Mac OS X Server 10.8.4 File Share problem
Stator
Dosao sam u posed Mac Mini server late 2012, I nikako mi ne ide da na njemu namestim prosti share fajlova. Jedino sto mi treba je to da nikada ne trazi User/Pass:
Sherovanje ukljuceno i random folder je dodat.
Sve dozvole su odvrnute do maksimuma:
Ali kada pokusam da pridjem tom sharu sa Win 7 dobijem ovo:
User Guest enable-ovan. Jel ima Mac neke spicijalne ACL-ove SELinux-e ili tako nesto sto propustam.
Ovo bi trebalo da bude krajnje prosta operacija ? Da li je to uopste moguce u 10.8 OS X-u ?
Pod mek os-om moraš da uđeš u file sharing i da tamo aktiviraš SMB za windows...
    45.3 KB · Pregleda: 137
Taj screenshot sam zaboravio ali to je odradjeno isto.
Inace ovo je tail /var/log/system.log kada pokusam da se ulogujem.
Windows pokusava da se uloguje sa bender\stator userom koristeci ntlmv2 protokol jer Win 7 koristi SMB 2.1
Kod:
Jul  1 18:08:05 macmini.local digest-service[513]: label: default
Jul  1 18:08:05 macmini.local digest-service[513]:      dbname: od:/Local/Default
Jul  1 18:08:05 macmini.local digest-service[513]:      mkey_file: /var/db/krb5kdc/m-key
Jul  1 18:08:05 macmini.local digest-service[513]:      acl_file: /var/db/krb5kdc/kadmind.acl
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: uid=0
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: init request
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: init return domain: MACMINI server: MACMINI
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: od failed with 22 proto=ntlmv2
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: user=bender\stator
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: kdc failed with 36150275 proto=unknown
Jul  1 18:08:05 macmini.local digest-service[513]: digest-request: guest failed with 22 proto=ntlmv2
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: uid=0
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: init request
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: init return domain: MACMINI server: MACMINI
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: od failed with 22 proto=ntlmv2
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: user=bender\stator
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: kdc failed with 36150275 proto=unknown
Jul  1 18:08:09 macmini.local digest-service[513]: digest-request: guest failed with 22 proto=ntlmv2
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: uid=0
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: init request
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: init return domain: MACMINI server: MACMINI
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: od failed with 22 proto=ntlmv2
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: user=bender\stator
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: kdc failed with 36150275 proto=unknown
Jul  1 18:08:13 macmini.local digest-service[513]: digest-request: guest failed with 22 proto=ntlmv2
Jul  1 18:08:29 macmini.local com.apple.SecurityServer[19]: Succeeded authorizing right 'system.privilege.admin' by client '/Applications/Server.app/Contents/ServerRoot/usr/libexec/ServerEventAgent' [100] for authorization created by '/Applications/Server.app/Contents/ServerRoot/usr/libexec/ServerEventAgent' [100] (2,0)
Jul  1 18:08:29 macmini.local com.apple.SecurityServer[19]: Succeeded authorizing right 'system.privilege.admin' by client '/Library/PrivilegedHelperTools/com.apple.serverd' [77] for authorization created by '/Applications/Server.app/Contents/ServerRoot/usr/libexec/ServerEventAgent' [100] (100000,0)
Izgleda kao da si sve uradio kako treba, ne bi trebao da ti pravi problem.
Kada ukucam:
Username: $hostname\$user
Password: pass
Onda mogu da vidim ceo FS, bez obzira sto on nije sherovan ?! Ali ne mogu nikako da ga nateram da radi bez user/pass.
Vrtim se u krug vec par dana...
smb settings
Kod:
macmini:log root# serveradmin settings smb
smb:ServerDescription = "Mac mini"
smb:EnabledServices:_array_index:0 = "disk"
smb:NetBIOSName = "macmini"
smb:AllowGuestAccess = yes
smb:LocalKerberosRealm = "LKDC:SHA1.A9AEC7FB4F0AFBE81789CAC160B3D511"
smb:wins server:_array_index:0 = _empty_dictionary
smb:DOSCodePage = "437"
macmini:log root# serveradmin status smb
smb:state = "RUNNING"
Moguce da je nesto promenjeno/******o u 10.8, jer u 10.6 meni radi bez win7 user/pass dialoga.
Da, u 10.6 i meni sve radi bez problema. Ono sto je interesantno je to da kada pokusas da pridjes sa drugog Mac-a serveru ne trazi user i pass, trazi samo za ne Mac sisteme...
