Debian 6 ("Squeeze") released
Ace Rimmer
VIP član
After 24 months of constant development, the Debian Project is proud to present its new stable version 6.0 (code name "Squeeze"). Debian 6.0 is a free operating system, coming for the first time in two flavours. Alongside Debian GNU/Linux, Debian GNU/kFreeBSD is introduced with this version as a "technology preview".
Debian 6.0 includes the KDE Plasma Desktop and Applications, the GNOME, Xfce, and LXDE desktop environments as well as all kinds of server applications. It also features compatibility with the FHS v2.3 and software developed for version 3.2 of the LSB.
Debian runs on computers ranging from palmtops and handheld systems to supercomputers, and on nearly everything in between. A total of nine architectures are supported by Debian GNU/Linux: 32-bit PC / Intel IA-32 (i386), 64-bit PC / Intel EM64T / x86-64 (amd64), Motorola/IBM PowerPC (powerpc), Sun/Oracle SPARC (sparc), MIPS (mips (big-endian) and mipsel (little-endian)), Intel Itanium (ia64), IBM S/390 (s390), and ARM EABI (armel).
Debian 6.0 "Squeeze" introduces technical previews of two new ports to the kernel of the FreeBSD project using the known Debian/GNU userland: Debian GNU/kFreeBSD for the 32-bit PC (kfreebsd-i386) and the 64-bit PC (kfreebsd-amd64). These ports are the first ones ever to be included in a Debian release which are not based on the Linux kernel. The support of common server software is strong and combines the existing features of Linux-based Debian versions with the unique features known from the BSD world. However, for this release these new ports are limited; for example, some advanced desktop features are not yet supported.
Another first is the completely free Linux kernel, which no longer contains problematic firmware files. These were split out into separate packages and moved out of the Debian main archive into the non-free area of our archive, which is not enabled by default. In this way Debian users have the possibility of running a completely free operating system, but may still choose to use non-free firmware files if necessary. Firmware files needed during installation may be loaded by the installation system; special CD images and tarballs for USB based installations are available too. More information about this may be found in the Debian Firmware wiki page.
Furthermore, Debian 6.0 introduces a dependency based boot system, making system start-up faster and more robust due to parallel execution of boot scripts and correct dependency tracking between them. Various other changes make Debian more suitable for small form factor notebooks, like the introduction of the KDE Plasma Netbook shell.
This release includes numerous updated software packages, such as:
* KDE Plasma Workspaces and KDE Applications 4.4.5
* an updated version of the GNOME desktop environment 2.30
* the Xfce 4.6 desktop environment
* LXDE 0.5.0
* X.Org 7.5
* OpenOffice.org 3.2.1
* GIMP 2.6.11
* Iceweasel 3.5.16 (an unbranded version of Mozilla Firefox)
* Icedove 3.0.11 (an unbranded version of Mozilla Thunderbird)
* PostgreSQL 8.4.6
* MySQL 5.1.49
* GNU Compiler Collection 4.4.5
* Linux 2.6.32
* Apache 2.2.16
* Samba 3.5.6
* Python 2.6.6, 2.5.5 and 3.1.3
* Perl 5.10.1
* PHP 5.3.3
* Asterisk 1.6.2.9
* Nagios 3.2.3
* Xen Hypervisor 4.0.1 (dom0 as well as domU support)
* OpenJDK 6b18
* Tomcat 6.0.18
* more than 29,000 other ready-to-use software packages, built from nearly 15,000 source packages.
Download:
http://www.debian.org/releases/squeeze/debian-installer/
Dobro su se setili:d
Promenili čak i sajt.
Probao sam testnu gnome 6 i nisam baš bio oduševljen, nadam se da je sad mnogo utegnutiji
I interesujeme kakav je na FreeBSD kernelu
p.s.
politika tzv. slobodnog ili preciznije rečeno robovlasničkog softvera ovog puta je prevazišla sve prethodne distribucije, preterivaje samo tako
p.s.
wtf?
pa dobro, ima sve šta treba u non-free repoima.
Probao, posle testnih upgrade-ovao sam neke manje bitne i manje kriticne servere, tek da se vidi da li ce se javiti heavy problemi. Sve je proslo glatko, osim sto je update freeradiusa iz nekog razloga obrisao softlink ka defaultnom sajtu te sam morao da ga rucno vratim. Drugaciji ishod nisam ni ocekivao obzirom da me apt do sada nikada nije 'izdao' :)
Za sada deluje ok, sve se vrti onako kako treba, uvedene su i neke bazicne promene koje treba pozdraviti - dependency-based boot lepo radi, grub je konacno penzionisan te je zamenjen sledecom inkarnacijom - grub2 i sl. Vidim da je i kernel detaint-ovan odnosno izbacen je sav non-free materijal tako da treba biti pazljiv prilikom apgrejda - ukoliko se koristi neki blob drajver obavezno instalirati i firmware-linux-nonfree paket.
p.s.
