FIFA 11
A kako je bre to reseno u FIFI
Uzmi WC pa probaj, ionako ćeš imati mesec dana pre demoa da igraš ;)
A demo pusti, FIFA10 je imala tako čudan demo da sam jedva uspevao da dam gol. Plus, utakmica traje 2 minuta, nemaš custom formacije, nemaš custom taktike, a u tome leži sva čar FIFE, znaš onu krilaticu engineered for freedom? :)
Kralj iako se vrati može da se vrati na period pre 2008me, a da dostigne FIFU... pa trebaće mu malo vremena ako uopšte imaju kapacitet da naprave tako dobar gameplay :)
Da li ce biti Srbije u FIFI11?
Nece.
Gary Patterson, EA Sports producer, posted this on the official boards:
Hi,
Just wanted to come on here and say that I am reading your comments on game speed and also say that I am very confident that the game speed is slower than 10 and WC. Whether this is as slow as you would like is something that we can evaluate once you have played the game.
With regards to the speed, here are some of the changes that we have made that effect the speed:
- Default ground pass speed is slower than in FIFA10 and WC
- Pro Passing adds the possibility of this being even slower
- Player accleration is very slightly slower than in FIFA10/WC
- Tackle speed is slower than in FIFA10/WC
- Pressing is slightly slower than in FIFA10/WC (Due to players having to read the ball trajectory before committing)
- Positioning is tighter than in FIFA10/WC (Forcing you to build up slower)
- Stamina: Increased effect on sprint speed when short term energy is low
- Stamina: Increased effect on acceleration when short term energy is low
Obviously I will be evaluating feedback from here on in and all of the above items (except Positioning) can be tuned post ship without the need for a patch.
Thanks,
Hi,
There is a lot of talk about the pressure button so I thought I'd just let you know what we have done this year to make it slightly less effective:
a. Tackling
- Tackle animations are slower than in FIFA10, that is to say that they are longer to ball contact (less responsive if you like).
- Tackle animations are shorter than in FIFA10, that is to say that the players have less reach with their tackles (attribute based).
- There are more errors in judgement on when to launch a tackle than in FIFA10 (when the dribbler has started a turn, a players ability to predict the direction of the turn - attribute based)
- Tackle animations have better momentum preservation than in 10, therefore defenders cannot break momentum in order to get the ball from you
b. Pressing
- Has more delay in its target update after the ball changes direction (attribute based) so you will not be able to hone in on the ball quite so powerfully.
- Has delay to read the ball trajectory during a pass (attribute based) so you should be under less pressure when you recieve the ball.
c. Locomotion
- Is slightly slower accelerating from stand than it was in 10. This is because we are algorithmically controlling the players speed (therefore his is sticking to his definded acceleration curve) whereas last year this was an animation. This means that he player will take slightly longer to get to you.
- Does not allow the player to acclerate and turn (once above jog speed), this was allowed in FIFA10. Again, this means that he player will take slightly longer to get to you.
d. Dribbling
- Has better shielding than in FIFA10. For example, the player will auto shield from a defender if you turn away from him.
- Jostling is less clear cut than in 10 therefore giving more time to escape or pass the ball.
e. Stamina/Fatigue
Hopefully the video will be released soon but basically, stamina will have a greater effect on how quickly a player will fatigue and fatigue will have a greater effect on a players acceleration and sprint speed (among other things).
I'm not saying that these changes will fix everyones complaints but it has certanly made a difference.
Thanks,
videos :
http://www.youtube.com/watch?v=1bAAR_gOyCw
Koliko FIFA bolje i fluidnije izgleda od PES-a, znaci neverovatno...
Pa ovo im je vec treca (ili cetvrta?) igra sa novim engineom i animacijama.. PES-u prva.. polako...
Samo da se EA seti da smanji broj stepeni, cisto da lici na fudbal.
Pricao sam specificno za onu jednu situaciju, gde i u stvarnosti moraju tako da zalamaju telo.. U FIFI trcanje izgleda bolje, fluidnije je sve.. ne kazem.. ali opet, 'vazdusasto' :)
Sutevi su vazdusasti...inace sve ostalo je na mestu, dueli igraca, dodavanja... :)
I jos jedan veliki + za FIFU, oduvek bilo, licenca!
