Magick
  • Začetnik teme Začetnik teme Alex
Po zavrsetku instalacije postoje opcije da instaliram to dvoje, ali odmah izbaci gresku! Sad cu pokusati ponovo.
Unable tu execute file
D Program files/Paradox Interactive/Magicka/ Directs_feb2010 Setup/DXSETUP.EXE
Create proces failed Code 740
i pise jos nesto ipod...
EDIT: Uspeo sam instalirati ovo dvoje ali iz Directorijuma igre! Sad radi noramlno(bar zasad) Hvala
Ja sam uspeo da zavrsim avanturu sa update 4... radio je 1. sve do pred kraj i tu je pocelo da zapucava... Lepo su me namucile neke table. Ne da tek tako da se protrci kroz igru...
Ako instaliras igricu da li su ti potrebni svi pechevi ili samo zadnji da stavis i to je to,tj. radice ok?
Sto se zahtevnosti tice...
Q: But my IGP should be able to run the game!
A:Remember that laptop versions of graphic cards have noticeably worse performance than non-mobile ones. A 8800M is NOT as good as a regular 8800.
Q: But I can can run Starcraft 2! Why not a little game like Magicka?
A: The fine folks at blizzard have dozens and dozens of engineers who've consciously made the effort to optimize the game to run on low end machines.
The arrowhead team, while also fine, consist of 7 developers. Of which 2 are programmers. 🙂
When the choice came between additional gameplay features and optimize performance on IGP's we chose the former.
What would you have chosen in our position?
Q: But I can play Crysis with this IGP! Why not Magicka?
A: Again, Crytek probably have even more engineers working on the engine than SC2.
http://forums.steampowered.com/forums/showthread.php?t=1739863
pomagajte. zaglavio sam se na nivou. ne znam tacno koji je. mislim da je cetvrti. pocinje kao film 300 "this is madness. dosao sam do zaledjene reke i ubio sam sve koji su dosli, ukljucujuci i dzina koji puca iz topa, i ne mogu nista vise da uradim. ne pusta me van tog ekrana.
probao sam da se ubijem pa da uradim opet i nista. uvek me zaglavi tu. ne bih da prelazim ceo nivo iz pocetka da bih opet imao problem.
...secam se te zaledjene reke i nisam tu imao problem... tu sam imao update 1.
I meni se to desavalo... Ali shvatio sam da nisam ubijao jednog, tj. jedan se zagubi van ekrana. Ali sreca pa sam imao staff za summon te je drvo otislo i odradilo posao 😉
Kad vec to spomenu, imam onaj "stap" koji moze da "summon tree" kako to da uradim? Je l' postoji komanda ili samo se stvori?
middle mouse button. moras da se "oslobodis" svih elemenata pa da kliknes. ako imas neki element onda ga na middle dajes sebi.
koliko je jako to drvo. meni je za sada najbolji onaj stap sto regenerise zivot. dam sebi stit i onda ga stap odrzava. u principu je to dupli health.
inace ispravka mala, nije cetvrti nego peti nivo na kome sam zaglavio. probacu da instaliram patch 5 pa da predjem opet.
edit: mnogo glupo pitanje. odakle da skinem update? nigde ne mogu da nadjem. vidim na forumima changelog, ali ne mogu da nadjem glupi link. ne igram preko steama tako da mi treba exe varijanta. nadam se da update nije samo za steam.
Hvala, uspeo sam!
na 4 chapteru sam, je l' da cuvam ovaj m60 i summon tree, ili ima sta jace?
Pa m60 je overpowered mnogo, ja sam ga bacio, tj ne ja, nego sam ubio ortaka pred novi chapter i prešao u drugi i ostao mu tamo m60 😀
poceo sam nivo iz pocetka i presao zaledjenu reku. cimam se ja tako do kraja i dodjem do khana i bijem se pola sata i ginem konstantno. posle pola sata taman sam dobro krenuo i skinuo mu skoro sve hp i igra crashuje.
nece me nivo nikako.
koja je fora sa onim elementom potrebnim za meteor shower i slicne? gde se on nabavlja ili kako se koristi?
nista. to je para. tek sam sad uspeo da provalim
Malo pomoci oko igre ko nije dosao i presao 10-ti nivo nek ne cita...
Kako se ubija na 10 nivou (smrt) crni mag sa kosom nemogu nikako da se odbranim od njega a i nisam nasao trik ni kako da mu trosim energiju osim da bezim sa hastom od njega
@B-ZiGER
e(stit)-w(heal)-drzish shift(male)-desni klik...😉... smrt nije otporna na tvoje heal nagazne mine, tj. tebi pune zivot , a smrt ubijaju... 🙂
Je l' se kroz celu igru ide potpuno sam, ili ce nekad da mi se pridruzi neko? Sve vidjam klipove po 3-4 wizarda idu zajedno.
Jeste dobro sto je izasao update 6, ali je i smesno, neverovatno kako uspevaju da u roku od 15h toliko stvari isprave od update-a do update-a.
Mene zanima da li je neko od vas uspeo da namesti mulitplejer,tj da nekako sa ortacima igram u cetvoro,video sam da moze ali kad god krenem da kreiram igru,igra me izbaci na desktop.
Update 7 izasao, malo preteruju svaki dan skidam novi update doci ce do updatea 20 kako su krenuli.
kako da se lecim dok imam vlad's gauntlet? mislio sam da ce biti ekstra predmet, ali zapravo i ne radi puno. do sada me niko nije napao koristeci arcane i jedino sto sam sada primetio je da umesto da me zivot leci zapravo me ubija. i ovaj life drain mi se ne cini bas kao neka magija. izgleda da cu se opet vratiti na life staff jer jedini radi bar nesto sto mi treba.
btw, sta vi koristite od oruzja i magija?
sto se magija tice, ja sam na steam, steam, steam, arcane, lightning i onda "pucam" kao beam za udaljene i jake i kao blast za sve ostale. tu je i led,led,led,lightning. to koristim kao brzi shotgun. bindovao sam na dugme na misu tu kombinaciju pa samo resetam.
...od 8-9 lvl*a nisu bitni staf i male oruzije... ide struja, para, laser, stit, heal, shift i tako to... kombo😛
Auuu ljudi što je ova igra dobra! 🙂
Igrao sam celo veče sa ortakom. On na mišu i tastaturi, ja na gamepad-u. Definitivno nije igra za soliranje, mnogo je zabavnije kada vas ima barem dvojica. Kombinovanje zraka, međusobno lečenje i vraćanje u život, ofanzivno/defanzivne kombinacije, ma sve je mnogo mnogo bolje 😛
Imam problema da pokrenem igru..kad kliknem na exe ikonu, samo mi se pojavi objasnjenje da igra nece da se startuje i da mogu da potrazim resenje preko neta i da je ugasim. instalirao i .net i dx i onaj xna ili kako god..al i dalje nece.
