Xbox One
Jovyland
VIP član
CPU & Cooler
Ryzen 5 5600
Matična ploča
MS B350M Mortar Arctic
RAM
16GB DDR4 HyperX 3200Mhz
GPU
XFX Qick RX 6700 XT
Storage
1 TB SSDa + 3TB HDDa
Zvuk
WiiM Amp Pro + Dali Kupid
PSU
Seasonic MII EVO 520W
Monitor
DELL G2724D
Laptop
HP Pavilion Aero 13
Mobilni telefon
Pixel 9a
Pametni uređaji
Meta Quest 3S
Steam
jovyland
Pristup internetu
  1. Optički internet
  2. Mobilni internet
Bilo je skoro izvesno da ce MS u aprilu-maju najaviti sledeci Xbox, a od danas je to i zvanicno 21. maj. Do konferencije ce sigurno biti nekih leak-ova, pa sve nove informacije kacite ovde.
On Tuesday May 21st, we’ll mark the beginning of a new generation of games, TV and entertainment. On that day, we’ll be holding a special press event on the Xbox campus and we invite you to join us via the live global stream that will be available on Xbox.com, Xbox Live and broadcast on Spike TV if you are in the US or Canada.
On that day, we’ll share our vision for Xbox, and give you a real taste of the future. Then, 19-days later at the Electronic Entertainment Expo in Los Angeles, we’ll continue the conversation and showcase our full lineup of blockbuster games.
We are thrilled to pull back the curtain and reveal what we’ve been working on.
https://xboxevent.com/Reveal/
http://techcrunch.com/2013/04/24/xb...-console-may-21-at-microsofts-redmond-campus/
http://www.vg247.com/2013/04/24/next-xbox-reveal-set-for-may-21-in-redmond-washington-report/
lol 😀
Hahahahahaha :d
Xbox Durango ce kostati 500$? Pa to je vise nego sto je kostao X360. Nadam se da je Kinect medju standardnom opremom.
Petsto dolara u USA je 500 evra u EU, ko zna koliko u Serbistanu. Jos kazu da ima slabiji hardveri manje VRAMa od PS4. Onda ce PS4 da kosta koliko, 699$ u USA iliti 800 evra u Srbiji? Skupo bre, a dok izadju cenim da ce moci komp slicnih performansi da se uzme za ne vise od 30% skuplje. Dok prve valjane igre izadju nekih godinu dana po launchu, bice na istom a za dve godine po izlasku nece biti uopste isplativo kupiti konzolu (ako im cena ne ode dole za 50%).
Bolje da su isli na custom hardver i jedni i drugi, ovako developeri nece zezati sa optimizacijom portova i konzole ce biti prevazidjene brze nego li ijedna prethodna generacija.
Za sada ne deluje zanimljivo.
Bilo bi fino kada bi Sony stavio nizu cenu, da vidimo sta ce Microsoft da uradi. Mnogo je 500 evra danas dati na bilo sta, pa i konzolu.
Slazem se sa svima u vezi cene. Ja sam ocekivao da ce novi Xbox i PS 4 (jos cemo videti) kostati 399$. Sto bi bilo fer za pocetnu cenu.
Ali izgleda da Microsoft ima druge planove.
Ti nikako da ukapiras da razlika izmedju konzola i PCa nije hardver 🙂
Nije sve u hardveru to stoji, ali kada je softver korektno napisan onda jeste razlika u hardveru. A sto se tice toga da su lakse za koriscenje, jesu. Za vecinu ljudi koje IT ne zanima. Oni koje zanima ce potrositi malo vremena i napraviti HTPC koji moze sve sto i konzola pa i puno vise, bez vestackih ogranicenja. Verovao ti ili ne, odredjena kateregorija ljudi (kojima je ovaj forum i namenjen) bas to voli da radi u slobodno vreme. Voleo si i ti nekada a sada se pravis da si fensi fotograf u godinama koji je to davno prevazisao 🙂
Headshot 🙂
Već u boljim i kompleksnijim igrama i eksluzivama na PC-u, naravno, slažem se 🙂
Samo LOL :d Kladim se da to isto mislish i o gomili softvera i hardvera koji je vremenom samo nestao jer je od starta bio besmislen, kao sto su netbookovi ili oni microsoftovi tableti 🙂 O HTPCu da ne pricam, pa to samo vi geekovi sa bencha pravite :d Normalan covek kupi uredjaj koji je manji 10x i radi istu stvar :d
Ne, ja nikada nisam bio prosecni bench sakupljach porna na 15 HDDova :d Meni je komp uvek sluzio za neki posao, najmanje za igranje, a OCom sam se bavio godinu dana i to opet zbog posla 🙂 Pre ja za tebe mogu da kazem da si matorac koji se nije pomerio od 2000. godine, i da se i dalje lozis na hardver samo tek tako zato sto postoji, a da ti komp sluzi za surf i skidanje filmova koje nikad ne pogledas :d
driver 'ladno ima IQ sobne temperature. :d
Petsto dolara u USA je 500 evra u EU, ko zna koliko u Serbistanu. Jos kazu da ima slabiji hardveri manje VRAMa od PS4. Onda ce PS4 da kosta koliko, 699$ u USA iliti 800 evra u Srbiji? Skupo bre, a dok izadju...
Zapravo, cena je 300 dolara, za sve koji se budu obavezali da će da plaćaju Xbox Live pretplatu od 10 dolara mesečno (a takvi se broje milionima, ako ne i desetinama miliona). Srpska posla njih ne zanimaju puno. Njima je USA glavno tržište i tamo će se razbiti od prodaje, po ma kojoj ceni - a dotičnu uvek mogu da spuste posle nekog vremena.
