madVR
peja
v0.81
* added automatic exception catching functionality
* added manual freeze report functionality (press Ctrl+Alt+Shift+Break)
* added option to switch display mode only when media player is in fullscreen
* added option to restore display mode when media player leaves fullscreen
* display mode changer now reacts on film (24p) vs. video (60p) content type
* improved renderer behaviour when display mode changes
* improved ivtc: faster detection of cadence changes
* improved ivtc: more robust against compression artifacts
* deint + ivtc is now auto activated for 60i movies which are tagged to 24 Hz
* ivtc is now auto activated for 50i movies which are tagged to 25 or 24 Hz
* deinterlacing is only turned on for 50i and 60i movies now
* added patch to MS VC-1 decoder -> deinterlacing off
* modified file name tagging logic (24p, 24i, 24fps, 24Hz, etc)
* improved behaviour with decoders which don't output proper interlaced flags
* improved exclusive -> windowed mode behaviour slightly, mainly for ZoomPlayer
* added "sharpness: 100" option for Bicubic scaling
* queue sizes are now always 16/8 by default, no more automatic adjustments
* keyboard shortcuts: always only change things temporarily by default now
* keyboard shortcuts: some changes (not all) can be stored by pressing F2 now
* the source levels (TV vs PC) can be stored now
* the source content type (film vs video) can be stored now
* key presses are now only "swallowed" if media player process has key focus
* osd keyboard handling runs in its own thread now
* added many more languages to the "Pause" MPC-HC message block
* used GPU RAM is now not shown in osd, anymore
* increased upload thread priority slightly
* fixed: ZoomPlayer eventually froze when leaving exclusive mode
* fixed: some users had composition rate in exclusive mode OSD -> problems
* fixed: crash when video window size was reduced to a very small size
* fixed: frame stepping sometimes resulted in weird play/pause mixed state
* fixed: one case where "delay playback start..." resulted in paused state
* fixed: v210 pitch/stride handling was broken
* fixed: YV24 had swapped chroma channels
* fixed: YV24 DXVA deinterlacing resulted in image corruption
* fixed: OSD API didn't capture mouse events on mouse down
http://madshi.net/madVR.zip
Dug je period prosao izmedju 0.80 i 0.81.
Konacno 24fps video radi bez seckanja na 60 Hz monitoru. :)
instalirao ovaj filter u mpc hc x64 ali mi je osencen i ne mogu da ga selektujem za rendering filter. Pomoc?
Moraš da instaliraš 32-bitni MPC-HC.
to sam i mislio. hvala na brzom odgovoru. :)
v0.82.1
* added: new option to activate deinterlacing if in doubt whether it's needed
* added: new IVTC option to only look at pixels in the frame center
* added: IVTC "cadence breaks" information to OSD; resets with Ctrl+R, as usual
* deinterlacing + IVTC are now always forced on for 60i sources tagged as 24Hz
* improved IVTC cadence logic
* improved DXVA deinterlacing behaviour slightly
* improved display mode change event handling
* improved exclusive -> windowed switch a little bit more
* fixed: madVR sometimes didn't notice changed display mode
* fixed: if DXVA2 deinterlacing was not available in XP, it made madVR crash
* fixed: crash when moving madVR to another display with ZoomPlayer
* fixed: freeze when switching subtitles in paused state
* fixed: closing down madVR didn't always wait for the closing to complete
* fixed: closing the media player while madVR was in exclusive mode -> freeze
* fixed: sometimes asking for a freeze report created multiple reports at once
* fixed: MS DVD Navigator caused error in the primaries/matrix auto detection
* fixed: when switching from Bicubic to SoftCubic, options weren't updated
* fixed: red error messages were supposed to disappear after a while but didn't
* fixed: red error messages no longer show duplicate error messages
v0.82.3
v.0.82.4
* fixed: 2 more finalization crashes
* fixed: display mode changer stopped working after a 2nd video file was loaded
* fixed: filter properties dialog didn't show the full madVR version number
Cemu sluze opcije u /rendering/general settings CPU queue size (meni je default 12) i GPU queue size (8) ?
da , mogli bi malo da pojasne sve bitnije opcije - oni koji se razumeju :)
jer sam ja cvakao nesto i nisam bas primetio ni dobitak ni gubitak u kvalitetu.
Šta od ovoga instalirati iz instalacije koja glasi official version release: madCollection.exe?
http://madshi.net/
    50.2 KB · Pregleda: 194
Samo ono što stoji u prvom postu teme. Ta kolekcija nema nikakve veze sa rendererom.
pa gde je onda link za v.0.82.4
U prvom postu.:) Ime arhive je uvek "madVR.zip" i na tom linku je uvek poslednja verzija.
Interesantno nisma se sreato sa takvim linkom do sad, šta bi bilo da neko hoće stariju verziju.
I recimi molim te šta je ono u exe formatu
v0.82.5
* improved D3D11 exclusive -> windowed switch slightly, still not great, though
* option "delay playback start..." now requires both GPU+CPU queues to be full
* fixed: YCgCo decoding matrix was not correct
* fixed: internal 4:4:4 decoding produced wrong colors (introduced in v0.81)
* fixed: display mode changer didn't always activate when entering fullscreen
* fixed: forcing deinterlacing + IVTC on was caused by 30p tag instead of 24p
* fixed: h264 media type parsing sometimes crashed
* fixed: crash when no filter in the chain provided frame rate information
* fixed: one thread was started per video frame (introduced in v0.82)
* maybe fixed: entering/leaving exclusive mode steals keyboard focus
Al je vredan. :) Imao je duzu pauzu posle 0.80.
Hebat ga, ako njega izaberem ondam mi MPC necita prevode nikako.
Kako to? Ranije si morao da koristi VobSub, ali od nekoliko verzija unazad normalno rade titlovi.
Nemam blage veze, stavim na Halli render i sve radi normalno, vratim na madVR nema prevoda, nema veze to mi je ionako informativno jer koristim KM player, ili stacionarni Blu ray za filmove.
Ja uradih sve po ovom uputstvu i kad dodjoh do treceg koraka iliti provjere, daje mi 'incorrect' varijantu, iako sam sve stavio kako treba.
Evo ovako:
    291 KB · Pregleda: 147
To je incorrect samo za hi10p fajlove.
