sta je AUXTIN
Google:
"Firstly will give you knowledge about AUXTIN. AUXTIN (w83627dhg pin102), the input of temperature sensor 3. It is always used for temperature sensing. On board, it used for auxiliary zone temp sensor, my knowledge says, its placed either near OPT_TEMP2 2-pin header which is near SATA ports or otherwise its placed near the Winbond W83627DHG Super IO chip which is close to PCI-E #3 slot (farthest blue slot from CPU). And what you getting is a bogus sensor unconnected to anything. Just ignore it."
:guitar:
I meni je taj AUXTIN preko 120c u jednom trenutku.. Pa brate kako ga samo ignorisati :S
Brate bas ja gledam to kad je postavljena tema.. Reko mozda moze neko da mi pomogne za ovo ******...
To se slazem sa tobom :) Jel ima nova tema u vezi ovoga ?? Ja sam nasao ovu samo