Ako ti se ne svidja a ti onda nastavi da 'kupujes' proprietary softver na demonoid.com-u i thepiratebay.org-u.
Slažem se ali ići tako daleko i izbaciti apsolutno sve, ona glupost sa promenom imena FF je smešna u odnosu sa sadašnje stanje kad su drajveri recimo u pitanju
Zamolio bih te da ako baš nemaš šta pamatno i konstruktivno da kažeš po pitanju ove problematike da se suzdržiš od jadnih pokušaja vređanja i iznošenja još jadnih optužbi
Ako ti ne razumes zasto je nekim ljudima bitno da imaju potpuno 'cist' sistem, ja ti tu nista ne mogu. Nije da ne postoji izbor - ono sto je namerno uklonjeno, namerno mozes i da vratis.
I gde si se, molicu lepo, toliko uvredio? Hoces da kazes da ne koristis piratizovan softver koji si nabavio ko zna kako, a najverovatnije preko mula/torenata/rapidsera? Drombuljas o 'robovlasnickom softveru' i ocekujes da ti niko ne odgovori u slicnom tonu? E pa nece moci.
Evo i meni smeta
Izbacen firmware i kako onda da ja koristim wireless na laptopu, sa cim onda da skinem potrebne fajlove odnosno firmware da bi mi adapter proradio? Reboot u Windozu, rucno ganjanje depova ili da razvlacim 15m kabla do rutera u sledecoj sobi i svucem to preko etherneta? :S:
Moze, ali je pain in the ass
Wifi nic firmware bi instalirao isto onako kao sto bi instalirao i drajver za windows - skines sa neta odgovarajuci drajver (paket sa blobom) te ga doinstaliras naknadno na sistem. Blobovi nemaju divljacke dependency zahteve u sta mozes da se uveris sa apt-rdepends. U slucaju upgrade-a cak ni ovaj problem ne postoji - dobije se poruka da odredjeno parce hardvera zahteva firmware koji se nalazi u tom i tom paketu te ostaje samo da ga doinstaliras pre reboot-a odnosno finalizacije apgrejda.
Kucnim korisnicima koji rade frisku instalaciju jeste pain in the ass, ali debian nije njima ni namenjen; tu je mint, ubuntu, koji-god-ubuntu-flavor-of-the-week.....
Nije to samo stvar filozofije vec i jako pragmaticnih stvari, pre svega stabilnosti i sigurnosti.
Ne bi se bas slozio da Debian nije dobar distro za kucnu upotrebu jer u repoima ima zaista sve sto coveku padne na pamet - a i sto nema, ima u Debian Multimedia ;)
Jesu pojedine verzije paketa malo matore ali makar rade svoj posao kako treba :)
Ajmo please da se držimo teme. Ovo je jedna od čistijih i kulturnijih soba na forumu, pa bih vas molio da tako i ostane. Bez ličnih kvalifikacija i sličnoga. Hvala.
Mladeniuse nije to do repozitorijuma vec do (uslovno receno) sitnica od kojih je jedna bas ova koja tebi smeta - naknadna instalacija binarnih blobova.
To je jednostavno - debian; user experience je stavljen u drugi plan a ide se na stabilnost, sto je moguce siru hardversku zastupljenost i apsolutnu nezavisnost od bilo koje korporacije. Zato je stable repo 'mator', zato se izmestaju blobovi, zato se po defaultu kodeci i 3d drajveri ne nalazi u stable repou, zato je debian relativno skoro dobio graficki installer (godinama posle user-friendly distroa), zato je ovo tek sesta verzija debiana iako je jedna od najstarijih linux distribucija itd.
Kome to ide na zivce bolje je da koristi neki od brojnih debian derivata.
Naravno, iskusni linux korisnici mogu uvek da sebi podese debian tako da bude rame uz rame sa tzv. cutting-edge distroima ali potreban je odredjen trud i vreme; kome se zuri/ko ne zna - ima alternativa koliko god zeli.
Probao sam xxx distroa, ali sam se uvek vraćao na debian! Jednostavno, kod mene on radi kao singerica.
A kome je do novijih paketa, pa on neka tera testing granu debiana.
Kod mene u sources.list-u i onako konstantno stoji testing.
Kakav crni testing, za ljude koji vole da zive na ivici tu je unstable aka debian sid :)
Aaa, jook ja! Nemam ja više vremena da se nonstop zezam sa sređivanjem linux-a.
Debian testing je, onako, baš po mojoj meri. Dovoljno stabilan, sa relativno novim paketima!
Debian rula! Vrtim ga na serverima na dve lokacije... Mnogi govore kako je CentOS bolji ali po statistici u zadnjem periodu Debian je ponovo najpopularniji serverski OS na Netu.
Koristim ga cak na DEC Alpha platformi, ali Lenny...
Squeeze moze da radi i na IA-64 sto postaje retkost jer su svi digli ruke od Itaniuma :d
