Neban26
Cenjen
A link 1 post iznad tvog ti nije dovoljan?!? :banana:
Pardon, tebi treba Legacy. Ali i to se nađe za 10 sekundi na AMD sajtu...
mozes promeniti u registriju verziju drajvera i onda radi i sa starim
pa nedjes u registry-ju verziju drajvera i promenis u koju god oces to je samo text
Pogledajte prilog 129013
The "catalyst version" in the window is just a text registry entry, you can edit it to whatever you want. If the driver version is correct just ignore it or change it to something enjoyable, like 13.37 or lol.cake(or just 12.4 so the updater works, but where is the fun in that?).
Frame Pacing poboljsan...
Da, ali koliko ljudi ima Quad CrossFire?! 😀
FEATURE HIGHLIGHTS OF AMD CATALYST™ 13.12
Support for the following new products:
• AMD Radeon™ R9 290, 280, and 270 Series
• AMD Radeon™ R7 260, 250, and 240 Series
Improved AMD CrossFire™ scaling for the following game titles:
• Call of Duty®: Ghosts (multiplayer component)
• Splinter Cell Blacklist
• Saints Row 4
• Metro Last Light
New AMD Enduro™ Technology profiles for the following game titles:
• XCOM: Enemy Unknown
• Need for Speed Rivals
• Total War™: Rome 2
• Battlefield 4
• Saints Row 4
• FIFA 14
• Support For AMD CrossFire frame pacing
Frame pacing ensures that frames rendered across multiple GPUs in an AMD CrossFire configuration will be displayed at an even and regular pace
Frame pacing is enabled through the AMD Catalyst Control Center, or on a per application basis
Frame pacing is supported on DirectX® 10 and DirectX 11 applications using resolutions up to (and including) 2560x1600 on a single display
Cek instaliram 13.12, i stoji mi idalje u catalystu da je catalyst 13.9? Da pokusavam ponovo?
Samo sam instalirao preko ovih sto imam...
edit: kontam sad mozda je ostao stari catalyst a drajveri da su se promenili na 13.12, sto sam uspeo i da vidim tamo u system info sto ima da se pokrene u katalistu....
Ja za brisanje koristim ovaj program http://forums.guru3d.com/showthread.php?t=379505
Zato što kad idu whql preko beta drajvera, uvek ispisuje tako. Ako te to nervira, deinstaliraj pa instaliraj ponovo, onda će pisati kako treba.
Za tvoju kartu idu 13.9 http://support.amd.com/en-us/download/desktop/legacy?product=legacy2&os=Windows 7 - 64Ja sam instalirao ove a i prethodne drajvere za windows 8.1 ali nemam nikakve opcije u ccc??? Ne mogu ni da sredim sliku na drugom uredjaju tj LCD? Graficka mi jeste iz ATI Radeon HD 4000 serije ali radi extra(skoro sve igre mi idu na high) doduse imam dobar procesor sa cetiri jezgra! Nije mi jasno kakav je ovo ccc kad nema opcija kod mene,na win7 x64 je sve radilo ok?!
Pogledajte prilog 131790
Kako nisu spremni?Ja se danas igrao skoro ceo dan dok nisam skontao da driveri jos nisu spremni za 8.1 win ... Moje karte su 280x i 290x ..
