F1 2013
Sto se ne zovem i prezivam na A 🙂
Al su ojadili split screen, katastrofa ko i proslogodisnja verzija. Moze po jedna trka da se vozi i to je to. Takodje McLaren daleko sporiji od Ferraria, realno i jeste ove sezone ali mi pravi problem kad igram sa drugarom. Mogli su i split screen kao sto su i online izjednacili bolide.
F1 2013 PC Patch #2
Today sees our second PC Patch available on Steam for PC versions of F1 2013. We will update this topic once the patch goes live (today).
PC FPS Issues:
We’ve made further improvements to the PC FPS issue whereby higher specification PC’s had a considerable lap time advantage over lower ones.  The difference now should be negligible and should allow fair competition between all players.  Again we are aware this is a hot topic and will continue to monitor the forums for feedback once this fix is live.
At 30+ FPS the track will now rubber in.
Minor Fixes:
In Online Custom Races AI cars that have retired will now be removed from the track correctly.
Improved AI replication on high latency / low bandwidth connections in Online Custom Races.
Corrected Professional and Expert AI difficulty on Sakhir (Bahrain) & Monza.
Fixed an issue where on certain hardware all menus will be black.
Force feedback settings tweaked to remedy the mid corner ‘dropout’ that some players were reporting.
The above fixes (where relevant) for the Xbox 360 and PS3 versions of the game are currently being tested and verified. These require additional submission and authorisation from Microsoft and Sony so the release date for these will follow a little later than the PC version.
Information on our previous PC patch can be found here.
Thanks for your continued feedback
Moze li ovaj Patch #2 da se instalira odmah ili moram prvi patch pre toga?
molim vas recite mi zasto mi ni ne radi save games.cak i ako snimim 5 ili sestu trku uvek me vrati na onaj prvi save games,npr u mom slucaju je kina 5 krug sam snimio.
Igra radi normalno preko tastature, kad prikljucim volan Logitech Momo racing ispada iz igre posle nekih 10 sekundi voznje. WIN 7 x64 je instaliran kao i win7 x64 drajver za volan, ima li jos neko istih problema?
Ja imam problem da mi ne kada gas ne reaguje do kraja. Stisnem papucicu koliko moze ali na pola stoji gas i nece vise da ide.
Kada gledam u kalibraciji najnormalnije papucice rade, " logitech formula force ex " je upitanju.
Today sees our third PC Patch available on Steam for PC versions of F1 2013.
Mid Session Save
Fixed a bug which prevented car setups from being loaded correctly when a Mid Session Save is created while on track in a Practice session.
Fixed an issue in Career which would cause a perpetual load when resuming a Mid Session Save after accepting a mid season contract.
Online
Improved connection map, latency evaluation and bandwidth evaluation to improve the quality of connection information.  This in turn should result in fewer disconnects in multiplayer games.
Minor Fixes
Memory savings when selecting Flying Lap in any session.
Evo odvezao sam jedan krug u Belgiji pa uzivajte malo... Slobodno pojacajte zvuk, isplatice vam se 🙂
U pitanju je classic car Lotus 100T... All assists off i manuelni menjac...
[YOUTUBE]GEdxD-ggQyk[/YOUTUBE]
ufffff masu je teza ova formula od prethodne.Istina prije sam igrao na tastaturu a sada na g 27 i ugodjaj je vrhunski.Sa ukljuce
nim full traction,automatskim mjenjacem i amater tezinom ne mogu sa Marisijom medju prvih osam.Mozda je i na ps3 teze...
Tek sad vidim ovo. Svaka cast, fino vozikas.
Inace ovo mi je najljepsa staza od svih, pogotovo prva krivina, strasni sud.
Ne mogu da verujem sta mi se desilo sa igrom... Danas pokrecem igru i imam sta da vidim... Izbaci mi poruku da je save s**ban i da ce biti obrisan! 😡 Ne mogu da verujem... Ostalo mi je jos 6 trka u sezoni, stigao sam do Koreje, presao na pola sezone iz Lotusa u Ferrari, sve cveta, toliko truda i sati provedeno na trening, podesavanje bolida, obavljanje R&D zadataka i na kraju mi se desi ovo...
Jel postoji ikakva mogucnost da se vrati stari save?
There are a few things to do for everyone that has a corrupt save game. The problem lies in the practice session (Career and Grand Prix) the game becomes corrupt if you exit out of the practice without moving on to qualifying.
So when u start the game u can either get a message of the game that tells you your save game is corrupt or either the game crashes (F12011.exe stopped working). When you get that go to your save game folder (My Documents/My Games/ FormulaOne2011/savegame) and open the autosave folder. Once in there locate the GTEHXOSJZ_0 file and delete that then copy and rename GTEHXOSJZ_1 to GTEHXOSJZ_0 so you have both files again.
Your game should be working again, but(!!!) keep in mind that when you do that u will lose all progress you made the time u played before the corruption began.
For example. You open the game (not corrupt) and you go in career and you are at Spa. you complete the race and go on the Monza, there you exit out of practice and close the game. The game corrupts and you do the fix. You start the game again and you need to do Spa again.
So your game is restored again and now what to do to not make it corrupt again.
Simple, do not exit out of practice without moving on to qualifying.
This worked for me and I only had one corrupt savegame and after i did this i never got one again
Meni je ovo pomoglo, doduse F1 2011 je bila u pitanju. Mozda je slicno i sa 2013, probaj...
Problem je sto ne mogu nikako da nadjem save game folder, nema ga kada ga trazim u My Documents. Citao sam nesto i ljudi su ga pronalazili u steam folderu, ali ja ni nemam instaliran steam...
Nije mi jasno, igra mora negde da cuva save-ove, kako automatske, tako i one manuelne.
Ima li ikog da igra ovaj vrhunac serijala, uz 2020? 😀
Zanima me, moze li mi neko pomoci sa bugom za Player One. Ne mogu nick da promenim, a ako neko igra ili se seca kako se to resava, nek se javi, potrebno sto pre. Hvala unapred 🙂
Takodje i za LAN na Hamachiju zasto crashuje, ako ima legendice da jos to koristi haha xD
Ovo dobilo dobru ocenu 😳 Ovo nije copy\paste prosli deo?
