AMD Athlon 64 x2 4000+ dokle smem ?
CPU Type DualCore AMD Athlon 64 X2, 2173 MHz (10.5 x 207)
CPU Alias Brisbane
CPU Stepping BH-G1
Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3
Original Clock [ TRIAL VERSION ]
Min / Max CPU Multiplier 4.0x / 10.5x
Engineering Sample No
L1 Code Cache 64 KB per core (Parity)
L1 Data Cache [ TRIAL VERSION ]
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
CPU Physical Info
Package Type 940 Pin uOPGA
Package Size 40 mm x 40 mm
Transistors [ TRIAL VERSION ] million
Process Technology 10Mi, 65 nm, CMOS, Cu, DSL SOI
Die Size [ TRIAL VERSION ] mm2
Core Voltage 1.100 - 1.300 V
I/O Voltage 1.2 V + 2.5 V
Maximum Power 65 - 76 W (depending on clock speed)
CPU Manufacturer
Company Name Advanced Micro Devices, Inc.
Product Information http://www.amd.com/us/products/desktop/processors
Driver Update http://www.aida64.com/driver-updates
Multi CPU
Motherboard ID nVidia MCP65
CPU #1 AMD Athlon(tm) 64 X2 Dual Core Processor 4000+, 2173 MHz
CPU #2 AMD Athlon(tm) 64 X2 Dual Core Processor 4000+, 2173 MHz
CPU Utilization
CPU #1 / Core #1 18 %
CPU #1 / Core #2 15 %
Postuj stranu Overclock.
CPU Alias Brisbane
CPU Stepping BH-G1
CPUID CPU Name AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
CPUID Revision 00060FB1h
CPU Speed
CPU Clock 1863.0 MHz (original: [ TRIAL VERSION ] MHz)
CPU Multiplier 9x
CPU FSB 207.0 MHz (original: 200 MHz, overclock: 3%)
HyperTransport Clock 1035.0 MHz
Memory Bus 310.5 MHz
DRAM:FSB Ratio CPU/6
CPU Cache
Motherboard Properties
Motherboard ID 64-0100-000001-00101111-080207-ATHLON64$1ADKU004_A7369NMS V2.1 080207
Motherboard Name MSI K9N Neo v2/v3 (MS-7369) (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, LAN)
Chipset Properties
Motherboard Chipset nVIDIA nForce 520, AMD Hammer
Memory Timings 5-5-5-15 (CL-RCD-RP-RAS)
Command Rate (CR) [ TRIAL VERSION ]
DIMM1: Kingston 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
DIMM2: Hexon HEXON [ TRIAL VERSION ]
BIOS Properties
System BIOS Date 08/02/07
Video BIOS Date 08/20/08
DMI BIOS Version V2.1
Graphics Processor Properties
Video Adapter nVIDIA GeForce 9400 GT
GPU Code Name G96GT (PCI Express 2.0 x16 10DE / 0641, Rev A1)
GPU Clock (Geometric Domain) 550 MHz (original: [ TRIAL VERSION ] MHz)
GPU Clock (Shader Domain) 1400 MHz (original: [ TRIAL VERSION ] MHz)
Memory Clock 333 MHz (original: 333 MHz)
CPU Multiplier 9x treba da stoji na 10.5x
Pci-e frekfenciju zakljucaj na 100mhz,u protivnom ce se
i ona klokovati.
HyperTransport Clock rucno na 1035.0 MHz
CPU FSB na 220 za pocetak.
Memorije rucno na 333-ili ako stoji 667mhz.
North Bridge Clock rucno na 1035.0 MHz znaci iste vrednosti kao HyperTransport Clock
voltazu procesora na 1.3 za pocetak.
North Bridge i memorija voltazu za sada ne diraj ostavi na auto.
Podigni sistem i prati temperature.
Ako ti se desi da padne sistem i ne mozes da upalis komp,onda odradi reset biosa
i bice ti sve na default podesavanjima.
PS- ugasi amd cool and quiet
ahaa ok hvala :)
javim ti da li sam uspeo
PS-kako odradim reset imam opciju ili stsnem neku tipku?
Pa prespajanjem jupera na ploci,ali ako ti je to
previse komplikovano,izvadi bateriju od biosa
predhodno ugasi komp,iscupaj naponski kabal iz napajanja.
Na start dugme pritisni(kao kada ukljucujes PC)
na prazno par puta,vrati batriju,kabal i gotovo.
