Da samo cujem da se jos neko pozali na cenu.
Uz kartu se dobije i drvena kutija sa nVidia logo a to je neprocenjivo:d
A onaj pajser sluzi za otvaranje ..
Sto se tice toga nije ni losa fora 😛
Ja moram opet da se pozalim, gde je sesir indijane dzons? :d...
The only difference between the two setups is the slightly lower speed at which the GTX 690 operates at. Instead of a 1006MHz Base Clock and 1058MHz Boost Clock, it makes do with slightly more pedestrian 915 / 1019Mhz speeds. On paper, this should cause a discrepancy between the performance of two GTX 680s in SLI and the GTX 690. However, there some additional factors which should allow this new flagship product nearly match the performance output of two individual GK104-based cards. We’ll go into further detail about this in our full review.
The real star of this show is the PLX chip sitting between the two GPUs. On past dual GPU cards, NVIDIA used their own NF200 bridge but it was only compatible with a PCI-E 2.0 interface. The PLX PEX 8747 meanwhile is equipped with 48 PCI-E 3.0 lanes, making it a perfect way for NVIDIA to squeeze every last drop of performance out of this design. Of those 48 lanes, 36 are split between the two graphics cores while the remaining 18 are used for the primary interconnect between the GTX 690 and the motherboard’s PCI-E bus. Naturally, the bridge chip is fully compatible with previous PCI-E certifications as well so you won’t have any problem using the GTX 690 on a PCI-E 2.0 or -heaven forbid- a Gen 1.1 compatible motherboard.
Priče o prednosti on card CF/SLI u odnosu na dual card konfiguracije slušamo od postanka ovakvih kartica. Stoga i ovu prihvatam sa velikom dozom rezerve.Prema ovom i jos nekim sajtovima microstutter je maltene eliminisan. Dal je to do novog PLX kontrolera koji je link izmedju dva gpu-a ili je nesto drugo u pitanju ne zna se tacno, ali vise sajtova je detektovalo da je grafika tecnija na GTX 690 vs GTX 680 SLI.
The results of the GeForce GTX 690 have surprised us. Because the frame is distributed from 42 to 29 milliseconds which is again clearly better than in the normal SLI system. Even at 30 frames per second, we can see only a minimal difference to the single GPU configuration, which are so completely playable! In other titles, repeated this result, it is therefore justified not only with the game.
http://www.computerbase.de/artikel/...dia-geforce-gtx-690/8/#abschnitt_mikroruckler
