Hello, This is Pete from CoinedUp.com
I'm sure you all have heard of what happened to mtgox recently. In summary, they double paid-out a significant number of withdrawals, because of some automated withdrawal code that was poorly written.
First off. We do not have that problem. So, not to worry.
One issue we are having is that some nefarious group is now trying to scam all the other exchanges (including us), by trying to replicate the issue that mtgox had. Again, we do not and could not have the same issue as mtgox, however, it is annoying to see a lot of our transactions become mutated (these appear as double-spends on blockchain.info https://blockchain.info/double-spends)
That is just an annoyance and is not the specific reason that bitcoin deposits/withdrawals are down right now.
The main reason is simply that we don't know what is going to happen next, and we don't want to lose your bitcoins! To my knowledge, the bitcoin network has never seen a mutated transaction rate that was this high, and clearly there are some bad actors out there attempting some sort of scam.
It might be over overcautious, but we're keeping the deposits/withdrawals offline until we can do some further investigation. I'm predicting we'll turn them back on in about 3-4 hours.
If you have anything to add, please comment.
PS: Customer Service is a bit behind as well. Sorry for the delay. Please be patient.
EDIT: This is an interesting thread: https://bitcointalk.org/index.php?topic=457546.0
cekcekcek, da li ima neka menjacnica na koju kad posaljes odma dodaje btc bez konfirmacija? tj koliko se transakcija pojavi u blokchain?
beše i mtgox najavio ltc?![]()
ako ima neko da odgovori na brzinu
samo je vazno da odredjena menjacnica kreditira racun pocim se transakcija pojavi na blokchainu, znaci bez konfirmacija
Sta li hoce ovaj sa tolikom kupovinom FTCa
