AMD’s recently released R9 280X is basically a re-brand of the HD 7970 GHz edition as it uses the same Tahiti XT2 chip. However, a new report suggests that the Tahiti XT2 chip in the R9 280X will be soon replaced with the improved Tahiti XTL chip which will lower the power consumption and run cooler. Now you must be wondering why would AMD update a card that has just been released. The reason behind that is AMD wasnt ready with their Tahiti XTL chip in time for the GPU14 event so they had to push out the R9 280X with the Tahiti XT2. However, it’ll now be replaced by a running upgrade which means that there wouldn’t be an announcement or anything. AMD will simply start shipping cards with the new Tahiti XTL chip and only way to tell these apart from the Tahiti XT2 based ones will be by looking at the BIOS of the card.
:wall:
Jel ima neko informaciju kad na tržište stižu "nove" R9 280X?
Jel koristi mozda neko XFX 7950 karte za majning? Zamolio bih za adekvatan bios. Menjao sam biose n akarti i nisam sacuvao stari. Stavio sam oko pet razlicitih XFX biosa na 800/1250 i 900/1375 i ni jedan nece da radi kako treba.
Oznaka karte je XFX R7950 Double Dissipation, model:FX-795A-TDJC
Ako neko ima informaciju koji bios provereno radi ili ako koristi ovu kartu pa ima adekvatan bios neka mi se javi na PM. Hvala
Po stranim forumima sam nasa "Each XFX BIOS has to be modified" nadam se da nije tako 😀
Sad uzeh da prostudiram testove tih novih r9 270/270x i koliko vidim razlika je samo u klokovima.Tacnije receno 270 je u odnosu na 270x osakacena za jedan 6pin naponski konektor i samim tim i def/max klok joj je nizi,ali...ako je verovati benchmark testu overklok i jedne i druge karte je priblizno isti.Sad,ako se pozovem na wiki od pre par postova 270x na 1120/1500 treba da daje 476kh/s sto opusteno po benchmarku moze da postigne i 270ka obicna.Da li je neko probao r9 270 pod guiminerom naklokovanu do max da mi potvrdi ovo moje gornje pisanije?Ako se ispostavi da je tako onda bi ovo mogla da bude prva ozbiljna konkurencija 7950 kartama bar sto se mininga tice
Pa Srbijo majko,pa oni ladno prodaju 270 i 270x po istoj ceni :zgran:
Da bre, stavili istu cenu lopovi, na jednoj zaradjuju 20% dok na drugoj jedno 35%.
Ledio baci problem u temi LTC sta, gde... pretposlednja strana u vezi widgeta... poz
poslao sam ti moj bios ali da znas da je oznaka na mojoj karti TDFC VA3
Pozdrav svim rudarima ovde.
Imam par pitanja u vezi hardvera.
1. Da li je ova moja sadasnja konfiguracija ok za pocetak rudarenja ?
2. Sta bih trebao da nadogradim ?
3.Posto vidim ovo trosi dosta struje koje napajanje da uzmem umesto ovoga ?
Ugasi komp i prebaci na backup bios (imas mali prekidac na kartici) . Posle kad se digne sistem prebaci ga u polozaj gde je taj los bios i ufleshuj stari koji je valjao 😉
Evo ti i tutorijal :
Ja nemam taj switch na grafici.....
Tacna oznaka karte, tj ono sto pise na nalepnici nalepljenoj na kartu je:FX-795A-TDJ V5.0 DD Radeon 7950 925m boost ready....
Dodje mi da je zavrnem kroz prozor, ceo dan sam izgubio maltretirajuci se sa XFX biosima i opet nista nisam uradio.....
Asus 280X DC2T CGminer 1070/1500 1134mv 750Khs .
cgminer podesavanja :
Evo ja sam stavio ista podesavanja u cg mineru , u trixx-u stavio iste klokove i voltazu i dobijam 525 khs. A gui miner na low 630 plafon, high nece ni da radi.
Mada me sada nesto jebava nece ni ni gui da radi kako valja. Nemam pojma sta sam stavio i kako prosli put
Nista mi nije jasno sta je sa ovim asusom r9, izgleda da nije samo slucajnost. Jer ortako isto nece da baca preko 600kh...
2.Sta bih trebao da nadogradim ?
1. mozes da rudaris ali slaba je to kartica za rudarenje, nece ti se isplatiti!
a i to napajanje ako je u pitanju blueberry od 420w nije uopste dobro (bolje nemoj da pokusavas da rudaris dok ga nezamenis), zameni ga u svakom slucaju i ako nebudes usao u ovu pricu sa rudarenjem!
2. moras da kupis neko krsteno napajanje i neke kartice HD7850/7950/7970/R9 270-290(sa x u oznaci ili bez nebitno) sve zavisi koliki ti je budzet.
