RoyalCoin
singerica
Cenjen
RoyalCoin is a new scrypt based coin developed by 3 guys based out of Montreal. We believe that the name of a coin is integral to it's success, so we won't be offering you junk. Here's what you need to know about RoyalCoin:
3 min between blocks
Subsidy half every 600,000 blocks
140,000,000 total coins
Retargets once per day (every 480 blocks)
100 coins per block
No premine
Default port is 9556
Default RPC port is 9557
In light of the fast difficulty retarget, early adopter special is offered:
Blocks 0-10 are for testing purposes and worth 0 RYC
Blocks 10-510 blocks worth 500 RYC
Blocks 510-1010 worth 250 RYC
Blocks 1010-2010 worth 125 RYC
Windows binaries: https://sourceforge.net/projects/royalcoin/files/royalcoin-qt.zip/download
Daemon (windows): https://sourceforge.net/projects/royalcoin/files/royalcoind.zip/download
Source: https://sourceforge.net/projects/royalcoin/files/royalcoin-source.zip/download
Website: http://royalcoin.org
Pools
http://www.royalcoinpool.com
http://miningpool.eu/ ---> PPLNS pool with a 1% fees
http://rlcpool.erundook.net/ ----> Fees 1,5% ----> ddos-protected
Malo detalja:
Mreža je sada na oko 185mh/s.
Očekuje se narednih dana na bter-u (svi se nadamo) :)
Prvi pool je PPLNS, po meni odličan. Sa steal-om veoma malim, manjim od 1%. Potrebno je 120 potvrda. Posle 6h počinju da pristižu novčići.
Ako neko ima pitanja, pitajte, ja ga majnujem dva, tri dana :)
Toliko novih coinsa da vise ne znam sta da kopam :D
Ja kopam royal dva dana i to na prvom poolu i za sada je sve ok , stale ispod 1% sto je odlicno. Isplata novcica korektna ali nakon 120 potvrda pa zna da potraje. Nadam se i ja da ce uskoro na bter.
Takođe, ja sam ih iskopao oko 1000, očekujem danas, sutra, eventualno prekosutra na bter-u :). Njedna od novih valuta nije ovako jaka. Malo je mreža u toku noći pala, ali i bolje, više za nas što veruju :D
Mreza je pala vise nego duplo, kontam da je masa ljudi presla na worldcoin, e sada ono sto mi se ne svidja u celoj prici je da cim se ljudi zagreju za neki coin i cim mreza drasticno poraste stvara se neki novi i krece masovno povlacenje sa poolova koji su do tada radili kao sat na te nove coine. Kao da se namerno upropastava nesto sto ima neku realnu sansu da se nadje na berzi.
Upravo tako, ja se nisam povukao, ja sam još tamo. Ako koji ima šanse da izađe ovih dana to je ryc, ali ono...
Ima li kakvih naznaka da ce ovaj mucenik osvanuti na kojoj berzi? Vidim diff pada, broj rudara takodje, a izlazak na berzu malo ko vise i pominje...
Kopa li ovo jos neko s bencha..sta mislite, probati jos malo ili bataliti?
Bataliti što pre. FTC I CNC treba da su nas naučili lekciju.
Da ali FTC i CNC su izasli na berzu, mogao je covek bar da se istovari na vreme...
I ja sam na vreme prodao chn.
Kupujem royalcoin 1k/5-6ltc zavisno od količine :)
Sta god pocnem da kopam na vreme to ne vredi nista bytecoin pa sad Royalcoin :banghead:
Kome pričaš, ja imam 5k coina trenutno, ako izađe negde biće super. Onaj cryptsy je shit za sada.
Neću ni da nudim, cena im nije realna, previše je niska. Bolje da propadnu nego za to da ih dam. :D
Realno za te pare bolje da ih sam koristis nego da ih prodas.
I da ih nabije tamo gde mu sunce ne sija...
hahahahah
ma bice od ovoga nesto, i ime walute izgleda da igra neku ulogu.. zato mislim da npr royal coin ima vece sanse od elacoina
Treba vremena, dok shvate ljudi šta je elitni novac :D
sinoc dok sam elc prebacio na cryptsy pena pade sa 0.02xx u bunar tako da cce da came do daljnjeg
*** ja sam poceo pre 12 sati da kopam i jos mi nista nije stiglo. A kopali smo ja i neki nas covek pod nickom - kraljevski *urac :)
a taj drugi pool nisam moga da namestim, tj namestim guminer al nije hteo da startuje, ne znam zasto.. mada i njihovi poolovi malo stucaju (bar je bilo tako sa wdc), gpu grafike mi non stop igra gore dole
Ti si taj.
ccc
ne ne, ja sam decko gospodin :)
(onaj prvi na listi) ne znam ko je ovaj kraljev penis :)
a i sad sam video da krecu da isplacuju tek sad, pa ce valjda biti sve u redu za par sati..
i jos nesti, aj mi objasni ovo sto pise kod mene da sam finder blocka, sta ja imam od toga? imam li neku nagradu ili sta? nisam bas jos upucen u ove price a zanima me...
Nemaš ništa od toga. Imao bi da ne majnuješ u pool-u. To ti je čisto da se zna ko ga je našao.
e do mojega...
znaci to je verov ako idem na solo mining, onda ima nagrada?
al to nemam pojima kako se podesava..
"nagradu" na solo majningu je kada razbiješ block (100royala). Sad pitanje je koliko će ti trebati da razbiješ jedan.
Na solo minigu nemaš sherove.
ne verujem da bi mi se isplatilo sa mojih 750 khas (2x7850)
a sta kad i nemam pojima da podesim...
Eto na kraju se isplati royal, steta sto samo jedan pool ima da valja, a na njemu zatvorene registracije. :S
