Zaboravili ste da napomenete ako se iskljuci skroz Virtual memory svaka igra ce da zabode na desktop.
Ovo nije tačno, na XP-u sa 4GB i na W7 sa 6GB mi nikad nije pukao ni jedan program ni igra, a Virtual Memory je oduvek isključen. Ne znam kako je na W7 sa 4GB, nikad nisam probao
Molim moderatora da edituje stavku "Turn off caching of thumbnails in hidden thumbs.db files" u "Turn off the caching of thumbnails in hidden thumbs.db files"ili ukoliko necete da radite preko ram memorije i ovo ume dosta da pomogne
Another good tweak that you didn't mention is to disable thumbnail caching in Windows Explorer. This will stop Windows from writing thumbs.db files all over the place. Here's how:
- Click Start
- Type "gpedit.msc" and press Enter
- Local Computer Policy -> User Configuration -> Administrative Templates -> Windows Components -> Windows Explorer
- Double-click "Turn off caching of thumbnails in hidden thumbs.db files"
- Click "Enabled"
- Click "OK"
- Close "Local Group Policy Editor"
Done.Molim moderatora da edituje stavku "Turn off caching of thumbnails in hidden thumbs.db files" u "Turn off the caching of thumbnails in hidden thumbs.db files"
Nije ako ti nestane struja. :d
koliko mesta zauzme win7 ultimate 64-bit? Pitam zbog kapaciteta SSD-a, koliki je dovoljan?
A ako ima UPS?:d
Ako uzimas preko uzmi onaj od 100 GB, taj ti je najpovoljniji na newegg-u.
Kad se ugasi hibernate i system restore i virtual memory, oko 20GB sa osnovnim programima.
Disable Write Caching
Description: There is no cache on the SSD, so there are no benefits to write caching. There are conflicting reports on whether this gains speed or not.
Instructions: Start Menu -> Right-Click Computer -> Manage -> Device Manager -> Disk drives
-> Right-Click STEC PATA -> Properties -> Policies Tab -> Uncheck Enable write caching -> OK
imam jedan offtopic dodatak i offtopic pitanje ...
dodatak: umesto system restorea imas npr HirensBootCD pa na njemu gost, acronis i sl
pitanje: ima li potrebe da formatiram SSD pre ciste instalacije Win7x64 na njega ili ce to prilikom instalacije Win sam sve da odradi ... pitam jer sam citao da je pravilan alligment vrlo bitan ... ako bi trebalo da se formatira koje paramtre da koristim tacnije koji cluster size i koji file system
Alignment particije:
- ako si na Visti/W7/Srv08, bice automatski.
- ako nisi, onda koristi diskpart:
Command Prompt->diskpart.exe
list disk
select disk # (umesto # unesi broj diska koji je C300, prepoznaces ga po velicini)
Pod pretpostavkom da nema particija (ako ima izbrisi):
create partition primary align=2048
JA sam sistem restore ubijao cak i na klasicnom disku odnosno u zivotu ga nikada nisam ni koristio! KAd dodjem do toga da mi on treba kompjuter mi je uvek bio zreo za format![]()
ja sam na 7ici, ali nesto na net procitah da moze i 7ica da ne uradi posao kako treba ..pa da pitam jel ovo ok?
off:
na par foruma sam pročitao da je ssd vrh kada ga kupiš, ali da vremenom gubi na performansama, kao i da se posle određenog vremena previše greje tako da nije baš preporučljiv za laptop.
koliko ima istine u tome?
