Opera
Dobro je ovako, ne talasajte, tek nam promenise.
Ja sam skinuo sad i developer, tako da imam sve varijante:
12.16 64-bit; Next 16; Developer 17; IE 11 DP; Firefox Nigthly 26-64-bit; Comodo Dragon; i kako god da se zove verzija 64-bit Chrome 30.
Pozamasna kolekcija, nikad ne bih rekao da cu toliko da ih drzim u isto vreme. :D
Jel mozes da ih syncujes sve preko opera link-a ?
nemoze
tek sad opera 17 ima neku experimentalnu sinhronizaciju ali jos uvek neradi.
Novi build:
CHR-1145 Update chromium to 1547.49.
DNA-9469 Geolocation badge indicator is displayed in addressbar after the user dismisses the dialog with the ESC key
DNA-8558 Dot separating badge icons is missing on Windows
DNA-9528 Fix Crash in FillPasswordForm
DNA-9411 After performing Paste and Go, Opera remains focused on address bar
DNA-8085 Make paste and go work even without focus in address bar
DNA-7912 Prevent javascript copy/paste fraud
DNA-8995 Can't search for strings starting with javascript
DNA-9351 Crash occurs when trying to copy more then one line of code with javascript in address bar
http://my.opera.com/desktopteam/blog/2013/08/13/16-0-1196-41
DNA-8270 Fixed problem with loading pages with Off-road mode
DNA-8338 Opera crashes when adding page with unknown protocol warning to Speed Dial
DNA-9259 Baidu speed dial search logo is cut off
DNA-9420 Geolocation badge indicator is displayed in addressbar after the user dismisses the dialog with the ESC key
DNA-9564 javascript:alert("hi") crashes opera.
DNA-9856 Crash when closing private window while downloading
http://www.opera.com/computer/thanks?partner=www&par=id%3D35953%26amp;location%3D360&gaprod=operanext
CHR-1183 Update chromium to 1547.57
DNA-10000 Some images does not finish loading with off road mode
DNA-10104 Opera Stable picks up 'Last Install Path' but writes to 'Last Stable Install Path'
DNA-7634 Save scroll offset to stash db instead of saving the whole content state blob
DNA-8512 Page address is not in the quotation marks on the permission dialog
DNA-9134 Translate strings for Opera 16
DNA-9261 Speed dial folder is misplaced on second load in custom builds
DNA-9503 crash on clicking link in page opened from stash
DNA-9894 Search queries with space replaced by about:blank when unfocusing the address field
http://www.opera.com/computer/thanks?partner=www&par=id%3D35957%26amp;location%3D360&gaprod=operanext
I sada jer se ova tema zove ''Next'', a moja za sve verzije je zatvorena, gde da se stavi o novoj stabilnoj i developer??
Izasla je 16 stabilna i ima nova developer verzija.
Pa 16 je Next, a Developer je jos uvek beta, tako da moze i ona u ovu temu. Bolje je kad je sve na jednom mestu.
16 je sada stabilna, Developer je alfa. I gubi se smisao naziva teme, neka se promeni u Opera sve verzije ili nesto slicno, jer je ovo zbunjujuce i glupo.
Za sve ostale browsere na forumu imamo lepo da je za sve, ova tema se zove za jedno, i off-topic je da pisemo za druge verzije, striktno gledano.
Opera Next je opšteprihvaćeni naziv za novu Operu. To znači sve verzije koje nisu 12.xx. To što oni interno označavaju verzije sa Stable, Next, Developer za nas nije bitno. Kao kada bi branio nekome u Firefox temi da piše o Aurora jer je to alpha nightly verzija a Firefox tema je samo za stable...
Nemojte da unosite zabunu.
Opera Next je beta verzija i postojala je i u vreme Opera 10 i 11 verzije. Stabilna verzija je sada 16, developer 17 ce za koji dan postati next itd.
Ako je tako, onda lepo nek neko izbriše Next iz naziva.
Pa prijavi prvi post i u komentaru ostavi predlog, tako sam ja izboksovao da se tema preimenuje u Next :p
pošto će opera još neko vreme pružati podršku za verziju 12.xx neka ostane naziv Opera Next, kako bi se znalo na šta se odnosi.
Neka bude Opera sa ili bez browser. Tako ce moci da se raspravlja i o final i o next i o developer.
12, kolilo su rekli ce da dobije neke sitnice, i verovatno ce biti pustano kao RC ili final, bez Next verzije.
I verovatno nece biti bitno pomena.
čekaj bre, gde su bukmarkovi , napredna podešavanja i ostale zezalice ? nije valjda da su i se i opera labs slizali sa SOPA , pa da imaju cloud bazu korisničkih bukmarkova i podešavanja ...
Na Opera 16 i novijim jeste, ali zavisi od update grane. Ne možeš uraditi update sa Opera 16 na Opera 17 nego moraš čekati da stigne ispeglani update za Opera 16 koji sadrži sve što su implementirali u dev/next grani.
Auto-update je i na 15. Nema napredih stvari, doci ce kasnije. Nije klon, nego na njegovoj osnovi, na koju nisu stigli da izgrade.
Ova Opera je krš realno. Šta su izbacili,15, 16 i 17 verzije bez nekih realnih poboljšanja. Očigledno je google na finjaka kupio velikog konkurenta i rešio da ga polako ugasi.
kada ce opera 16 prestati da bude samo polovina browsera i postati kompletna? Stvarno mi se svidja kako radi jer je brza od bilo kog drugog, ali mi je neupotrebljiva.
a sta vam to fali u novoj operi a imali ste u staroj, izuzev Opera mail-a ?
nisam detaljno ni testirao, ali tab grouping, podesavanja speed diala (podesavanja bilo cega zapravo su vrlo ogranicena prema onome sto vidim). ne mogu da namestim ni izgled na koji sam navikao sa dugmicima koje redovno koristim.
