Rainbow Six: Patriots
nex999
Moderator
Super Moderator
CPU & Cooler
Core i9 14900KF*Noctua NH-D15
Matična ploča
MSI MAG Z790 Tomahawk WiFi
RAM
Corsair Vengeance DDR5 64GB 6400MHz
GPU
Asus TUF RTX4090
Storage
2x 2TB Samsung 990 PRO NVMe M.2
PSU
Corsair HX1500i
Kućište
NZXT H7 Flow
Monitor
LG Ultragear 27GS95QE-B, LG CX
Rainbow Six Set to Invade New York With Home-Grown Terrorism
A new interpretation of the classic Rainbow Six, the tough-as-nails tactical shooter that asked gamers to carefully plan out the nuance of a breach like a choreographed dance, is in the works, a source familiar with the unannounced Ubisoft shooter tell Kotaku.
We've also heard that the game will in many ways be a departure from the sameness found in Rainbow Six: Vegas and its sequel, and a return to what helped separate the shooter from others of its ilk.
It's unclear if the in-development game will be shown at E3.
The original Rainbow Six is more tactical and focused on stealth than on weapons. Before each mission, in those early games, players were asked to view a briefing and then build a team, pick their weapons and equipment and finally create waypoints that the secondary members of the team would follow. Once the mission started, players had only control of one team member at a time.
Rainbow Six will be a far more story-driven game than previous iterations of the Tom Clancy branded title. The game is meant to take a step in a different direction, telling a bigger, much more gritty cinematic story than previous versions of the game.
In this still-to-be-titled Rainbow Six, players will be tasked with stopping a homegrown terrorist group operating in America. The group, fed up with the greed of Wall Street and the government that acts to protect them, decides to target New York City.
While the gameplay is based on some classic Rainbow Six mechanics, there is a cover system that takes you out of the first-person perspective and into the third.
A new icon-rich graphics style helps to highlight members of your team during a mission and other pertinent information.
BIGGER MUCH MORE GRITTY CINEMATIC STORY
:d
Da, da ...sucks, carrot on a stick, streamlined...
Igra nije cak ni najavljena al ajde da je sahranimo, cisto reda radi
Ne, ne. Slova moraju biti VELIKA da bi ja to mogao pročitati zavaljen u fotelju kao i svaki drugi vrhunski hardkor gejmer.
Mislim stvarno, kakva opasna filmska priča u Rejnbou Siksu. Šta će od četvorice specijalaca dvojica da budu Tihi i Prle iliti Kane & Lynch?
Samo komentarišem na opsnovu dostupnih informacija tj. teksta koji si okačio a koji kaže:
Kada si otvorio ovu temu ljude su podelio na dve grupe. Jedni su oduševljeni što izlazi nastavak popularne igre (iako nemaju pojma zašto je popularna) i apsutno im ne bi smetalo da igra funkcioniše i izgleda kao Conviction. Druga grupa se (bez osnova) nada nastavku Rainbow Six-a kakav je bio u prva tri dela.
Cenim sposobnost Amerikanaca da oko specijalaca naprave filmsku priču kao što su uradili sa onim SASovcima što su (navodno) ubili Osamu Laden Bin-a. Ali zaista jednoj igri to ne treba. Treba samo ono što posao specijalaca čini dovoljno zanimljivim da se oko toga pravi video igra a to nije ******* personaliti nekog od njih.
Šta je sledeće, SWAT 5 koji prati živote dvojice najboljih prijatelja koji su izgubili dvojicu dugogodišnjih saboraca, kako se oni nose sa gubitkom, kako piju, kako tuku žene. Naravno pošto treba da ih opet bude četiri u timu, dodaju im dvojicu junoša sa kojima će oni imati zaeban odnos koji će kulminirati neraskidivim prijateljstvom. Na kraju će se obračunati sa čovekom zbog koga su ona prva dvojica mrtvi, opsovati mu mater uz još koji oneliner, na kraju išetati iz zgrade mašući USA zastavom...
Hoću bre taktiku, neću Holivud!
Sta god da je pisalo u onom tekstu gore, ista bi stvar bila. Makar pisalo i da je igra najtaktickija u svemiru, isti klinac. Nasla bi se vec jedna ili dve reci oko koje bi opljunuli...ja bi ipak malo sacekao da vidim i cujem sta je ovo zapravo i da li ce zaista najaviti igru uopste. Pa onda da vidim nesto konkretnije...
I da - SEALS su ubili 'Ladena a ne SAS, dakle GTFO :p
I na kraju se ispostavi da jedan od ove dvojice mrtvih u stvari nije mrtav, već je prešao na tamnu stranu, i da je morao ubiti drugog koji je bio blizu da ga raskrinka. :D
Mozete i malo Em Najt Šamalamalamlamjana, pa da se ispostavi da su terori u stvari bili kanteri...
Btw, SWAT 5 ne bi imao smisla ni sa kakvom pricom, jer u njemu su casual genericki panduri u pitanju i sama prica zavisi od mape do mape gde se odvija situacija, tako da se vise i ne bi zvao SWAT, a u R6 su Klensijevski patriotski heroji u pitanju tako da je svakakva prica moguca. I da, SWAT je igra u kojoj pucanje gotovo ne sme da se primenjuje, tj. mozda je jedini fps u kome se pucanje kaznjava, s`toga ga i to dosta deli od R6.
Ne moze Niko Belic da divlja po New Yorku, i baja u nano odelu da prasi vanzemaljce a da to bude bez "specijalaca" pravih patriota.
Nisam sad skonto koji je ovo R6, Vegas ili neki drugi, Lockdown, Ghost Recon..
Ovo bi vec trebalo da se reimenuje u Rainbobw Six: Patriots...
Igra izlazi 2013-te a vise o igri u decembarskom izdanju gameinformera....
Inace, evo prototype video kako je igra zamisljena, mada ne sumnjam da nece da bude daleko sa ovim wallhackom koji vec postaje moderan feature u igrama. :D
Ovo odlicno izgleda, koliko vidim ima dobru pricu... ali sve je pod znakom pitanja da li ce igra uopste ovako izgledati.
Sa intervjuom.
[video]http://www.gametrailers.com/video/gameplay-interview-rainbow-6/724456[/video]
Pa ko je jos video da igrac mora da pazi sta radi?! Lepo ukljucis sonar goggles (Splinter Cell: Conviction) ili poznatiji i kao Intuition (Hitman: Absolution) i vidis kroz zidove, kola, nuklearne reaktore, nebitno....
Sa intervjuom.
Da nije bilo SexBoxa mi bi danas igrali ovakve igre a ne bi bilo samo "kako je igra trebalo da izgleda".
Stvarno su konzole žešće unazadile igre, samo pogledajte te animacije i osvetljenje pa onda podgledajte nove "hitove".
zasto se zaustaviti tu , verovatno su konzole krive i za krizu u svetu , opstu depresiju , pink i grand , Borisa Tadica... :d
E jes vala, si vido kad su hakeri povukli svoja sredstava sa Soni plejstejšna, kako je Kriza opalila Japan. :D
