Kinpad I600 - kapacitativni ekran, SIM slot, 2.2 = win
Igoritza
Banned
Banovan
upravo mi je Diehard poslao klip, u pitanju je kineski tablet - Kinpad I600
Freescale IMX51 800MHz ARM Cortex A8
Android 2.2 Froyo, Flash 10.1
Memory 512MB DDR2 Ram, 8GB Nandflash built in
Extend Memory up to 32GB via micro sd card
Screen 8″ Capacitive Multi-touch
1024*600
Audio
Power Amplifier: CODOEC+Class DX2
3.5MM headphone jack
Built in Microphone
Supported Audio Formats: MP3, WMA, AAC, WAV
Video
Support MKV (H.264) RMVB/MPEG-4/FLV
Features and highlights
Android 2.2 Froyo
Built in 3G WCDMA UMTS/HSDPA (2100MHz), GSM/EDGE (850,900,1800,1900MHz)
Bluetooth 2.1+EDR (ability to make calls)
Microphone support
Freescale IMX515 800MHz ARM Cortex A8
Gsensor
Light Sensor
Front Fascing camera
Built in GPS SiRF3
USB port
Standard 30-pin port (supported by many devices)
Wi-Fi (802.11b/g)
Excellent Ebook reader
Internet browsing, HD Video, Lnline Music, Map, Real-time communications
Flash 10.1, access all flash websites and online flash games
7″ size perfect to bring with you anywhere
Slim body
3.5mm audio jack
HDMI out
USB port
Built in Battery 4200mAh
Dimensions
197*126.5*13.8mm weight: 0.350kg
Camera Dual cameras: Front facing 0.3 MP, back side 3MP
Battery Built in Battery 4200mAh
Package Content
Kinpad I600
USB cable
Power charger
HDMI cable
Earphones
[youtube]NdxmuP5meI8[/youtube]
7'' tablet telefon. :)
kada se udje u sys info, pise da je AMD zapravo supplier grafickog chipa, tako je i potpisan, pa ostaje misterija dal su ikada freescale i AMD saradjivali, kako rece ovaj na klipu, jesu nesto 2007.
u svakom slucaju, ovo je za sada najbolji 7moinchni tablet, koji u kvalitet/cena varijanti dobija protiv galaxy tab-a i njegove nenormalne cene.
cena je takodje misterija, jer Shanzai.com dodje kao neki reseller kineske robe, i pumpaju cene u nebesa. cena ovog uredjaja je 250 evra, ali daleko od realne, sobzirom da merimobiles i shanzai prodaju Flytouch2 po ceni od 200 evra bez troskova slanja.
Koliko su dugotrajni (ili kratkotrajni) ovi uredjaji? Jel mogu da preteraju koju godinu uz koriscenje od po par sati nedeljno? Nedeljno.
ne bih znao da ti kazem, jer su ovo sve novi uredjaji. ja imam Flytouch2 koji je besprekoran, odnosno za 3 meseca koriscenja konstantnog, nit je oslabila baterija, nit se "rasklimao". a do sad je pao niz stepenice, i sednuto je na njega.
Taj Kinpad I600 sam tražio ranije i nije ga bilo. Merimobiles ga je držao(i još uvek drži) na pre-order statusu, a cena koja se vrtela je bila USD 400.
Igorizte trebao si u prvom postu malo vishe hypeovati da ima sim slot i full GSM mogucnosti [SMS i telefoniranje]. Ipak, to je jedina osobina koja ga najvishe izdvaja od mora slicnih tableta.
pa, rekoh - moze da primi SIM, zato i jest fenomenalan, jer oogucuje pricanje i 3G internet bez budzenja! :D
evo poredjenja:
1. CPU: Samsung ima Hummingbird koji je 45nm, i stize klokovan na 1Ghz. svakako bolji od ove revizije Freescale-a na Kinpad tabletu. oba uredjaja imaju graficki procesor, bez daljih opisa moze se sa sigurnoscu tvrditi da je onaj u Galaxy-ju brzi.
2. Ekran: Kinapd zapravo ima multitouch sto je za svaku pohvalu. ne treba trositi reci za samsungove displeje sobzirom da je u tom poslu 20 godina, ali treba napomenuti da je lom ekrana na Kinpadu svakako manje opterecenje nego eventualna ista stvar na Galaxy-ju. oba ekrana imaju kapacitativni digitajzer.
3. sve ostale mogucnosti su zapravo - iste. uz napomenu da Galaxy tab ima jos i Bluetooth 3.0 dok Kinpad ima 2.1. isti su 3G standardi, isti je Wifi standard, flash support na oba modela ... naravno, treba znati da je ovakvo poredjenje cisto radi odnosa u cenama, jer je svaka od komponenti na galaxy-ju pravljena kvalitetnije od kineskog hardvera.
Kinpad i600 - ~250 evra.
Galaxy Tab - 1000 evra.
3G je super, mada po mom mišljenju to se podrazumeva da tablet danas ima, tablet bez 3Ga ne bih ni uzimao u razmatranje jer to dalje iziskuje petljanje sa USB modemima koji pitanje da li i kako rade na tabletu. GSM je, sa druge strane, krajnje nepotebna mogućnost koja samo poskupljuje uređaj. Ne vidim svrhu toga kad svakako svako nosi mobilni telefon gde god da krene. :)
pa, kako mislis da imas 3G bez GSM-a ? mislim, moguce je to napraviti, ali kad je vec tu 3G, sto da ne iskoristis karticu u polozaju ? elem, za poslovne ljude je na GSM tabletima opciono bluetooth pricanje, dok tablet stoji u kolima/ofisu/slicno. a i ne dize mu to cenu ne znam sad kolko, telefonska mogucnost nakalemljena na maticnu plocu je danas jako jednostavan proces
Verovatno si u pravu da ne poskupljuje uređaj (puno) jer je potrebna elektronika već tu, mada treba softverski to sve podržati i ispleglati... ali, sa druge strane, nije ni mogućnost vredna hvale. Razgovor putem BT je moguć i preko mobilnog koji je svako na stolu/džepu, zar ne?
da, al gledanje pornica na lanch pauzi u veceu nije toliko efektivno na mobilnom, ko sto je na tabletu .. ? ;) u prevodu - sve ima svoje :)
Ili jednostavno mozesh da povucesh net preko wifija na mobilnom, koji ti je u dzepu uvek :)
A inace, uskoro ce se kineski tableti po ceni klati sa iPad kecom :d
driver - standard Apple trovanje ? :) i ja jos namerno izvucem sa samsungovim proizvodom paralelu, valjda zato sto su slicni, ali avaj ...
prvo - ipad1 se povlaci, te ce ga biti u prodaji mnogo manje nego sto je recimo sada u opticaju iPhone 3G, jer je u pitanju tablet, a ne telefon. moci ce za manje od 2-3 meseca da se kupi samo polovan.
drugo - kinezi prave sasvim solidne uredjaje koji su po svemu ekvivalent brendiranim imenima, osim po snabdevachu sofisticiranog hardvera (cpu/gpu). kolko para toliko muzike. oces da bacimo po 100 evra u opkladu da ce ovog datuma 2012, izaci kineski tablet koji je po svemu superiorniji od bar jednog od 4 - blacberry, Apple, samsung, toshiba ? znaci, govorim o svemu bukvalno, do same plastike u tom tabletu i kvaliteta izrade.
The manufacturer confirmed that the device does not have any GPS antenna and related source codes in the software due to copyright issues. The system has to use Wi-Fi or 3G for internet connection and has to connect to google maps for the positioning function. This device does not support navigation function.
imate celu temu na androidtablets
