM onto your phone
10. Check the md5sum of the NeatROM.zip
11. Purchase and install Mobile Odin Pro
12. Run Mobile Odin Pro---pic1---pic2
13. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
14. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
15. UN-TICK "Wipe data and cache"---pic1
16. UN-TICK "Wipe Dalvik cache"---pic1
17. Select "After flash..." then select "Download mode"---pic1,---pic2
18. Select "Flash firmware"---pic1
19. Once the Aroma Installer starts, select the options that you would like to install
20. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
21. When the phone goes into Download Mode, download and open PC Odin
22. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
23. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe Data/factory reset" then "reboot system now"
24. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
25. Go to Settings/Security/ and UN-TICK "Send security reports"
26. Enjoy your NeatROM with KNOX 0x0
Installation Instructions: If you're coming from a Samsung stock NON-Rooted NG2/NG7/NG9 ROM (KNOX 0x0)
2. Download, extract, boot the phone into Download Mode and flash this ROM using PC Odin (use AP on Odin)---pic1,---pic2
3. Boot the phone normally. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
6. Go to Settings/About device/Software update/ and UN-TICK "Auto update"
7. Root your phone with Towelroot---pic1---pic2
8. Reboot and install SuperSu from the PlayStore
9. Run SuperSU and select "Continue", "Normal" and "Cancel". Reboot device.---pic1,---pic2,---pic3
10. Run SuperSU again and select "Try to disable KNOX"---pic1,---pic2
11. Reboot and download NeatROM onto your phone
12. Check the md5sum of the NeatROM.zip
13. Purchase and install Mobile Odin Pro
14. Run Mobile Odin Pro---pic1---pic2
15. Load the NeatROM.zip file with "OTA / Update ZIP"---pic1,---pic2
16. UN-TICK "Enable EverRoot" (NeatROM is already rooted)---pic1
17. UN-TICK "Wipe data and cache"---pic1
18. UN-TICK "Wipe Dalvik cache"---pic1
19. Select "After flash..." then select "Download mode"---pic1,---pic2
20. Select "Flash firmware"---pic1
21. Once the Aroma Installer starts, select the options that you would like to install
22. When the ROM has finished installing, and at the end of the installation process in Aroma, UN-TICK "Reboot Device"---pic1
23. When the phone goes into Download Mode, download and open PC Odin
24. Extract and flash MODEM (load as CP) and BOOTLOADER (load as BL) in ONE STEP---pic1---pic2
25. If something goes wrong and your device will not boot after flashing, try to remove the battery for a few moments and then put it back in, press and hold VolumeUP + Home + Power to boot the device into recovery mode and do a "wipe data/factory reset" then "reboot system now"
26. Go to Settings/Security/Security policy updates/ and UN-TICK "Automatic updates"
27. Go to Settings/Security/ and UN-TICK "Send security reports"
28. Enjoy your NeatROM with KNOX 0x0
My KNOX flag is still 0x0 :) but I am not responsible for anything that may happen to your phone including KNOX as a result of this guide
Bravo Sale, svaka čast.
Sto bi rekli stranci : " Reserved" ;-) :)
Ne razmisljam :) Koliko sam sve iscitao,nema potrebe za razmisljanjem :) Evo instalirao SuperSU... Prazna mi baterija, da napunim,odradim backup ,pa cu da flesnem :) ;)
A towelrot?
Viči ako zagusti nesto mada ako pratis detaljno svaki korak nema sanse. Ja sam flesovao preko 100 puta
Da,da Towelrot je prosao bez problema ;) Mobile Odin je nesto bagovao,kao device not supported,ali sam ga reinstalirao sa marketa i on je proradio bez problema ;) Kontam sve,prosto je ,nema sta ,moracu samo da flesujem novi modem i bootloader,posto mi nije prosao zadnji update.
Haha :) Pa na NE2 sam, nisam na NG2, pa kazem da cu morati i PC Odinom da flesujem modem i bootloader... Kontas sad? :)
Bravo Sale, svaka čast !!! Čestitam ti na velikom trudu.
Koliko brzo će sada ići razvoj ovo ROM-a ? Planiraš li baš brzi razvoj i da skroz zapostaviš S2 i S3 ROM-ove ili kako ćeš sada ?
Da li će biti AOSP 4.4.4 verzije za S5 ???
Hvala
Bice. Planiram ovako: tih nekoliko sati koliko sam odvajao za S2 i S3 pa puta 2 rom-a, da bude (S2+S3+S5)*2 podeljeno na iste sate ili malo manje
Sve je proslo bez greske :)
Samo jos wipe da odradim, da bude sve clean i voziii :)
Yup , 0x0 :)
U svakom slučaju, dok se ROM očisti od bugova i grešaka, preporuka je da se sačeka.
Nikad nije preporučljivo odmah prvu verziju koristiti, već je bolje sačekati nekoliko izdanja dok se stvari optimizuju i stabilizuju. Slažeš li se, Sale ?
Ne. U ovom slucaju stvarno ne vidim ni jedan jedini razlog. Jedino ako cekas da ce se pojavi knox 3 pa da nas sve za.ebe?
Aha, ok.
A jesi li stavio ART kao default ili ne ?
To neka Samsung TouchWiz *******cija?
Nemam :D imam s4 0x1 od prvog dana tako da bih probao taj tvoj 0x0 već do sad :D
Samo na osnovu iskustva sa s3 kažem svaka čast, a ako ikad kojim slučajem budem imao s5 tvoj rom ide odmah :D
Ovo nije bilo jos od S2... I mnogo me nervira... Dal moguće da su uveli tu notifikaciju u zadnjem romu? Jel moze to negde da se isključi a da ostane power saving ON?
Koristis PS mode?
Ponekad, kad sam vani a nemam punjac blizu... Inače, na S5 baterija uspeva uglavnom da izdrži ceo dan i bez njega, sreća...
Nikad to nisam koristio, malo pe sam ukljucio pa da vidim kako se ponasa S4.
