- Xeon 5650 (6c/12t) @ 3,7Ghz
- MSI X58
- 48Gb HyperX DDR3 @ 1666Mhz
- Gigabyte 1060 6Gb
- 256Gb 850Pro + couple of AliExpress SSD's
- Zvuk
- Creative
- Zalman ZM600-HP (Heat-Pipe :) )
- Alexander Weiss (glass front + glass side)
- Monitor
- AOC 32" IPS
- Miš & tastatura
- G602 & Drevo 87 key (Red Switch)
- Ostale periferije
- MX Master 2 & K380
- Mobilni telefon
- Moto G9 Plus
- Kablovski internet
Pošto nemam ni 1 DVD preko 4,5Gb, da li je neko probao ovako (sa HDD-a) da instalira W7 (neka nabudžena verzija sa gomilom programa)?
Ili ima neki drugi predlog kako da instaliram Win a da pri tome nemam ni 1 USB flash ili DVD-DL disk?1. Unpack the .ISO with Winrar
2. Copy the whole files on your HDD drive (J:\SETUP.EXE, J:\BOOT, J:\EFI, J:\SOURCES, ....) NOT A SUB FOLDER!
3. ,,cd H:\BOOT" use your Stick not J: = just an example!
4. ,,BOOTSECT.EXE /NT60 H:" make it bootable!
5. Reboot your Computer. Go to the Bios, set the Boot Priority from your HDD/USB drive on the TOP
6. Install the Windows on a clean HDD
7. Boot from it and get some coffee...
8. After the installation is done, follow the instructions on the 1st Time boot.
