1% je na wire transfer ali imas swift confirmation i bank clarification sto se jednom naplati po 30$.
Please note that we only charge the wire deposit/withdrawal fees in according with the service fees:
https://www.okpay.com/services/fees.html
There are no hidden charges, however we would like to warn you that correspondent bank charges can be applied and vary and (deducted from the sent amount).
Please do not ask us to give you the exact fee for the transfer you will send as it all depends on the country and the way banking system works is that in many cases you can not calculate the amount with 100% guarantees.
Banking details verification and SWIFT confirmation are required only if you point wrong banking details or your transfer is lost.
Thank you
O pa super onda nisu skupi uopste!
Edit: steta sto ne salju plasticne kartice
Cek, meni na withdrawal na btce pise 0% provizije minimum 1 eur i na usd isto.
Uzima ako uplacujes pare ako radis withdraw onda je 0%.BTC-e na Okpay uzima trenutno proviziju od 4% + 1% + banka na kraju sve to izadje 7-8% minimum
EDIT: ja sam povlacio vise puta i eure i dolare i nije bilo provizije.
10 eura okruglo otislo na swift i banka uzela proviziju 2 eura-povlacenje sa okpay na devizni.
Hahaha nadam se da je keopsova, neka je ona postoji vec 1000-e godina...zahvaljujem se u ime btc drustva![]()
BTC-e --> okpay par sati, okpay --> banka sutradan ali nisam povlacio u srbiju.A vreme od klika na btce, preko okpay, do podizanja love u banci?