3. napajanje moras da uzmes u zavisnosti koje i kolko ces grafickih staviti, tek onda ti mozemo dati predlog za neko kvalitetno napajanje...
pozz
Za pocetak sa koliko novca raspolazes? Elem, nekoliko postova iznad R9 270X Sapphire se postavlja kao trenutni $/kh pobednik. A od napajanja v700 ili neki Seasonic.
w
nemam pojma ! Ili ja nesto ne radim kako treba ili nemam srece i prosla 7870 mi je imala rezz ispod proseka. Gui miner 670 sada daje
u svakom slucaju , vise sam odlepio
Nista mi ne pricaj za 7870 pisao sam o njima, jos vrte jedna 360 druga 390 i nece preko undervolt. Klokovi minimalni cim nesto povecam u bilo kojoj kombinaciji samo losiji rezultati.
Daj rezove klokova i podesavanja u guimineru .
Prika nemoj da odlepljujes nego slusaj kad neko hoce da ti pomogne,kupis 7950 makar i polovnu malo koristenu i rudaris na miru
Neki ljudi ovde nisu svesni da novih- starih kartica nema ni za lek...niti 7950,7970 niti 280X.....tj. ima Light....koji je preskup.....i onda neko sanja da kupi grafike za 15-20k..... uh....najava postoji..kod par uvoznika za nekih 15-20 dana...no slusajte sada....tipa stizhe im 30 kartica....a potraznja je za 300...u startu....toliko...
Koji su ti def clockovi od te karte ? Kod ove su 1070/1600 a za kopanje je spusteno samo na 1500 jer na 1600 daje 650Khs a na 1500 daje 750Khs .
Inace to je ova karta a ti verovatno imas onu koja je na 1000Mhz za GPU
http://www.itsvet.com/proizvod/asus-radeon-r9-280x-3gb-gddr5-r9280x-dc2t-3gd5/comp_comp_vga/20/3613
koja je bolja od ove dve kartice za kopanje
AMD Radeon 7950 MSI TFIII OC 3GB/DDR5,DVI/HDMI/2xDP/384bit/R7950 TF 3GD5/OC BEG
ili ova
SAPPHIRE 100352-2L Radeon HD 7950 3GB 384-bit GDDR5
@cacanin tako ispada ...
da li neko moze da pojasni fenomen da li je do razlike u serijama/generacijama grafickih ili nesto trece ?
- kako dve kartice radeon 6970 sa istom plocom i cpu mogu da proizvedu 1Mhs
- druge dve kartice radeon 5970 sa istom plocom i cpu mogu da proizvedu 1.1Mhs
kada je bar statistika vise nego duplo u korist 5970 ? http://www.hwcompare.com/9425/
Statistika je *****, a ti nesto nisi dobro namestio
podesavanja u start skripti za rig sa dve 5970 kartice (temp 70-74 u nehladjenoj prostoriji a hash oko 1.1M prosek)
rig je sa 4GB rama jedan modul ddr3
gpu clock 820 a mem 1000 tako bar kaze msi afternurner ili kako se vec zove
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_USE_SYNC_OBJECTS 1
cgminer.exe --scrypt -o http://litecoinpool.org:3333 -u ******* -p ******** -T
a u config fajlu
"pools" : [
"url" : "stratum+tcp://litecoinpool.org:3333",
"user" :"****************",
"pass" : "**********"
"intensity" : "13,13,13,13",
"vectors" : "1,1,1,1",
"worksize" : "256,256,256,256",
"kernel" : "scrypt,scrypt,scrypt,scrypt",
"lookup-gap" : "2,2,2,2",
"thread-concurrency" : "6400,6400,6400,6400",
"shaders" : "0,0,0,0",
"gpu-fan" : "0-90,0-90,0-90,0-90",
"gpu-memclock" : "0,0,0,0",
"gpu-memdiff" : "0,0,0,0",
"gpu-powertune" : "0,0,0,0",
"gpu-vddc" : "0.000,0.000,0.000,0.000",
"temp-cutoff" : "95,95,95,95",
"temp-overheat" : "80,80,80,80",
"temp-target" : "72,72,72,72",
"api-port" : "4028",
"auto-fan" : true,
"expiry" : "30",
"failover-only" : true,
"gpu-dyninterval" : "7",
"gpu-platform" : "0",
"gpu-threads" : "1",
"hotplug" : "0",
"log" : "5",
"no-pool-disable" : true,
"no-submit-stale" : true,
"queue" : "0",
"scan-time" : "5",
"scrypt" : true,
"temp-hysteresis" : "3",
"shares" : "0",
"kernel-path" : "/usr/local/bin"
Upravo tu jacu imam sa T. U prvoj radnji sa linka kupljena. Namestio sam je nekako sinic tj. Jutros u 2 u gui mineru da izbaci preko 700. Cini mi se 720. Klok je valjda 1080 1500 i volt. 1100 a temp je, ne znam dok n ne dodjem kuci
Na tim klokovima mora da baca 760Khs .
