Pozdrav, imam problem oko ubacivanja navigacije na HTC sensation XL, navigacija koju pokusavam da ubacim je Igo Primo 2.4-9.6 November 2012.
Uradio sam sve korake koji su dole navedeni medjutim ne mogu da instaliram program na telefon nakon sto sve prebacim na phone storage. Probao sam da preimenujem folder u rootu na Igo, medjutim opet nece, ne znam gde gresim.....
A) Install base Primo2 files
1) Extract/Unrar Required Base Files on your computer.
Copy entire Primo2 folder to your GPS device or SD Card.
Primo2 folder and Primo2.exe within it can be renamed to whatever
your device or menu system would prefer. Do not unzip anything within the Primo2 folder.
2) Extract/Unrar Non-TTS Voice files on your computer.
Copy desired {voice}.zip file to the appropriate folder under Primo2 folder, as shown,
on your device or SD Card. Do not unzip the Voice file.
3) Extract/Unrar Program-Interface Language files on your computer.
Copy desired {Lang}.zip file to the appropriate folder under Primo2 folder, as shown,
on your device or SD Card. Do not unzip the Language file.
