Kako izgleda Vas LINUX Desktop?
Tema: Numix-daily (modovana)
Ikonice: Numix-circle
Pozadina: Star-Citizen (sa SC reddita)
Conky: simple & nsclock
Svala čast za post, sve pojašnjeno, tako da nema potrebe da se postavljaju pitanja šta je ovo šta je ono. Šteta samo što nisi i linkove ostavio
@G@W
@delboy
JOš jednom svaka čast. Školski primer šta je dobar post
Novi hardver, stari softver 🙂
openSUSE 13.1
default tema i wallpaper
conky sam malo izmenio u skladu sa novom rezolucijom ekrana 🙂
# Conky, a system monitor, based on torsmo
# Any original torsmo code is licensed under the BSD license
# All code written since the fork of torsmo is licensed under the GPL
# Please see COPYING for details
# Copyright (c) 2004, Hannu Saransaari and Lauri Hakkarainen
# Copyright (c) 2005-2010 Brenden Matthews, Philip Kovacs, et. al. (see AUTHORS)
# All rights reserved.
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
background yes
font Snap.se:size=8
xftfont Snap.se:size=8
use_xft yes
xftalpha 0.1
update_interval 3.0
total_run_times 0
own_window yes
own_window_transparent yes
own_window_argb_visual yes
own_window_type normal
own_window_class conky-semi
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
minimum_size 206 5
maximum_width 206
default_color 7fe817
default_shade_color 000000
default_outline_color 000000
alignment top_left
gap_x 10
gap_y 5
no_buffers yes
cpu_avg_samples 2
override_utf8_locale no
uppercase no # set to yes if you want all text to be in uppercase
use_spacer no
TEXT
${font zekton:style=Bold😛ixelsize=14}SYSTEM${font Snap.se:size=8} ${hr 1 }
Hostname: $alignr$nodename
Kernel: $alignr$kernel
Uptime: $alignr$uptime
Processes: ${alignr}$processes ($running_processes running)
${font zekton:style=Bold😛ixelsize=14}CPU LOAD${font Snap.se:size=8} ${hr 1 }
Load Average: ${alignr} $loadavg
Core 1 ${alignc}${alignr}${freq 0}MHz (${cpu cpu0}%)
${cpubar cpu0 8}
Core 2 ${alignc}${alignr}${freq 1}MHz (${cpu cpu1}%)
${cpubar cpu1 8}
Core 3 ${alignc}${alignr}${freq 2}MHz (${cpu cpu2}%)
${cpubar cpu2 8}
Core 4 ${alignc}${alignr}${freq 3}MHz (${cpu cpu3}%)
${cpubar cpu3 8}
Highest CPU $alignr PID CPU MEM
${hr 1}
${top name 1}$alignr${top pid 1} ${top cpu 1} ${top mem 1}
${top name 2}$alignr${top pid 2} ${top cpu 2} ${top mem 2}
${top name 3}$alignr${top pid 3} ${top cpu 3} ${top mem 3}
${top name 4}$alignr${top pid 4} ${top cpu 4} ${top mem 4}
${font zekton:style=Bold😛ixelsize=14}MEMORY LOAD${font Snap.se:size=8} ${hr 1 }
RAM ${alignr}$mem / $memmax ($memperc%)
${membar 8}
SWAP ${alignr}$swap / $swapmax ($swapperc%)
${swapbar 8}
Highest MEM $alignr PID CPU MEM
${hr 1}
${top_mem name 1}$alignr${top_mem pid 1} ${top_mem cpu 1} ${top_mem mem 1}
${top_mem name 2}$alignr${top_mem pid 2} ${top_mem cpu 2} ${top_mem mem 2}
${top_mem name 3}$alignr${top_mem pid 3} ${top_mem cpu 3} ${top_mem mem 3}
${top_mem name 4}$alignr${top_mem pid 4} ${top_mem cpu 4} ${top_mem mem 4}
${font zekton:style=Bold😛ixelsize=14}FILESYSTEM ${font Snap.se:size=8}${hr 1}
Root: ${alignr}${fs_free /} / ${fs_size /}
${fs_bar 8 /}
Home: ${alignr}${fs_free /home} / ${fs_size /home}
${fs_bar 8 /home}
Ext: ${alignr}${fs_free /var/run/media/user/Transcend/} / ${fs_size /var/run/media/user/Transcend/}
${fs_bar 8 /var/run/media/user/Transcend/}
USB: ${alignr}${fs_free /var/run/media/user/USB/} / ${fs_size /var/run/media/user/USB/}
${fs_bar 8 /var/run/media/user/USB/}
${font zekton:style=Bold😛ixelsize=14}NETWORK ${font Snap.se:size=8}${hr 1}
LAN $alignc Speed $alignr Total
Down: $alignc ${downspeed eth0}/s $alignr ${totaldown eth0}
Up: $alignc ${upspeed eth0}/s $alignr ${totalup eth0}
Ево и мог. Ништа спектакуларно. Чак ми је и тема подразумавна. Имам једино Конки за који је G@W оставио везу. Мало препрваљен да се не губи при клику на Прикаши радну површ дугме, а да се виде иконице. Исцимао сам се за то и једва сам нашао на нету. Такође променио сам и команду за бројање пакета за ажурирање, и додао сам ово горе Убунту 14.04, које је у ствари команда lsb_release -d | cut -c15-25.
