Video sam skoro zamenjen touch (u nezvaničnom servisu) na Sensation-u i dobro je radio i izgleda kvalitetno, kao originalni. Ali nije najbolje prijanjao uz "liniju" telefona sa svih strana kao što to radi originalni. Možda je to samo ovde bio slučaj, ali sam siguran da je bio touch najviše klase koji može da se nadje kod nas po nezvaničnim servisima.
Ako bi ga prodavao u takvom stanju, javi za koliko bi ga prodao jer mi je potrebna ispravna ploča.![]()
7.RUN THE JB TOOL or control-bear now
Follow the Complete set of Instructions(Step 2 | ControlBear: and Step 3 | Wire Trick: ) on running the controlbear from the official Juopunutbear website ...i.e from here http://unlimited.io/juopunutbear.htm
Verify - You are on Stock RUU (not FreshROM, Stock Rooted, HarmonyROM - none of these will work!)
Verify - You are HTC Dev Unlocked
Turn ON USB Debugging on your device (Settings > Developer Options)
Verify fast boot is turned OFF (Usually found under Power Settings)
Connect your device and set to "Charge Only"
Download the correct version of the tool for your HBOOT and OS:
HTC Sensation (pyramid)
Linux Gingerbread
Linux Ice Cream Sandwich
Untar ALL files from the download into a new folder
cd into the folder where you extracted and run the following cmd:
Note: This cmd returns a blank new line if you have done it correctly.
chmod 755 ControlBear adb fastboot
Run ControlBear from terminal - sudo ./ControlBear
Follow the on-screen instructions from ControlBear.
Do not press any of the buttons on the phone during the process.
Vidi da nekom četkicom malo očistiš usb port na telefonu. Možda se samo zaprljao.
Jel neko ubacivao CM rom na Sensation-u i kako je zadovoljan?
Moj Sensation se u poslednje vreme dosta usporio iako mu nisam dodavao mnogo aplikacija, pa razmisljam da ce CM da resi problem
Mislio sam da ce bolje da radi sa rom-om nego samo sa hard resetom. Ima li neko iskustvo s Cyanogenmod-om?