Neki ce reci, a ovo ono Option File skines za PES...ali zasto bih se cimao toliko, treba posle sve to i obrisati kao npr. sada kada vise nemam PES. Ima preko 250 fajlova, a da ih obrisem treba mi sigurno 15ak min.
Šutevi su vazdušasti jer je beta u pitanju, do sada su u svakoj finalnoj verziji bili sve oštriji i oštriji. Šutevima u World Cup igri recimo skoro da ništa ne fali. Tako da kapiram da će FIFA11 imati sasvim pristojan šut. Ali isto tako kapiram da će biti prostora da se još doradi. Nadam se da su igru glavom ostavili iz WCa.
Glavni vic u FIFI je što ne možeš sa igračem koji ima long shots 60 i shot power 65 da opališ bombu. U PESu si do sada mogao jer se sve svodilo na to koliki si for dao sebi pre šuta.
@wladymeer
To da sut mora da bude preko 65 je stvarno glupo. Pa i onaj igrac iz neke opstinske lige u Srbiji moze da raspali bombu ne mozes tako ogranicavati fudbalere.
Nisam igrao Fifu ali ako je tako to je skroz bezveze. Nadam se da ce ove sezone Fifa za PC biti bolja pa da konacno i ja probam Fifu i da dam svoj sud.
Naravno, ali taj iz opštinske lige ne šutira Casillasu i ako je taj poznat po bombama imaće makar 70 :)
Kada igraš sa slabijim ekipama, tipa, Australijska liga i slično, padaju golovi van kaznenog jer su i golmani slabiji.
Ne možeš na osnovu izuzetka koji se desi jednom u godin dana postavljati pravilo u igri jer se u suprotnom oni pravi šuteri sa distance ne bi uopšte razlikovali od ostalih i svako bi mogao da uvalja gol sa 20+. Recimo, Modrić sigurno ume da potrefi ponekad jak šut na treningu, ali je u utakmicama poznat po suštoj suprotnosti i ja bih prvi umro od smeha da mi neko uvalja bombu sa Modrićem preko 30m i pitao bih se kakva je to igra. I to još recimo levom nogom :)
Na svu sreću, FIFA i o tome razmišlja, pa zato uvek treba paziti kao i u stvarnosti da li si se namestio za šut jačom nogom.
A što se tiče Srbije, prosto i jednostavno, nismo članica EU, slaba je prodaja te igre na Balkanu i zbog toga nas neće biti. Da smo se plasirali recimo u 1/4 finale ili 1/2 finale, verujem da bi bila druga priča. Doduše, ostaje neka mala nada, pošto su kupili licencu za Svetsko Prvenstvo, ali moguće je da je to bio neki dil preko FIFE i da je važio samo za tu igru.
Na zvaničnom forumu se pojavila informacija da će poluvreme u demo-u biti 3 minute. Bolje i to nego ona šunjava 2 minuta. Prošli put nisam uspeo da sastavim 3 akcije ko svet za jedno poluvreme.
http://www.youtube.com/watch?v=nHE5wsaXH2M
Mah, koga briga za to, ionako se FIFA igra na max zoom out :)
Demo details :
Xbox 360 / PS3
Content: One full offline kick-off match, three-minute halves. You’ll be able to upload replay videos to easportsfootball.com (which will be launching with a whole new design on 2nd September).
Release Dates:
SCEA / SCE Asia, Tuesday September 14
SCEE, Wednesday September 15
Xbox, Wednesday September 15
Teams:
Barcelona, Real Madrid, Juventus, Chelsea, Bayer Leverkusen, Lyon
Arena:
Player: Kaka
Goalkeeper: Petr Cech
Stadium:
Arena – South Africa
Game – Santiago Bernabeu
Kako ce se ovo raditi na ps3 kada ds3 nema triggere?
Zar R2 i L2 nisu triggeri? U FIFI je po defaultu sprint na R2.
Mozda on ima neku kinesku kopiju DS3 :) Ali koliko znam nemaju tako dobar 'hod' kao na xboxovom dzojpedu..
Konačno su sortirali ocene po srodnim atributima... a i otključali su specijalnosti igrača tako da budu vidljive i običnim korisnicima... fala bogu više :)
edit: a vidim, ostavili su i penale kao sa WCa, sjajno :d
[YOUTUBE]rRZ_hROMQIg[/YOUTUBE]
I onda kazu voleji a.k.a. Hjerpseth u fifi nerealni!?