Pa jeste, najbolje da je daju za 200 evra. :d I tada bi im se verovatno prebacivalo da GeForce 760 košta isto i nudi isti ili bolji kvalitet grafike.
Mene mnogo više brine cena igara.
jeste milijardama, ma jok, ceo univerzum. svi su baš zapeli da plaćaju konzolu mesečno, nemaju pametniji poso. osim ako nisu apsolutne budale, a doduše pokazalo se mnogo puta da ljudi to jesu
brine te cena igara? i treba da te brine. jer to je ono što diferencira konzole, zato su one "jeftine" jer razvaljuju od igara posle. ako ce novi xbox da razbije sa cenom u startu ili da ima pretplatu kako ce onda da naplaćuje skupo igre? ili ako pokušaju i pretplatu i skupe igre zašto bi to neko kupio kad može pc? na koji može da poveže isti fakin gamepad i tv i da ima prokletu konzolu. ili su ljudi fakin mnogo glupi. ali MNOGO
Imaju 46 miliona korisnika na Xbox Live. U fiskalnoj 2010.-oj, Microsoft je zaradio milijardu dolara samo od toga. Tako da je filipenko u pravu, cak je i premalo nabrojao.
aj da vidimo koliko je majmuna spremno da im plaća 10 evra mesečno pored kupljene konzole. moguće da se volas u svojim proračunima mnogo gadno zezno i da ja nisam u pravu, ali ja se i dalje nadam da jesam
Ako neko hoće da igra online svoje igre mora da plaća, to mu je što mu je. Tako je bilo i sa x360, nisu izmislili ništa novo.
Jos jednom ponavljam, Sony samo treba pametno da odigra i oprace ih ovu rundu. MS realno ne zna gde udara u poslednje vreme, nijedan proizvod koji su izbacili u poslednjih dve godine ne valja. Tako ce biti i sa novim Xbox-om. Ja ocekujem da se ovo samo u USA prodaje (patriotizam). Sirom sveta ce ih ugaziti PS4.
Pitanje je koliko PS4 može uopšte može pomoći Sony-u, Sony kao kompanija je u debelim govnima i praktično jedino njegova gaming divizija se drži u nekom minimalnom plusu, sa druge strane M$ još uvek pliva u parama i njima jedan kiks kao što je Sony-u bio PS3 ne bi napravio nikakvu štetu, kao što im nije štetu napravio ni prvi xbox, njima je bitno jedino da zadrže market share u nekom balansu.
Sa PS4 su ispravili grešku sa furanjem pogrešne arhitekture kojoj razvojni timovi nisu mogli lako da se prilagode, pogotovo oni multi-platgorm orijentisani, sada je ta greška ispravljena, ali kao što rekoh pitanje je koliko dugo Sony kao kompanije može da se uopšte zadrži na nogama, bez nekog cepanja kompanije na više delova i škartiranje divizija koje donose gubitke.
poenta je u tome da plaćaš stalno i za single player igre, pošto moraš da budeš allways on.
Pa za te situacije imaš onaj Xbox od 500 dolara i tu ne plaćaš predplatu za single player igre 😀
Koliko se sećam već imaju u ponudi Xbox 360 koji košta ultra jeftino, ali sa obavezom plaćanja 2 godine Xbox Live.
Pitanje je koliko je Xbox potreban MSu. Izgubili su milijarde na obe konzole, Xbox franšiza za njih je bukvalno nebitna u odnosu na pare koje uzimaju na Windowsu i Officeu. Ako bude problema u kompaniji, ode Xbox niz vodu. Eurogamer (Digital Foundry) tvrdi da je nemoguće da hardver konzole bude na nivou PS4, što je u današnje vreme, s obzirom na to da je ogroman broj igara multiplatformskog karaktera, jako bitno. Videćemo šta će Xbox moći da ponudi od ekskluziva - PS3 ih je imao daleko više od X360 a čini mi se da će situacija i sad biti slična. No, američko tržište je jako specifično, da se najblaže izrazim. Zašto treba plaćati 60 evra da bih igrao igre online, nikad mi neće biti jasno. Ali ovce su za šišanje.
M$ gaming divizija poslednjih par godina itekako posluje u pozitivi. Gubitci su bili za vreme prvog xbox-a koji su progurali sa brute force idejom samo da izbore i izgrade neki market share na račun gubitaka i u prvih par godina xbox 360, od onda gaming divizija donosi pare. Njihov veći problem trenutno je da se nametnu na tržištu tableta i mobilnih telefona, gde trenutno gube pare, ali ko zna, možda i tamo brute force uspeju da izbore neki market share, ali je tamo konkurencija daleko veća.
Evo recimo M$ izveštaj iz poslednjeg kvartala:
http://www.vgchartz.com/article/250...up-xbox-division-up-55-13m-xbox-360s-shipped/
apsolutno mi nije jasno odakle ljudima ideja da xbox360 ide u minus? i da mi neko kaže da je ps3 bolje prošao od x360. pa soni je prso ko oblanda bre sa ps3. ps4 hardver nedostižam? pa taj hardver u principu sad možeš da kupiš i napraviš takav pc. šta ti je?
Polako, jos se ne zna sta ce sve da ulazi u pretplatu i da li ce da zadrze biznis model. Nadam se da nece, jer je placanje samo za multiplejer je potpuno besmisleno.
E sad ako mozes da kupis konzolu za 250e uz 10e mesecno za sta bi ionako placao jer bez lajva nema mnogo smisla, a pretplata donosi gomilu besplatnih igara kao ps+ i ubace jos korisnih striming servisa, to je druga prica, zar ne.
hardver treba ostaviti po strani, ekskluzive i optimizacija izdvajaju konzole a kome se igra battlefield bolje da investira u future proof pc, ako tako nesto uopste postoji.
