http://www.benchmark.rs/benchmark-t...test-hp-pavilion-dv7-amd-vision-u-srbiji.html
Ja sam iskreno ocekivao vise...
Dell Inspiron M501R
The Inspiron M501R is a Vision Ultimate laptop, featuring a 1.6GHz Phenom II P920 quad-core CPU paired with an ATI Mobility Radeon HD 550v. It differentiates itself from the other models here with 6GB of DDR3 memory, compared to the 4GB on the HP and 2GB on the Lenovo. This spec has helped the Inspiron to score 1.06 in the productivity tests, and it produced a playable 30fps at medium detail in Crysis thanks to the powerful Radeon GPU. It managed to last for an impressive 6hr 16mins in our light use battery tests, but only 1hr 15mins in heavy use.
HP Pavillion DV6 - AMD
HP's AMD-powered DV6 is a Vision Ultimate laptop and uses the same processor as the Dell, but it has a different approach to graphics. It includes both an integrated GPU and an ATI Radeon Mobility HD 5650. While on batteries it uses the integrated GPU, which helps it to 4hrs 12 mins in our light use battery life test, and 1hr 51mins on heavy duty, but when you plug it into the mains you get the option to turn on the high performance 5650. It scored 0.89 in our productivity tests - less than we'd expect from the ‘Ultimate' label - and manages a playable 34fps in medium detail Crysis.
Hmm mene nije razocarao posto je u pitanju koliko vidim procesor (bolje reci skup cipova) koji je namenjen manjoj potrosnji
