SeRPeNT
Elem, ne znam da li je ovaj topik vec bio ali mislim da nije, pa reko da podelim sa onima koji zele da dobiju Windows 8 Pro potpuno besplatno.
Proces je sledeci:
Nakon restarta imacete i Windows 8 media centar i FULL verziju Windows 8 Pro (ne nisam pogresio, PRO a ne ENT)
Nadam se da sam pomogao
Proces je sledeci:
- Skinete windows 8 enterprize trial (http://msdn.microsoft.com/en-us/evalcenter/jj554510.aspx)
- Nakon instalacije aktivirajte najnormalnije (pisace da je trial)
- Trazite besplatno key za Windows 8 media centar (http://windows.microsoft.com/en-us/windows-8/feature-packs)
- Kada dobijete key (za dan dva stize) uradite sledece:
Swipe in from the right edge of the screen, and then tap Search.
(If you're using a mouse, point to the upper-right corner of the screen, and then click Search.)
Enter add features in the search box, and then tap or click Settings .
Tap or click Add features to Windows 8 and then do one of the following:
Tap or click I already have a product key.
Enter your product key and click Next.
Read the license terms, select the check box to accept the license terms, and then click Add features.
If you were running Windows 8, your PC will restart automatically and Windows 8 Pro With Media Center will be on it.