Тема: подразумевана
Иконице: подразумеване
Позадина: кликни
Конки:
Kod:
# Settings #
background yes
use_xft yes
xftfont Liberation Sans:size=9
xftalpha 1
update_interval 1.0
total_run_times 0
own_window yes
own_window_class Conky
own_window_type dock
#own_window_transparent yes
own_window_argb_value 0
double_buffer yes
minimum_size 200 200
maximum_width 300
draw_shades no
draw_outline no
draw_borders no
default_color 656667
default_outline_color 828282
default_bar_size 240 2
alignment bottom_left
gap_x 1600
gap_y 100
no_buffers yes
uppercase no
cpu_avg_samples 2
# Output #
TEXT
${color #FFFFFF}
${font Ostrich Sans:pixelsize=35}${execi 3600 lsb_release -d | cut -c14-25}${font}
${font Ostrich Sans:pixelsize=35}${voffset 15}CPU: ${CPU}%${font}
${font Ostrich Sans:pixelsize=35}${voffset 15}RAM: ${mem}${font}
${font Ostrich Sans:pixelsize=35}${voffset 15}UPDATES: ${execi 3600 /usr/lib/update-notifier/apt-check 2>&1 | cut -d ';' -f 2}${font}
${font Ostrich Sans:pixelsize=17}${voffset 15}UPTIME: ${uptime}${font}
Svež je sistem, i za sada izgleda ovako, mada tek ga treba modiffikovati.🙂
Manjaro
WM Theme: Adwaita-Manjaro-dark
GTK Theme: Menda [GTK2]
Icon Theme: evolvere-green-folders-vivid-dark-
  • Screenshot - 2014-07-04 - 12:15:36.webp
    144.4 KB · Pregleda: 319
off-pitanje: U kom sistemu i grafickom okruzenju se moze ovo dobiti:
http://i.kinja-img.com/gawker-media/image/upload/19gbgawgudhepjpg.jpg
U pitanju je Numix tema, Numix ikonice, Docky,...
Meni je bitno da li moze u bilo kom grafickom okruzenju da se dobije identicno ovako? Guglajuci, dosao sam do zakljucka da npr na Xfce-u i Gnome-u nece izgledati isto. 🙂
Izvinite, ali pocetnik sam. 🙂
To bi bio gnome shell, ukoliko se ne varam. Dok je verovatno Plank sa tranparent temom.
Ja bih izvrsio harikiri kada bi me neko naterao da koristim Fedoru. Sve je bolje od Fedore, ali sve. Cak i Slackware koji je apsolutno prevazidjen i koji odrzava samo jedan covek. Jedini razlog zbog kojeg ljudi koriste Fedoru jeste priprema za serfitikacione testove za Red Hat (sertifikacija ugh, kako mrzim tu rec). Ko ne zeli Ubuntu, topla preporuka Arch Linux ili Manjaro. Ako cete vec da prljate ruke, nemojte se zamajavati sa Debian Sidom jer je pacman mnogo bolji od APTa.
Takodje, Docky je za zaobilazenje ukoliko ne radis .NET development na Linuxu pa vec imas preinstalirane Mono pakete. Plank nema magnify ali to je meni licno veliki plus posto je magnify icons on mouse over deciji fazon ako mene pitas. Mislim da Cairo ili AWN imaju magnify ako ti bas treba.
Koristiš qbitorrent i transmission u isto vreme ? 🙂
Да; недавно сам почео да користим qbit јер има боље могућности, а transmission ми је укључен јер се сидују торенти које сам већ скинуо. Сидујем до 1:2 односа, па чекам да се заврши.
Ih pa gde njih nadje pored deluge i rtorrent 🙂
KDE 5 Neon, instaliran na Linux Mint 17 KDE
Nije los ovaj Plank, sad ga prvi put probam.
Screenshot from 2014-08-06 13:43:40.webpScreenshot from 2014-08-06 13:44:59.webpScreenshot from 2014-08-06 13:49:18.webpScreenshot from 2014-08-06 13:46:03.webp
Ubuntu Trusty
Theme, Numix
Icon, Numix Circle
Dock, Plank Transparent
Sta je ovo sa Numix, svi koriste?
Opensuse 13.2 (factory rolling zapravo)
Ikone Numix circle
  • Screenshot from 2014-08-21 02:29:57-1.webp
    49.8 KB · Pregleda: 394
Vidim da je tema dozivela, a ja jos nisam presao na linux....malo kakim jos od novog sistema...
Tema: Lubuntu-default
Ikonice: Faba-mono-dark
Pozadina: M50 & 300i (wallhaven search: star citizen)
