illidan
- Bike Camper -
- amd 5800x3d, cm atmos 240 - phanteks t30
- asus rog strix b550-i gaming
- g.skill trident z neo 32gb cl16 3600
- nvidia rtx 4070super founders edition
- samsung 980 pro 1tb, wd black sn770 2tb
- Zvuk
- ifi zen dac v2 - fosi audio za3 - kef q350, fiio ft1, all balanced
- corsair sf750 platinum
- lian li a4 h2o
- Monitor
- gigabyte mo27q28g
- Miš & tastatura
- g-wolves hts plus pro 8k, kbd.fans tofu65 raw alu - cream soda switches - gmk serika 2 keycaps
- Optički internet
Opera Wahoo
Now, 8 days since Opera Swordfish is successfully hunting out in the deep, warm waters, with more than 32 000 000 downloads, we would like to use the opportunity to thank you all for the excellent help and support in making Opera 11.50 our most successful release ever!
And since the weather outside of Opera’s HQ is somewhat tropical (relatively warm, with pouring rains), our developers were able to catch one of the fastest tropical fishes in the world So today we are happy to present you with the very first snapshot of our next major release, codenamed Wahoo (what will eventually become version 12). It’s currently in its embryo pre-alpha state and only includes some important bug fixes and overall polishing, with all the fresh and juicy stuff coming a bit later
Changelog
Desktop
DSK-339958 Align scrolling for document and scrollbar; and to other browsers
DSK-338150 Freeze on dialogs and address field input
DSK-320065 Widget upgrade via mainmenu stalls
DSK-340326 Crash when dragging a button from the Appearance dialog onto the Tab Bar
DSK-285866 Missorting of incoming mails, news and feeds
DSK-341109 Selecting search suggestion using keyboard difficult because the first search engine is focused by default
DSK-340665 Impossible to manually resize Speed Dial if custom number of columns is set
DSK-340975 Move Widgets menu next to it's brethren in the Tools menu
DSK-339779 Opera fails to start when search.ini points to invalid default search engines
DSK-339618 No Speed Dial page opened after Deleting User Data: Close all tabs
DSK-326870 Widgets without a <name> are treated as invalid
DSK-333610 Text on the button at error page in Asian languages is vertically: fixed again
Windows
DSK-337352 Make the Windows Installer able to continue after non fatal errors
DSK-322534 Cancelling uninstall triggers Windows compatibility assistant in Vista
DSK-331939 The text "By clicking on "Accept and Upgrade" in the Install jumps when clicking the TOS and back
DSK-333343 Right clicking and pasting into UI fields when they are not focused yields ghost text
DSK-340699 Low performance on windows while relayouting extensions manager
DSK-340494 Crash on exit
DSK-337892 Opening a panel with Content Block Toolbar present, the block content overlay gets stuck and the toolbar disappears
DSK-317904 Change to new Plugin event API
Mac
DSK-340209 Files from Finder open in background tabs
DSK-339539 Links from external applications open in background tabs
DSK-226117 Links that open new tabs from pages with click event listeners will open tab in background
DSK-340688 Crash when opening Dragonfly
DSK-340163 Some select lists have no scrollbars on Mac
DSK-340536 Hovering over collapsed access point in new mail panel while in drag state should expand the access point so you can continue dragging to a view
DSK-232496 Form widget inside container with opacity, painted beneath the container
DSK-340489 Dialog tabs not aligned in Preference Dialog for Japanese language
DSK-337995 Accept-Language header contains duplicate entries for en-US
DSK-340525 Disable smooth scrolling on Mac
Linux/FreeBSD
DSK-339973 The status bar dissappears if you show menu bar
DSK-312270 Selecting all text on a page causes it to be copied to the clipboard.
DSK-332212 Opera doesn't respect opera:config#UserPrefs|PageBarOpenURLOnMiddleClick setting
DSK-339553 Wrong border width for popup menues (KDE)
DSK-336895 Window background in KDE incorrect: further fix needed for tab bar
DSK-339569 Wrong background color / effects for (hovered/disabled) popup menu buttons (KDE)
DSK-339915 Popup menu indicator arrows are poorly styled under KDE
WARNING: This is a development snapshot: It contains the latest changes, but may also have severe known issues, including crashes, and data loss situations. In fact, it may not work at all.
Windows
Mac OS
Linux
