ERROR "the application was unable to start correctly (0x0000142)" WIN 7
louderick
pojavljuje mi se error "the application was unable to start correctly (0x0000142)", kad kliknem na npr VLC ili win media player ili na dosta drugih aplikacija.... sumljam da mi se to desilo posle jednog naglog force restarta ili sl.... kako da resim ovo, a da ne radim sa restore point jer mi izlgleda on nije bio ukljucen... :(
molim za pomoc.
Probaj ovo:
Hi,
Welcome to Microsoft Windows 7 Answers Forum!
To troubleshoot this problem you can follow the steps provided below.
Try performing SFC scan on the computer.
1. Click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are
prompted for an administrator password or for a confirmation, type the password, or click Allow
2. Type the following command, and then press ENTER: sfc /scannow
[The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.]
A message will appear stating that 'The system scan will begin'. Be patient because the scan may take some time
3. If any files require a replace SFC will replace them. You may be asked to insert your
Win7 DVD for this process to continue
4. If everything is okay you should, after the scan, see the following message "Windows
resource protection did not find any integrity violations"
5. After the scan has completed, close the command prompt window, restart the
computer and check.
Check the below mentioned link for further guidance on SFC scan –
http://support.microsoft.com/kb/929833
Here you may try disabling the security software on your computer and check if the issue gets fixed.
Thanks and Regards:
Suresh Kumar- Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
hvala mmsandi- probao- nije pomoglo.... :( procesljao sam malo net i nasao par stvarcica i pokusao (izmedju ostalog i ovo) i dzaba- :(
Probaj novi drajver od graficke, posto vidim da te plejeri zafrkavaju.
