AIMP 3.2 ili 3.5?Meni sve ok ASIO siba kontrola zvuka radi...
3.5AIMP 3.2 ili 3.5?
Pri tome i dalje ne znam sta je, jer pri cistoj instalaciji 3.2 i dalje je isto, iako je radila savrseno dok nisam uradio update na 3.5. :crash:
AIMP je tata za izvikanog Winamp-a.
Evo zasto:
1. AIMP je ljepsi.
2. Zvuk je cistiji na AIMP-u.
3. AIMP manje rama jede.
Winamp-a samo slava izvlaci. Ljudi su culi samo za njega(poznajem takve ljude)pa ga zato i koriste.
pa nije tesko biti bolji od winampa![]()
ali zato ih foobar dere![]()
Probaj da instaliraš 3.5 pa onda deinstaliraj uz pomoć Revo Uninstaller-a, da bi počistio sve što je 3.5 ostavio ili izmenio...
Aimp ne reprodukuje video fajlove kao Winamp.![]()
Aimp rules, valjalo bi da ubace automatski downloader album artova. Jel primetio neko razliku u zvuku kad se stiklira "Allow advanced channel procesing"? Koristim WASAPI.
mix 5.1 to 2.0
or 2.0 to 5.1
see Help >> Playback >> Playback options
Za Advanced Channel Processing ja našao ovo objašnjenje.
Allow advanced channels processing
Switching-on of channel mixing, in case of input channel count is not equal to output one. If option is disabled source channels will be either duplicated or rejected.
Sample 1:
Source file is 5.1 (6 channels), but it has stereo output (2 channels). If option is disabled, only 1st and 2nd channels of source signal will be played.
If the option is enabled, left channel will play mix of 1st, 3rd (left channels) and 5th (central channel). Right channel will play mix of 2nd, 4th (right channels) and 5th (central channel).
Sample 2:
Source file has stereo format (2 channels) and 5.1 output (6 channels).
If option is enabled - 1-й и 3-й (левые) каналы 5.1 system sends signal from left stereo channel to 1st and 3rd (left) channels 5.1, and to 2nd and 4th (right) – right channel. Mix from both stereo channels will go to central channel, low-frequency component of central channel will go to subwoofer.
Proveri PM. Izgleda da je neko editovao link.
Mada, link je vodio do poruke koja sadrži tekst is AIMP Help fajla. Evo, citiraću tekst:
AIMP v3.51 Build 1288 (07.08.2013)
* Sound Engine: TAK decoder has been updated
* Sound Engine: Cache system has been improved - CPU usage has been reduced
* Playlists: auto name algorithm has been improved
* Tag Editor: The progress of current operation is now displaying on the taskbar button
* Skin Engine: The sizes of windows now automatically adjusted after screen resolution changing
- Fixed: Common - The Ctrl + Page Up / Ctrl + Page Down hot keys does not work in secondary windows if its have been used as local hot keys in the player.
- Fixed: Common - Bugs in some localizations
- Fixed: Common - Format line parser does not process "\," set of symbols correctly
- Fixed: Sound Engine - Tracks with long names cannot be played in some cases
- Fixed: Sound Engine - No an ability to pause file playback, if it located on remote server
- Fixed: Sound Engine - Program crashes during radio capture process, if playable track has incorrect symbols in one of its tag fields
- Fixed: File Save Dialogue - No overwrite confirmation in some cases
- Fixed: Browse Folder Dialogue - The Ctrl + Up / Ctrl + Down hot keys does not work
- Fixed: Playlists - Deletion of the collapsed group expand group which placed below
- Fixed: Playlists - Playlists Manager deletes playlists pass the recycle bin
- Fixed: Playlists - the "Save playlist 'Default'" option is ignores when closing playlist tab
- Fixed: Skin Engine - An ability to resize window is blocked after change skin to another without maximization support if window is maximized
- Fixed: Skin Engine - Converter ignores special settings for All-In-One skins
- Fixed: Pandemic AIO Skin - No ability to drag player window by its caption
- Fixed: Audio Converter - Bugs with parameters selection in the "WMA Encoder Settings" dialogue
- Fixed: Audio Converter - Bugs with parameters selection in the "OGG Vorbis Encoder Settings" dialogue
- Fixed: Tag Editor - Incorrect files order in the "Analysis Result" dialogue
- Fixed: Tag Editor - The M4A tag missing in the tags list for group removing / applying tag fields values
- Fixed: Tag Editor does not recognize files which located in the Windows Libraries
- Fixed: Audio Library does not take initial rating of file into account when adding file to database
- Fixed: Audio Library displays wrong data in the report
- Fixed: Small bugs and defects
+ Common: Added an ability to move links via drag-n-drop from internet browser to playlist or "Add link" dialog
+ Bookmarks: Added an ability to add playlists to the bookmarks
+ Bookmarks: "Bookmarks Manager" dialogue - quick search has been added
+ Bookmarks: "Bookmarks Manager" dialogue - usability has been improved
+ Sound Engine: Anticlipping
+ Sound Engine: Added an ability to customize resampling speed/quality
+ Sound Engine: Added an ability to use dithering when decreasing bit depth
+ Sound Engine: The SoXR library is now used for resampling
+ Sound Engine: Performance has been increased
* Rollback: Skin Engine - The sizes of windows now automatically adjusted after screen resolution changing
* Plugins: The "Internet Radiostation Catalog" plugin has been removed, you can access to catalogs via internet browser
* Player: Fading and cross mixing settings has been moved to DSP Manager dialogue
* Player: Cross mixing setting has been expanded
- Fixed: Sound Engine - Program crashes during cache buffer initialization process if system cannot allocate requested memory size
- Fixed: Player - window position is restored incorrectly if it was attached to the screen edge via drag-n-drop
- Fixed: Player - Data from ID3v2 has been replaced with data from ID3v1 in some cases, even if encoding is different
- Fixed: Player - Сrashes on attempt to activate DSP-plugin
- Fixed: Player - The custom information about the radio station is lost when playback is starting
- Fixed: Player - No information about bitrate is displayed for some files in the MP4 format
- Fixed: Tag Editor - File cannot be removed physically if it played in mini-player of the tag editor
- Fixed: Small another bugs
v3.55 - update for v3.5 has been published.
Major Changes
Advanced Search: The "file Location" menu item has been added
Advanced search: Added an ability to add files to the queue via middle mouse button click
Manual: Added search ability
Sound Engine: activating / deactivating effects are now processed more smoothly
Sound Engine: Cache system has been improved - read latency has been reduced
Tags: replay gain are now supported for MusePack v8 format
